    Member TransAmTerry's Avatar
    May 2010
    Abingdon, Md
    02 TransAm Ramair WS6
    Can't get my rear rotors off !!
    Is there some trick to getting the rear rotors off ?? The E-brake is off, there is no screw holding them on and no retainer clips on the studs. I have an 8lb steel hammer that I have pounded the crap out of it with. I put PB Blaster on the hub area. won't even budge. ...and of course the caliper and bracket are off. Has anyone else ran across this problem and solved it ??
    Feb 2015
    Harrisburg, PA
    1995 Firehawk
    I had to beat mine to death to get them off. But they eventually did come off.
    98 T/A w/ mods, 00 FBVert
    Ditto....but only when I was doing a total replacement.
    Try hitting the center of the axle hub a couple of times to shock it. If you have to smack the rotor place a 2x4 board between the rotor and the hammer. Less chance of damaging the rotor. Applying a little bit of heat sometimes works as well.
    Just make sure if you're using PB Blaster or WD40 you clean all brake surfaces with brake cleaner.
    May 2010
    Abingdon, Md
    OK,, so it appears it's just being stubborn then. I just put everything back together ,, i'll get back after it when I get back from GM Carlisle . Running out of time with work and a bunch of other stuff. Thanks for getting back to me.
    '02 Black RamAir M6--Kooks LTH, Magnaflo, Lowered Eibach springs and Bilstien shocks, Tuned By Frost, K&N & SLP box, Smooth bellows, polished TB, Spohn perf. suspension, shock tower brace. UMI 3point SFC. Front & side splitters w/ canards. American Racing 18" wheels & Mich. Pilot SS titres
    '76 LagunaS3 - 355ci , 350 turbo, 3:55's
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Use a 9lb one lol.
    Sent from my SM-G900V using Tapatalk
    Feb 2015
    Harrisburg, PA
    1995 Firehawk
    Do you want me to bring my hammer to Carlisle?
    May 2010
    Abingdon, Md
    No hammers this weekend. just gonna have some fun !!
    Feb 2015
    Harrisburg, PA
    1995 Firehawk
    Hammers can be fun too. But, I am all for a nice relaxing day this saturday.
    Grab a torch and heat around the hub - even a propane torch will work in most instances. Use either a soft face dead blow hammer or a block of wood between the rotor and any steel hammer. Make sure you have at least one lug nut in place so the rotor does not get launched across your garage. After removal, wire brush the axle lip and lightly grind or sand the inner lip of the rotor as this is where they normally seize.
  1. Question: Rear rotors
    By Project LS1 in forum General Help
    Last Post: 04-27-2011, 06:11 PM
  2. Wanted: rear rotors
    By MUDDOG in forum Parts Wanted / Trade
    Last Post: 12-27-2009, 08:24 AM
  3. Anyone put front calipers & rotors on rear??
    By COKEBOTTLES in forum Suspension and Handling
    Last Post: 08-01-2009, 07:47 PM
  4. are 97 rear rotors the same as 2000
    By lx24 in forum Firebird / WS6
    Last Post: 03-25-2007, 02:37 PM
  5. Wtb: Ls1 Rear Rotors
    By 1badchicken in forum Parts Wanted / Trade
    Last Post: 01-30-2006, 06:15 AM
