Thread: Body sway when turning sharp
08-17-2016, 05:26 AM #1
Can anyone tell me what can cause the body to have a sway to it when you turn sharp...If I turn the wheel left to right repeatedly it is very noticeable, almost seems like the front sways one direction and the back sways the opposite? It also feels like a floating feeling at higher speeds (70+mph).
08-17-2016, 05:27 AM #2
Rear sway bar is loose, broken, or the holes are oval causing it to shift.
Sent from my SM-G900V using TapatalkBoost gets you laid, unless your name is Jon.
08-17-2016, 05:38 AM #3
Ok thanks for the input...I was thinking worn out shocks, but i'll check the sway bar first. Thanks again!
08-17-2016, 05:42 AM #4
Let me know.
08-17-2016, 03:59 PM #5
OP, If you've got a lot of miles on that suspension, might be time for a refresh in general.
Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
08-22-2016, 07:50 AM #6
- Mar 2011
- fort myers,fl
black- 1998 trans am convertible
Sway bars are my next project after i get ride back from bunp shop. Still have the original ones. i am curious why u have different shocks on yours.
08-22-2016, 07:51 AM #7
I said sway bar but I meant pan hard bar, sorry.
09-17-2016, 02:14 AM #8
Could be sway bar bushings. I would look there. I look for improvement over stock and buy Prothane bushing that are greasable for $30 a set.
I generally do front and back. For $60 it helps a lot. Then if you want even better handling.... Sub Frame Connectors, LCA, Tower Brace, Traclink, Panhard rod, bigger sway bars, upgrade shocks, wider tires and wheels, springs etc...Life comes at you fast. Grab it and hold onto it with all your might.
Living life in the fast lane. 182IDIE
Help: Best sway bar? Dif in reg & Drag Sway Bar??
By Lucky1963 in forum Suspension and HandlingReplies: 8Last Post: 08-25-2010, 11:15 AM -
93 Z-28, Sharp.
By jaybird1234 in forum Vehicles For Sale / TradeReplies: 1Last Post: 01-12-2009, 09:10 PM -
MAf,AGX rear shocks, Strano sway bars,1LE sway bar
By AFASTYZFR1 in forum Parts For Sale / TradeReplies: 3Last Post: 09-21-2008, 01:54 PM -
Stock front sway bar rear sway bar........
By pewterzron in forum Parts For Sale / TradeReplies: 5Last Post: 06-27-2008, 03:42 PM -
WTB H&R sway bar for G-body
By Gbodyolds in forum Parts Wanted / TradeReplies: 0Last Post: 12-27-2005, 07:22 PM
