Results 81 to 100 of 237
Thread: My build....421CI
03-28-2014, 07:08 PM #81
- Apr 2010
- Alabama
I have heard of Morel for a long time. They are one of the top lifter brands on the market other than Jesel but I wasn't about to spend spend 1k on lifters if it wasn't necessary. It was a matter of knowing I am getting good quality lifters from a known quantity vs buying cheaper ones. Plus I know several people who are running their stuff with good results. Also these particular lifters are have shown their performance and reliability over and over again. These ones have a .750" wheel which is nice. The interesting thing is apparently most guys are running around .090 preload with these to keep the lifters quiet but Morel recommends .045 to .050 preload.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
03-29-2014, 04:38 AM #82
Good to know. Thanks for the info!
04-10-2014, 03:59 PM #83
- Apr 2010
- Alabama
Some pictures of the wheels the came in today. I also received my rocker arm stands back from being polished.
04-15-2014, 05:02 AM #84
- Apr 2010
- Alabama
Bought my 4.03 Iron block from Summit!
04-15-2014, 05:06 AM #85
That's a great deal from Summit considering it's a new block machined and ready to go. They cost nearly that much from GM in standard bore configuration.
04-15-2014, 06:31 AM #86
Tell me if I'm correct FBJ, I told him to go ahead and have it clean again just to be sure it's done. But the question of CAM bearings? I believe they will need to be replaced after the cleaning correct?
Also he had a question of ARP Main Cap studs. I had mine check to ensure the main caps didn't need to be resized with the ARP studs, however I've also read that it's rare for ppl to need to resize the main caps. Mine didn't need it with it having 150k on the block and crank. I was able to use standard bearing sizes.
04-15-2014, 08:42 AM #87
On the cleaning, I always clean even after the machine shop does. I use a simple soap and water solution and wash it all down, and I'll also use small pipe cleaners to run through some oil passages just in case and then blow everything out with compressed air. All of this can be done with the cam bearings in place if they are already installed. I guess your only fear would be packing debri up behind the back side of the bearings oil passages, but probably not likely since I'm sure Summit already ran the block through the washer if they installed the bearings. Wouldn't hurt to ask when you buy for piece of mind.
On the mains, the very first thing a machine shop will do is make sure the mains are aligned and hone if necessary because all of the other machine work on the block is based off the mains. The cylinder boring procedure and decking are all based from the main journals, so if that's not square, then the rest of the machine work is wasted. On blocks like the LS platform (similar to the ford FE) with it's mains encased up above the pan rails with alot of support, I would expect that you wouldn't find mains out of alignment very often, but they should always be checked anyway, as any good machine shop would do.
04-15-2014, 09:15 AM #88
I think he's concern that when you install ARP studs for the mains will it take it "out of round" like what happens on the rods if you switch over to ARP bolts.
04-15-2014, 10:22 AM #89
- Apr 2010
- Alabama
Well Tick Performance said they could if needed machine for the arp main cap studs for $100. I'll still be under what a new lq9 with no .030 over bore costs from TSP even with that machining cost.
04-15-2014, 12:05 PM #90
04-15-2014, 12:22 PM #91
- Apr 2010
- Alabama
They already shipped it so...., doesn't really matter either way. The only other option for me would be to buy a new non bored block for more than this one so I don't really mind having to have additional machine work done to this one if needed.
04-18-2014, 04:15 PM #92
- Apr 2010
- Alabama
The block is scheduled for delivery on Monday since I am off and my wife won't have to figure out what to do with a 200 lb block .
04-21-2014, 09:13 AM #93
- Apr 2010
- Alabama
My block came in today as well and I will post pictures once I get it out of the crate.
04-21-2014, 10:57 AM #94
- Apr 2010
- Alabama
The block, I'll post more pictures later.
04-26-2014, 04:18 PM #95
- Apr 2010
- Alabama
ARP head studs have arrived.
04-26-2014, 11:46 PM #96
- Apr 2010
- Alabama
As promised here are more pictures of the 4.03" bore block from Summit. The block is so clean you could eat off of it lol.
05-30-2014, 11:15 AM #97
- Apr 2010
- Alabama
So all my tires are in. I am going to get them mounted this weekend hopefully if I have time. I will be running 275 35 18 in the front and 335 30 18 in the rear. The tires are BF Goodrich KDWs. I will post up pictures later.
06-08-2014, 06:04 AM #98
- Apr 2010
- Alabama
I ordered a Walbro 450 lph fuel pump which should be here Tuesday.
06-08-2014, 06:32 AM #99
Looking good.
06-09-2014, 12:29 PM #100
- Apr 2010
- Alabama
Well the fuel pump arrived!
78 LS1 TA build
By reedld in forum LSx Retrofit and SwapReplies: 6Last Post: 07-11-2014, 06:41 PM -
440 LSX build
By cam02ss in forum Camaro / SSReplies: 9Last Post: 07-01-2013, 03:55 AM -
78 LS1 TA build
By reedld in forum Classic MuscleReplies: 2Last Post: 04-23-2013, 07:40 PM -
500CI Chevy LS1 Engine Build - How To Build A 500C
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 02-17-2009, 07:10 PM -
I want to build up the .....
By clg82 in forum DrivetrainReplies: 8Last Post: 09-01-2007, 11:06 AM
