Thread: LQ4 with stock lS3 heads
05-31-2016, 01:03 PM #1
- May 2016
- Canada
red- 1970 Camaro
I want to put a LS3 camshaft (or equivalent ) in my engine. I like keeping things designed to work together...together.
I don't want to go crazy with changing head springs or carving piston reliefs in my pistons. I want a nice street able engine. it will never see the track. The loppy idle would be add to the cool factor but not necessary.
So my question is , what modifications do I have to do to put a LS3 camshaft in my LQ4 engine? My LQ4 is a 2003 where the cam sensor is in the back.
05-31-2016, 04:25 PM #2
Why not just go to any one of the dozen or so aftermarket cam manufacturers and spec out a bumpstick that will work with what you have?
05-31-2016, 04:31 PM #3
I just saw your car at the bottom of your profile -- sweet! We have a '70 that we just picked up last August from the Rochester area. Great car and we have been thoroughly enjoying it.
05-31-2016, 04:40 PM #4
- May 2016
- Canada
red- 1970 Camaro
05-31-2016, 05:54 PM #5
That makes sense. Is the LS3 cam a 1 bolt or 3 bolt design?
05-31-2016, 06:50 PM #6
- May 2016
- Canada
red- 1970 Camaro
06-02-2016, 07:21 AM #7
- Apr 2010
- Alabama
Are the knock sensors in the valley or the side of the block that will determine what you have to do. Mine are in the valley so that means I have to relocate a few things to make that work since its gen 3. Also the ls3 is a one bolt design not 3 like gen 3.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
06-02-2016, 09:19 AM #8
The one bolt is also for the Variable Timing that connects to the cam. Here's a couple of articles on it.
GM's Variable Valve Timing System Performance Test - Hot Rod Magazine
http://www.enginebuildermag.com/2014...-valve-timing/
AFR heads VS. Ported and beefed up stock heads.
By hutcher04 in forum Internal EngineReplies: 10Last Post: 03-14-2010, 08:27 AM -
For Sale: Stock 241 Heads and Cam
By Shepp1691 in forum Parts For Sale / TradeReplies: 3Last Post: 03-21-2009, 05:01 AM -
New Heads or Port/Polish Stock Heads?
By Black02LS1 in forum Internal EngineReplies: 32Last Post: 06-22-2007, 11:29 PM -
New heads or Port/polish Stock Heads?
By Black02LS1 in forum Western MembersReplies: 0Last Post: 05-20-2007, 09:11 PM -
WTB stock LS1 Heads
By lowonair6173 in forum Parts Wanted / TradeReplies: 1Last Post: 04-21-2006, 06:15 PM
