Thread: A/C Compressor - How to Jumper?
07-01-2014, 02:29 PM #1
I am working on the AC system in our '07 Suburban. Last night I was able to locate a leaking line to the rear AC unit after partially charging the system with refrigerant. While recharging, I attempted to jumper the low pressure switch on the drier and I still could not make the compressor engage. When I push the AC button on the HVAC panel, the light blinks a couple of times and then goes out. Is there something else I need to do to engage the compressor? The service manual is about useless on the recharging procedure.
07-03-2014, 05:36 PM #2
I received the rear block off kit this morning and will be attempting to get the system up and running tomorrow.
07-04-2014, 02:45 PM #3
- Jun 2011
- Branchville, NJ
What a shame that an 07 vehicle is having A/C trouble already. I hope the new systems are better engineered. BTW. I have a 1998 Jeep Cherokee with 262k and the A/C still works. I guess I'm one of the lucky ones.
07-04-2014, 02:50 PM #4
- Jun 2011
- Branchville, NJ
Jeff, these systems are still the old design and I do not believe the BCM has anything to do with the operation so that being said, did you check for 12v at the fuse, relay and clutch ?
07-04-2014, 04:13 PM #5
I'm not sure what the issue was. I installed the rear block off kit this morning, and then sucked it down to 26 inches of vacuum. It held that for an hour, so then I let the vacuum pump run for a good 35-40 minutes before charging it. Part way through the first can the compressor started working and with the second can going in I jumpered the low pressure switch and the compressor ran like it should. No clue why I couldn't make it spin the other day.
03-07-2015, 04:01 PM #6
Reviving this thread from last year -
Well, I have hope that the winter freeze will be departing and that the weather will eventually get warm again. As I prefer being cold rather than hot, working AC is a must in our daily drivers. After blocking off the rear A/C lines last year and recharging the system, I once again had cold air in our Suburban. The only issue is that I am now getting a "sucking" sound that seems to emanate from the passenger footwell whenever I run the A/C. The sound is regular and happens around every 30 seconds or so, lasting only about 2-3 seconds each time. It does this no matter what the setting on the HVAC panel, so long as the A/C is activated, and does not seem related to compressor engagement. Any clue?
03-07-2015, 05:31 PM #7
not sure if this really helps you much and I'm not real experienced with a/c stuff other than a basic charge but this link has some good info. Is it a gurgling sound? I've had that sound from a clogged condensation drain line which is in the same area you're hearing it. May want to fish a coat hanger up that line and see if it's clogged.
a/c link
Air Conditioner A/C Compressor Failure
03-08-2015, 10:22 AM #8
Darn good info, thanks!
06-23-2019, 01:51 PM #9
- Jun 2019
- US
Good info
Sent from my SM-G930V using Tapatalk
WH Fence-Jumper Supposedly Got Deep Inside the Mansion...
By wileyCoyote in forum Political / Debate ForumReplies: 16Last Post: 10-02-2014, 09:50 AM -
WTB: AC compressor for LS1
By deelli in forum Parts Wanted / TradeReplies: 2Last Post: 02-10-2009, 07:58 PM -
I had a jumper!!!
By blackSS01 in forum Almost Anything GoesReplies: 7Last Post: 01-04-2009, 06:35 AM -
Fs: Ac compressor for 01 ws6
By formergper in forum Rocky Mountain MembersReplies: 0Last Post: 09-07-2008, 06:54 PM -
AC Compressor!!!
By CWW17 in forum Parts Wanted / TradeReplies: 3Last Post: 09-06-2007, 12:56 PM
