Thread: 2002 camaro ss speedometer
04-30-2016, 03:13 PM #1
- Apr 2016
- US
I had to replace the pcm in my car after I replaced it I let it run for about 10 min to let it re learn. I went for a drive and the speedometer is way off. Going around 50 and speedometer shows I'm going 120. Any ideas?
Sent from my SAMSUNG-SM-G900A using Tapatalk
05-01-2016, 01:36 PM #2
Sounds like a simple calibration issue -- A4 or M6? If it's an A4, are you having any shift issues?
05-01-2016, 02:08 PM #3
- Apr 2016
- US
05-02-2016, 11:20 PM #4
- Apr 2016
- new york
Did u checked the working of your speedometer? Maybe there would be an issue with that
05-03-2016, 02:18 AM #5
Ok, sounds like you are A4. You should probably stop driving the car until you get this fixed. The transmission has several functions that are dependent upon speed and if it is being fed incorrect data the PCM is probably going a little nuts. You need to scan your tune to see what gearset it thinks it has and then check that against what you actually have. This is simple to do with a handheld or something like HP Tuners.
05-03-2016, 11:13 AM #6
Jeff is correct, no longer do you need to swap in the correct speedo gear in the transmissions. They all have the same speedo, it's what the ecm is program to take what inputs it gets and then sends a signal to the dash cluster/speedometer needle.
05-03-2016, 11:22 AM #7
- Apr 2016
- US
Thanks for the input I went ahead and got the pcm tuned and they were able to fix it
05-04-2016, 03:40 AM #8
Good to hear.
Improving Pontiac Speedometer Accuracy - Speedometer Super-T
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 02-27-2012, 09:10 PM -
2010 camaro ss or 2002 camaro z28
By pgviper in forum Camaro / SSReplies: 32Last Post: 06-13-2011, 06:13 PM -
2002 mustang gt vs 2002 camaro
By jrea42 in forum Kill StoriesReplies: 24Last Post: 09-05-2009, 06:07 AM -
2002 T/A WS6 vs 2002 Camaro Z28/SS
By cbo0485 in forum Almost Anything GoesReplies: 126Last Post: 06-24-2007, 07:55 AM -
wtb, corvette speedometer cluster for a camaro
By sscrazy in forum Parts Wanted / TradeReplies: 0Last Post: 09-27-2005, 07:49 PM
