Results 1 to 17 of 17
Thread: 01 SS randomly dies!
06-17-2016, 10:15 PM #1
- Jun 2016
- Tennessee
Hello, I have an 01 camaro that has something weird going on, during the winter months it drives fine and doesn't die but when summer rolls around it will start and run for about 3-4 min then then idle sounds like it changes then dies shortly after, it doesn't stumble, jerk or anything its like you cut the switch off to kill it, I have replaced the fuel pump, crank sensor, PCM, cleaned throttle body and IAC valve chasing this problem, note it only has 86k miles on it
06-18-2016, 03:42 AM #2
Never hurts to check fuel pressure. Does it start right back up or do you have to crank on it?
06-18-2016, 02:03 PM #3
- Jun 2016
- Tennessee
06-21-2016, 11:22 AM #4
This is a possibility....
How full is the tank? Some times the plastic line in the tank will crack. Fuel drops below the crack and then you no longer can get fuel to flow.
How to test is with a Fuel Pressure Gauge, turn key on and leave it on. Watch the pressure it should surge to 56-60 psi and stay steady. If the pressure drops then you most likely have this issue.
Far shot on this one....but have you had any other issues? Like the windows, radio, lights inside cut off randomly, security light comes on and off?
I'll wait for your reply before I go further.
06-21-2016, 11:52 AM #5
- Jun 2016
- Tennessee
06-25-2016, 02:34 AM #6
Any luck yet?
06-25-2016, 02:45 AM #7
- Jun 2016
- Tennessee
06-25-2016, 10:53 AM #8
Curious if the stumble and die happens right when the PCM switches over from open loop to closed loop? If I recall, this occurs when the coolant temp gets to about 140 degrees, so time-wise it may correspond with your issue.
06-25-2016, 02:04 PM #9
- Jun 2016
- Tennessee
It sounds like it changes idles if you listen very closely then shortly after it changes it dies, it also sounds like something kicks off when it changes kinda sounds like turning a vacuum cleaner off, but then again you have to listen very very closely, thanks so much for your feedback it's greatly appreciated
06-26-2016, 02:28 PM #10
The "vacuum cleaner" is most likely your secondary air system. There is a pump mounted in front of the driver side wheel well that blows air into the exhaust manifolds at cold startup. This system only runs for a short period of time and helps get the catalytic converters up to temperature. It really does sound like something acting up then when it goes into closed loop. Have you ever cleaned your MAF and throttle body?
06-26-2016, 02:42 PM #11
- Jun 2016
- Tennessee
06-27-2016, 12:03 PM #12
When you have it apart - take a look at the MAF to see if it has been modified (ported, descreened, debladed...). You'll want to use something like CRC Spray MAF Cleaner and then a Throttle Body Cleaner as well. You can hose down the throttle body and carefully wipe away the gunk. Q-tips work nice for the crevices and such, but do not use them on the MAF.
06-27-2016, 02:50 PM #13
- Jun 2016
- Tennessee
07-15-2016, 02:29 PM #14
- Jun 2016
- Tennessee
Cleaned the MAF, started it, it got to nearly operating temp and died, not sure if I added that the check gauges light comes on, wouldn't start back just turned over and over.
07-16-2016, 09:32 AM #15
Scan for codes?
07-28-2016, 04:05 PM #16
I had a very similar issue but on a lt1. It was my ignition control module. It would randomly cut off when it was really warm. Then the next day it would run fine. It took me several other avenues before figuring out that's what it was
07-30-2016, 04:58 PM #17
So how is everything coming?
Was your SES light on at all during any of these cycles?
2018 Tahoe - Silver - OEM
Alarm goes of randomly?
By MasonWS6 in forum General HelpReplies: 2Last Post: 08-08-2015, 10:59 AM -
Ws6 Randomly Misfires
By JeepJake in forum Firebird / WS6Replies: 24Last Post: 10-15-2012, 05:08 PM -
Volume goes up and down randomly on its own
By cascade in forum Stereo and ElectronicsReplies: 6Last Post: 08-29-2011, 09:38 PM -
Help: Car randomly shuts off???
By iceman504 in forum General HelpReplies: 10Last Post: 04-14-2008, 05:49 AM -
Z28 Randomly shuts down...
By Kamauxx in forum General HelpReplies: 10Last Post: 08-15-2007, 02:47 PM
