Results 41 to 60 of 321
Thread: *** Mayday TRAIN ***
05-05-2015, 01:38 PM #41
05-05-2015, 01:54 PM #42
Been non-stop in the garage lately I swear. Replaced 3 of the 4 ball joints on the truck, going to pick up a 4th tomorrow and just fkkin' change it since I need an alignment anyways. The wheel bearing is changed. Waiting til tomorrow to pick up the brake line I busted and pick up some metric line wrenches (fuckin' fucks) and get the truck done. Changed the master cylinder on the car, got things all bled out ready to rock n roll, and still have a squishy pedal. Rear brakes were out of adjustment, pulled the drums and the newish (<3000 miles) shoes are cracked almost the full length down the center (drag strip? I had cracked fronts too), so I've got those on the way. Noticed this spring on the first few outings I had a metallic grinding noise in the front of the car. Discovered today that it was the harmonic balancer rubbing on the timing cover. Made a phone call to our local engine zohan and he thinks the balancer is coming apart. Upon closer inspection I do see what appears to be a 'fresh' area of rubber around the outer ring of the balancer indicating that it's probably worked itself loose and is moving backward and off the center mass. Time for a new one! What...it's just money, right?
05-05-2015, 03:30 PM #43
Yep. Make more every day. Glad it's not something major, your text message scared me a bit.
05-05-2015, 05:00 PM #44
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
Very little sleep last night + Work today + double header softball games = no work on car
05-05-2015, 05:16 PM #45
I had grand plans to move cars around up at the building and unload the Corvette from the trailer... but they all ended up just being plans. Another night.
05-05-2015, 05:31 PM #46
And a cavity rears its ugly head, i can't win.
05-05-2015, 05:31 PM #47
- Aug 2007
- Corn and Soybean fields
Dog caught a crab walking the beach with me about an hour ago
05-06-2015, 02:40 AM #48
Our local election candidates will be debating this evening. Should be a good show.
05-06-2015, 04:04 AM #49
- Aug 2007
Mornin. Looking to see if more dolphins pass buy again this morning
05-06-2015, 05:05 AM #50
05-06-2015, 07:48 AM #51
Chicken of the Sea?
05-06-2015, 08:02 AM #52
05-06-2015, 08:42 AM #53
So I got my own place now. Just haven't moved yet. Since I'm stuck paying the last 3 months rent on my place with the roommate, should I be a crazy vindictive bitch to him? He continually pisses me off everyday.
05-06-2015, 01:13 PM #54
- Aug 2007
Itching powder in his underwear?m
05-06-2015, 03:24 PM #55
I need to know more before I can give you good advice. Is he staying after you leave? If so my suggestion would be 2-3 raw chicken thighs dropped down a couple upstairs registers the day you leave. I did that once at a apt I was moving out of that wouldn't give me back my deposit. Wonder which was cheaper? My deposit or paying someone to come in and try to figure out what the smell was then finding out where it was then tearing walls apart to get to the ducts? I'm not a math guy but I'm going to guess my deposit would've been the way to go for them.
05-06-2015, 04:21 PM #56
- Aug 2007
You had a wall damaging shrine to Sarge even then?
05-06-2015, 04:53 PM #57
Got the balancer pulled off the engine tonight. definitely was going to get real bad really quick.
and I completely rebuilt the rear brakes with new shoes and hardware. kinda needed it, 3 of the four shoes were cracked like this.
05-06-2015, 06:13 PM #58
- Apr 2011
- Johnstown,PA
Nice warm sunny day today, did a little grilling after work and then worked on transferring the brake hard lines over to the new rear had to completly re bend one side do a little reworking a bracket and installing the braided lines on the center housing.
05-07-2015, 03:10 AM #59
Zap - just ask Dawn, brakes are overrated... Lots of life left in those!
Good thing you caught the balancer going bad before it did some real damage. I sent the W-31 balancer out to California for an elastomer rebuild as it is a W-31 specific part.
05-07-2015, 03:10 AM #60
PerFormaBuilt MayDay SPECIAL
By performabuilt in forum Automatic TransmissionReplies: 1Last Post: 04-23-2013, 11:25 AM -
Ftw train
By 402 Guru in forum Almost Anything GoesReplies: 16Last Post: 12-16-2009, 11:50 AM -
Got on the PC train...
By 99'CajunFirehawk157 in forum Showcar and DetailingReplies: 20Last Post: 03-03-2008, 02:01 PM -
Mayday Mayday Ss Down
By cobra12345 in forum Manual TransmissionReplies: 1Last Post: 04-14-2006, 03:16 AM
