    Jul 2016
    SC
    2002 Z-28
    02 Z 28 overheating
    My 2002 Z28 is overheating in normal driving. The gauge will move from 210 to the red in 20-30 seconds and the check gauge light will come on. Does this when idling. I can hear the electric fan click on and it runs for around 1-1.5 min after vehicle is shut off. Car is completely stock and has 44k on it. Where should I start?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Thermostat not opening.....low coolant level....radiator plugged up....air bubble in a line.....water pump not working.
    Sent from my SM-G900V using Tapatalk
    And do not trust the factory temp gauge. It is a temp estimator at best. If you will be swapping the thermostat I recommend flushing the cooling system and changing out hoses, as needed. The factory service manual recommends against using a chemical flushing agent. Use a flashlight to inspect the radiator core through the cap and hose openings. Also, use a high pressure hose from the back side (as best you can) to flush dirt and debris out of the fins. Refill with a 50/50 mix of Dexcool and distilled water.
    Jul 2016
    SC
    2002 Z-28
    Ok thanks for the info, much appreciated.
  1. overheating
    By lancesT/A in forum General Help
    Last Post: 07-13-2007, 12:12 PM
  2. Always something.. Car overheating.
    By juiced99ws6 in forum General Help
    Last Post: 07-13-2007, 01:40 AM
  3. OverHeating! Need help
    By 02bluez28 in forum General Help
    Last Post: 05-13-2007, 01:13 PM
  4. overheating
    By lancesT/A in forum Firebird / WS6
    Last Post: 05-09-2007, 07:45 PM
  5. overheating 02 z-28 (not sure)
    By chuckt619 in forum General Help
    Last Post: 09-10-2005, 10:40 PM
