Results 1 to 20 of 41
05-11-2015, 10:49 AM #1
- Jan 2015
- Sacramento
Black- 2002 WS6 Trans Am
Best way to dry your car after a wash?
From my understanding, the majority of swirl marks come from drying. What have you detail freaks found to be the best and safest way to dry your car after a wash?
05-11-2015, 11:02 AM #2
My favorite way is get in and drive as fast as I can.....
05-11-2015, 11:05 AM #3
- Jan 2015
- Sacramento
05-11-2015, 12:43 PM #4
Get the car up to 88 mph and that should dry it off
WARNING: The flux capacitor has to be in the off position before attempting to dry your car this way.
05-11-2015, 12:43 PM #5
- Jan 2015
- Sacramento
05-11-2015, 01:56 PM #6
I know you guys are just being funny, but I've tried it in the past and it doesn't work. I used to live one block from a highway. I washed and took it out on the highway for a ways and came back. There was still a lot of wet spots on the hatch and in "grooves/corners". And the water around the taillights would come pouring out after I stopped. And the back would get dusty going down the road so I didn't want to dry then.
I have a real and an imitation chamois. Only use in straight lines.
BTW Not a detailing expert. I always thought swirl marks came from washing.
05-11-2015, 01:59 PM #7
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
Micro fiber towels or true 100% real deal cotton towels.
Do NOT wash and dry them with any type of fabric softener. It will actually cause issues with your paint in the long run...you would think that since they are softer it would be better but the chemicals in fabric softener are bad juju for paint.2000 Black TA M6 - LT's, ORY, UMI Short Stick, TT2's, Drilled/Slotted Rotors, Braided Lines, and Tuned by Vengeance SCCA and Car Show Approved
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
05-11-2015, 02:14 PM #8
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
I use Cobra waffle weave microfiber guzzler towels. Dry just about the entire car and only have to do one pass with it. Usually only have to wring it out a few times. Have a smaller one to go over any panels that aren't completely dried the first time. Korean microfiber is some of the best out there.
05-11-2015, 04:59 PM #9
- May 2010
- Wilkes-Barre, PA
Black/Black- 98 WS6/04 Sierra Dmax
leaf blower! electric one.
Callies 383, Trick Flow 225, Rapid Motorsports Dominatior 2 X cam, ls6 ported oil pump,42lb injectors, FAST 92/92 , ASP underdrive pully, eletric water pump, Pacesetter LT's, Pacesetter ORY, Magnaflow catback, e-cutout, Yank SS 3600, Performabuilt stage 2 4l60e, Strange S60 ,4.10s, Detroit Truetrac, (UMI) - Adj. LCA, Adj. tunnel mount torque arm, Adj. panhard bar, Drag bar, subframe conectors, shock tower brace. 465rwhp-438rwtq 11.09@119.90.
05-12-2015, 09:10 AM #10
- May 2012
- Dayton, Ohio
Black & pewter- 2002 Formula & 1999 TA
I use the water blade to get most of the water off and then when I get home I use a microfiber towel to finish drying it off.
05-12-2015, 09:12 AM #11
- Jan 2015
- Sacramento
05-12-2015, 10:50 AM #12
black cars are the worst.....they look the best clean but it takes about twice as much work to get them there as the lighter colors. I normally wash mine and dry it with a combination of a shammy, waffle towel, and cotton towels. Just seems I need the combo of them all to get it dry. Even still I use a spray detailer and a couple microfiber towels right after to go back over the car to get any of the spots that I either missed or dried before I could get to them. Just washing my car is a several hour experience and one of the reasons I dread doing that shit these days. I used to not mind it but after 15+ years it just seems like tedious work these days.
05-12-2015, 02:25 PM #13
05-12-2015, 02:27 PM #14
- May 2013
- Nashville, TN
And you need a California duster...it'll save you from washing your car all of the time.
05-12-2015, 02:36 PM #15
One of the worst things to use on paint. They scratch the paint.
Also I would recommend to not use the brushes at a coin op. Those will scratch the paint.
This is a good video. If you have a good layer of wax or sealant you can sheet the water as seen about the 1:36 mark.
As far as drying media I would get a couple of these. Either one would work fine.
The Edgeless Avalanche 20 x 40 Super Plush Drying Towel | The Rag Company
Dry Me A River Jr. 20 x 40 Waffle Weave Microfiber Towel | The Rag Company2002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
05-13-2015, 08:29 AM #16
- Nov 2011
- CT
Here you go. The ultimate washing and drying guide.
Washing and Drying Auto Detailing Guide - Detailed Image
05-13-2015, 08:20 PM #17
I've used a good ole' fassion shammy all my life, keep one in every car just in case a wash is required during a road trip.
Works just fine for me. On the darker color cars, especially black, I might go back over it when it's dry with a little spray detailer and a micro fiber towel. But I find as long as I keep a good coat of wax on it, the shammy dries it just fine and the micro fiber/detailer step isn't always necessary.
After 2-3 washes, I need to apply wax again. I also find (in dusty Arizona) that using the California dusters are daily routine to keep from having to wash the car too often. The problem with the California dusters is that they leave parafin wax behind on the paint (that's how the duster picks up dust) but unfortunately this parafin wax left behind simply attracts more dust on the car even faster. So generally after a session with the duster to get the majority of the dust off, I go back over the car with a spray detailer and micro fiber towel to remove the parafin wax. The car stays dust free much longer this way.
Unfortunately it's simply a ton of work to keep a nice paint job on a car that's driven at all.
05-14-2015, 12:36 PM #18
Have you considered switching to a sealant rather than a wax? A sealant doesn't attract dust as much as a carnauba wax. They also last longer and are more durable.
05-14-2015, 12:39 PM #19
05-14-2015, 12:43 PM #20
Actually, In the very near future, I'm simply going back to 2 classic daily drivers in primer and the heck with paint. Even my wife wants hers that way. Less worries about everything, including door dings and rock chips That way all the nice stuff just stays in the garage and only comes out when needed, or when I feel ambitious.
Had to wash AGAIN!!!
By ls1camino in forum Firebird / WS6Replies: 10Last Post: 10-21-2008, 11:30 PM -
Question: Hand Wash Or Touchless Car Wash?
By 96Firebirdformula in forum Showcar and DetailingReplies: 55Last Post: 08-30-2008, 05:55 PM -
Question: Pressure wash or drive thru wash really that bad?
By terrytheexpert in forum Showcar and DetailingReplies: 9Last Post: 05-13-2008, 02:35 PM -
Best Wash and Wax
By MY67GTO in forum Showcar and DetailingReplies: 17Last Post: 12-25-2007, 09:07 AM -
What car wash are you using?
By LETHALxLS1 in forum Showcar and DetailingReplies: 25Last Post: 09-05-2007, 08:57 AM
