Results 1 to 20 of 26
03-25-2016, 12:31 PM #1
- Mar 2014
- New England
black- 02 trans am
02 LS1 with gm ac delco dexos 5W30
Has anyone tried the "new" Gm Dexos 5w30 in a ls1? my car has 80,00 mile on it and has only had conventional oil since new. I'm looking to get some more protection but I'm scared of going to a full syn because of reported leaks with late millage switch overs. Would the Dexos be a good fit? My gm truck seems to like it and I would only have to stock one type of oil at home.
Thanks
03-25-2016, 04:01 PM #2
Go buy some Penzoil Platinum full synthetic and stop worrying. The issues with synthetic oil were from so long ago that even an old guy like me can barely remember when that all went down.
03-25-2016, 05:10 PM #3
- Mar 2014
- New England
black- 02 trans am
You really don't think I will see leaks and oil burning off by going to a full syn this late in the game?
03-25-2016, 07:49 PM #4
My understanding is that the "rules" for manufacturing petroleum products (like motor oil) are that the have to be interchangeable and even mixable. In other words, if I understand it correctly, you could run any brand or type of motor oil (per your application, of course) and it should be "fine."
Note that the quality of the product will be another story. Not all oils are created equal. Mobil1, for example, changed their formula and certain parts manufacturers stopped using them (Comp Cams, I think was one of the parts makers who stopped using/advocating Mobil1).
I switched from Mobil 1 to Amsoil, myself.
03-26-2016, 03:57 AM #5
03-26-2016, 07:32 AM #6
- Mar 2014
- New England
black- 02 trans am
How old were those engines when you made the switch. Did they all have conventional oil before. Does anyone have any knowledge of the dexos oil?
03-26-2016, 07:55 AM #7
Switch was made as long as 8 years ago on the Corvette, 6 years ago on the Monte Carlo, 3 years ago on the Regal and last year on the '70 as that is when the last two were acquired. All ran conventional oil previously. The dexos oil, which is a synthetic blend, will work just fine, as will any of the current synthetics on the market. I have been running Penzoil Platinum full synthetic in the Trans Am since 2010, and another brand synthetic prior to that since 2008. Not a clue what was run in it previously, but I would guess conventional motor oil.
For our vintage cars, the only problem with modern oils is the lack of any meaningful zinc content which can wreak havoc on old school flat tappet cam setups. Your car has a hydraulic roller cam, as do almost every other modern car these days that runs a push rod setup, and the lack of zinc is not an issue. I run a ZDDP additive in our old school cars (which has nothing to do with the engine seals) to protect the valvetrain.
03-26-2016, 10:50 AM #8
- Mar 2014
- New England
black- 02 trans am
Thanks for the info. I wonder how the Delco synthetic blend compares to other leading name brand motor oils. It must be pretty good GM is putting in all of their cars at the dealerships, right?
03-26-2016, 02:37 PM #9
Check out "Bob is the oil guy" and I am certain you will find some chatter about it.
03-26-2016, 03:08 PM #10
- Apr 2010
- Alabama
All I know is my engine builder, Tick Performance said go with Valvoline VR1
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
03-26-2016, 08:25 PM #11
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
VR1 seems to be real popular with guys running aftermarket cams and heads or full blown custom built engines like you have.
03-27-2016, 04:28 AM #12
03-27-2016, 04:40 PM #13
- Mar 2014
- New England
black- 02 trans am
I'm gonna try the ac delco dexos. Bob is the oil guy had a lot of good things to say about it
06-17-2016, 10:44 AM #14
- Mar 2014
- New England
black- 02 trans am
So I have put about 500 miles on the car since the last oil change. The ACDelco synthetic blend noticeably quieted down the common cold start LS1 piston slap. As a matter fact it pretty much eliminated it. So far there are no leaks or consumption issues, what I see any additional benefits from going over to a full synthetic or should I just stick with what I'm doing?
06-22-2016, 02:21 AM #15
Longer oil change interval.
10-30-2016, 06:48 PM #16
- Mar 2014
- New England
black- 02 trans am
Just completed a successful season on the new oil. The ls1 is running quieter then ever and have noticed zero consumption or leaks. I put on about 1100 miles this year. Should I keep running the ac delco synthetic blend or should I move to a pennzoil Platinum or other full synthetic for next year? Pennzoil seems to put big money into marketing because their commercials have me wondering if I'm sort changing my baby lol
10-31-2016, 02:10 AM #17
My understanding regarding synthetic blends is that they are conventional oil with "synthetic" additives. I have been on full synthetic for a while. I currently run Z-Rod (Amsoil) and the wear and tear on the engine has been reduced significantly (based on the amount of shrapnel on the drain bolt when I do the oil change--since running the Z-rod, there is basically no shrapnel/shavings at all).
However, I'm not sure Z-Rod is ideal for a stock engine. If you get rid of the cats, then I'd recommend it, but Zinc is "supposedly" bad for the cats if it gets in there.
10-31-2016, 04:32 AM #18
- Aug 2016
- Merrick,NY
- 2001 WS6
I had an 86 GN I purchased in 92 from a meticulous owner. Soon I went to Mobil 1 for the turbo which only went to 15 psi. Then the rear main seal started to leak. I ran a 160 stat and seemed like the hotter the engine got especially in the summer, the more it leaked and I eventually had to change the rear main seal. That's why I am sketchy about putting it in my 58K LS1 that had questionable maintenance before I got it.
Sent from my iPhone using Tapatalk
10-31-2016, 07:50 AM #19
- Mar 2014
- New England
black- 02 trans am
My ls1 got regular maintenance prior to me owning it. I have service records showing oil changes every 3000 miles. However, like you, I'm still a little sketchy about the change to a full synthetic. The car seems to love this ACDelco synthetic blend which is a dexos approved oil so it must be pretty good. All of these synthetics like Valvoline synpower and Pennzoil Platinum just have me wondering if I would be better protecting my car about using one of them
10-31-2016, 08:07 AM #20
- Aug 2016
- Merrick,NY
- 2001 WS6
I'm sure you could get plenty of miles out of a properly maintained vehicle using regular oil, however the synthetic benefits are real especially during start ups and in cold environments. I haven't seen a test on a blend to see the flow rate in cold weather and so on. I can't even find the percentage of synthetic in blends. Now I am thinking of using Magnatec and full synthetic at a 50-50 blend. They are compatible and at least then I know what's in the car, maybe it's not enough to start pissing out the rear main seal
5w30 or 10w30?
By 02fbody35th in forum Internal EngineReplies: 22Last Post: 05-28-2010, 06:40 PM -
What kind of oil 5w30& spark plugs&spark plug wire
By ROMERO98Z28 in forum General HelpReplies: 20Last Post: 09-01-2009, 01:50 PM -
AC Delco 9mm wires & AC Delco Iridium plugs
By NitrOmm in forum External EngineReplies: 9Last Post: 07-15-2009, 08:04 AM -
Question: Switch from 10w30 to 5w30..now...
By JoshieDoom in forum General HelpReplies: 4Last Post: 07-08-2008, 11:04 AM -
10W30 or 5W30 in New Jersey?
By Patsy57 in forum Internal EngineReplies: 9Last Post: 05-01-2008, 02:34 PM
