Results 41 to 60 of 308
09-04-2015, 04:13 AM #41
Over on Tech there's plenty of threads on Mickey Thompson ET Street Radials (not the Radial II's which the article is about) vs Nitto tires. The Radial II's were designed to be more of a street tire, not a track tire. Big difference between the Radials and Radial II's.
Here's the M/T ET Street Radials:
The Street Radial II's:
09-04-2015, 04:21 AM #42
I would still like to see what the 60's between the 3 looked like. I wonder how close to the et streets the 2's are everything else being equal. That guy was cutting 1.7x on both of those...wonder what his 60's would be with et's? I wonder what he's leaving on the table running those tires? I cut 1.69-1.71 all day long on et streets with less power. This stuff makes me want to spray my car even more. I just worry about the tranny these days. It's on borrowed time.
09-04-2015, 04:38 AM #43
That would be a nice write-up comparing all 3. Hell, even throw in the NT555R. My friend was cutting 1.5x consistently on the ET Street Radials. I'd personally be happy with 1.6x in my car. It's built from the ground up, but I do have one weak link still; T56 output shaft is stock.
09-04-2015, 06:03 AM #44
If someone want to pony up for 3 sets of tires and wheels, I will gladly put them to the test.
09-04-2015, 06:25 AM #45
off for 4 days....
09-04-2015, 08:01 AM #46
my tranny is still stock minus the stall and cooler.....I've been lucky so far. I have noticed recently that it's started chattering when going into lock up so I'm guessing the lock up clutch is about shot. The plan right now is to put a littl 100 or 125 shot on it this winter but if I have to replace the stall those plans are in jeopardy. I've ran 11.80's with it and want to get about another second out of it to keep up with my brother. He just procharged his GTO and put down 600 to the wheels. I figure he'll be low 11's or high 10's if he can launch it which is a trick in and of itself with those cars.
09-04-2015, 08:08 AM #47
I'd really like to be part of the 10s club, but it's not happening with where the car stands now. 11.3-11.4 and I'll be happy.
09-04-2015, 08:11 AM #48
I do not want to run faster than 11.49 as I have zero plans to cage our car.
Big cruise in tonight - have the Camaro, Trans Am and Regal ready to roll.
09-04-2015, 08:22 AM #49
I have zero plans for a cage either You get a few shake down runs then 1 real good one and call it a night.
09-04-2015, 08:41 AM #50
09-04-2015, 09:12 AM #51
- Feb 2007
- San Diego, CA
My sig shows what I was doing with the ET Street DR's. I had Nitto 555r's before that and it wasn't even close...
67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
09-04-2015, 09:15 AM #52
09-04-2015, 09:19 AM #53
09-04-2015, 10:59 AM #54
I think I might do a Zex high output kit. I'd be really tempted to just stick with the low kit because 125 is probably pushing it for how much I would want to spray. Never can tell though. Better to have and not need than to need and not have.
09-04-2015, 12:36 PM #55
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
II'm not really sure what that is all about!
The NT05R's and the ET streets look pretty similar to me and I can tell you my NT05R's feel pretty soft.
I never said anything bad about the ET's other than what I read about the side wall's being a little soft and not a great street tire for cornering. I was looking for something that would be good at the track as well as the street, also price I found on the Nitto $392 pair shipped was what I could afford. The lowest I found the ET's was $70 more per pair and shipping was extra!
Now to be clear I Only like how the Nitto hooked up on a high horse power car with a six speed on 3,500 rpm launches nothing more just that. Not comparing to M/T at all!!
And if they get me down the track with out spinning 1st - 4th then my money well spent its just for fun for me...
09-04-2015, 05:50 PM #56
Damn when it rains it pours....so today was suppose to be my off day. Spent the 1st half driving miss daisy (my wife) around. Then I get home and find the light on the septic grinder pump is on. That's bad, like shitty bad So I start thinking God that the last time it had an issue the company put in one that all the electronic stuff is in a box outside of the literally shit hole. I pop the fuse and can't tell if it's blown or not. Multi-meter decided to give and quit on me. So off on a journey to find said fuse. HD & Lowes do not carry it. So I go to a couple of real stores for electrical and such stuff. 1st on struck out, 2nd had 2 so I go them both.
Get home pop in fuse - nothing. WTF? so after screwing around I for some reason wonder over to the fuse box. Yup main circuit was popped for the shit grinder. Reset then back to the panel. Still not working so now I'm pissed. I smack the panel and the damn thing turns on. So like a smart man I close it up and walk away.....
Next I install a new led light for the laundry room and in the process hurt my damn back. Then while cooking supper one of the large elements quits.
I'm done.....where's the beer?
09-04-2015, 06:30 PM #57
what make is your aerator? When was the last time you pulled it out and cleaned the shaft on it? Need to do that a couple times a year. Shit paper and lint and shit like that gets around the shaft and causes it to get out of balance and can, at a minimum, pop the breaker but it can also fuck up the motor on that aerator. That's just a little 5 amp push button breaker so it doesn't take much to pop it. Went through all this shit a few times with mine so I'm pretty well versed on shitter repairs. I would have to look at the paperwork but if you do ever need a motor let me know.....I found a place somewhere that was half price of all the other places. Those motors are about $400 IIRC. I ended up having to run a new wire out to mine because I had a short somewhere but I've been round and round with that motherfucker several different times. It ran for a year or two plugged into an outlet on the side of the house until I finally got around to burying a new wire. Put the new wire inside some pvc which is technically against code but fuck 'em....they're not the ones that have to dig that thing up when it shorts. Won't be having anymore shorts on that wire.
09-04-2015, 06:35 PM #58
it's a good looking tire and I'm sure some thought went into how close they could get it to look to the et streets without getting sued Compounds and sidewall, like you said, are more important than tread pattern really. I run 555r's on mine on the street but I could see me going with the 05r's for my next tire depending on the mileage people get out of them. Actually....mileage isn't as big a deal for me as it used to be. I could easily just run et streets and still get a decade out of a set of tires almost I think I put 600 miles on my car last year and here it is september and I have about 400 on it this year.
09-04-2015, 06:57 PM #59
The tire you read about having issues on the street wasn't the ET Street Radial, it was another M/T tire lol.
09-04-2015, 07:09 PM #60
Ford halts Mustang production in wake of September sales div
By Ed Blown Vert in forum General Help - 6th GenReplies: 1Last Post: 10-15-2016, 03:56 PM -
*** Back to School (September) TRAIN ***
By ls1camino in forum Almost Anything GoesReplies: 665Last Post: 09-30-2013, 02:21 PM -
I want my wake to be like this.
By EnjoiJoe in forum Almost Anything GoesReplies: 9Last Post: 05-02-2010, 01:18 PM -
***September Texas Mini-Train***
By ntimid8r in forum Texas MembersReplies: 72Last Post: 09-30-2009, 06:09 AM
