05-31-2016, 01:30 AM #1
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
Need good 350 heads to go with 290 comp cam.
I have a 290 comp cam that have a 501/501 lift in my 350 engine that is bored 30 0ver with 10 to 1 flat top pistons, rpm intake 750 holley carb, hooker headers 2.5 inch exhaust with hooker mufflers. the engine have vortec heads with a 525 max lift with 190/150 valves,The truck runs good but I feel that a lot my be left on the table by me not having bigger valves to make the engine show it's full performance. I don't all out race the truck but just want the go power when I want to at times. I have a set in mind that have 202/160 valves 575 max lift that are alum. made by blueprint which is also on a engine I purchased from them some years ago.what should I be looking for to make sure I get the best head for the least amount of money.Dont want to go over board on the price. any ideals?
05-31-2016, 03:08 AM #2
You can't beat the iron Vortec heads for the money. We run those on our '74 Corvette 350 engine and it is a torque monster. An aftermarket set of heads will up the ante a bit -- just not sure if it is going to be worth the extra $$ in the long run. Has the current combo ever been tuned -- distributor curve, air/fuel, etc...?
06-02-2016, 04:57 AM #3
Jeff is on the money.
You say truck and I think big heavy vehicle shaped like a brick used to tow and haul stuff. So I'd be more concerned with a nice flat torque curve and not so much HP.
The Vortec heads are a good piece out of the box. They are exactly what GM used to create the LT1 heads in later years (with reverse flow cooling) Same intake/exhaust port design.
If it hasn't been already, I'd get it on a chassis dyno and fine tune it, there may be enough power there to be found to satisfy. If you're really ambitious the vortec heads wake up with a simple bowl blend and clean up to help mid lift flow numbers. Would cost you nothing but gaskets and a couple days time.
06-05-2016, 03:55 AM #4
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
There is no dyno turners in my area, the nearest one is about 600 miles away. I have changed springs in the dist, played with the timing,changed the jets in the carb,installed 2.5 exhaust and hooker headers and mufflers, other than that I am lost.Like I said the truck runs good and may be I look for it to perform like my camero which weights a lot less.yet like all of us the truck is not what I feel it should be.
06-05-2016, 04:02 AM #5
The extra thousand pounds or so of the truck does make a huge difference. Rear gears are the easiest upgrade for a "snappier" feel, and so long as you do not tow with it, a bit looser converter if it is an auto. Both will compromise your fuel mileage but will improve the feel of your truck.
06-06-2016, 04:00 AM #6
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
For Trade: Ls1 241 heads with comp cam springs
By Rk ws6 in forum Parts For Sale / TradeReplies: 0Last Post: 11-25-2012, 07:18 AM -
Dart heads/comp cams in L.A
By LS1 WPN in forum General HelpReplies: 0Last Post: 02-20-2007, 01:41 AM -
FFHP STG I heads, Comp 850's, HPT & more
By jrp in forum Parts For Sale / TradeReplies: 16Last Post: 07-08-2006, 03:22 PM -
Ported 4.8 Heads & Comp R Lifters
By Fubarredz in forum Parts For Sale / TradeReplies: 2Last Post: 05-25-2006, 12:09 PM -
Brand New CNC Inc heads and used Comp Cam!
By onelife in forum Parts For Sale / TradeReplies: 11Last Post: 11-11-2005, 10:26 AM
