Results 61 to 80 of 731
Thread: My 6 Liter 403ci Build
06-01-2013, 05:20 PM #61
Underside of our K-member and the rack was oiled up fairly good. Thought for sure mine was leaking, but after cleaning it all up and running the car for 2 years, she is still clean and dry. Had to be the pan gasket leak that junked up the rack.
Don't forget to take pics as you go, please.
06-02-2013, 04:47 AM #62
I'm pretty sure it's the r&p. I constantly had to add fluid to the PS pump. I know it wasn't leaking from there or the hoses because I had already changed them out.
06-02-2013, 06:13 AM #63
- Dec 2005
- Laurel, Maryland
^ This is why I went to a manual rack.
06-02-2013, 06:44 AM #64
Those cost an arm & leg
06-03-2013, 08:49 AM #65
Sold the LS1 intake, so I'm able to get this.
LS1 alternator relocation bracket kit
Relocates the Alternator to the passenger head where the EGR used to be. No more PS Pump leaks killing my alternator
I know it's a little pricey for most, but after paying for 2 alternators in a yr I got feed up.
06-03-2013, 01:40 PM #66
Received the BTR Lifters
and my replacement LS2 pistons (2 were damaged in shipping)
06-04-2013, 06:21 AM #67
- Apr 2010
- Alabama
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
06-04-2013, 06:43 AM #68
More goodies....
Here is the LS1 relocation kit
06-04-2013, 06:52 AM #69
If you looked at the pics on that link I don't think it will remove as much as you think, The EGR for such a small part took a ton of room.
I just realized that my catch can will need to be relocated to another spot. I had it sitting in the same spot that this is going to.
If/when I swap to a truck alternator I will need to clock the oil fill tube in order to clear the larger alternator.
Another bonus is I don't have to worry about drilling/tap the block to fit the alternator anymore.
Also if you are going to do a turbo build you'll need to do this. The turbo guys use truck exhaust heads and flip the exit towards the front. When you do this the alternator is now in the way.
06-04-2013, 07:00 AM #70
06-04-2013, 07:06 AM #71
oh I will post pics....
It's too hot down here to run with A/C
06-04-2013, 07:13 AM #72
06-10-2013, 08:02 AM #73
Last of the gaskets are in (-) head gaskets (those I'll order after I get back from the shop.
06-10-2013, 03:06 PM #74
Don't forget to toss an unrecognizeable chunk of metal into the oil pan for good measure.
06-10-2013, 05:28 PM #75
I think you mean the arp rod bolts in the pic, horrible lighting when I took the pics, hard to believe it was 10am when I took that. Rain clouds so damn dark it blocked the sun out.
Had my son help me drill out the rivets on the engine mounts so we could paint them.
Comparison between factory and poly mounts (Energy Suspension)
Had no issues getting the rubber out, it fell apart once the rivets were gone. Makes me think how much longer these would have held up. I don't remember the block shifting around.
I have to say I'm having fun teaching my son these little things. Whether he knows it or not it's going to help him later. on.
06-10-2013, 06:32 PM #76
Totally agree with your last statement.
06-14-2013, 12:35 PM #77
pulled the trigger on a (98) Racetronix Fuel Pump & wire harness kit.
just need to find 42lb injectors...
06-14-2013, 06:58 PM #78
Rewired the Alternator wire (to the PCM) from the drivers side to the passenger side along the fuel rail wire loom. This is prep for moving the alternator to the passenger head.
Does anyone know where I can get another one of these. I showed the local parts ppl and I got a deer in the headlights look.
I also cleaned up the k member some and look there's a rack & pinion......couldn't see it before under all the grim.
Now I have a dilemma....The high pressure hose at the r&p was loose, I mean very loose. I know I checked in the past and it was tight. Now I'm wondering if this is the leak? If I leave it then I have the nightmare of trying to fix it with the block over it. What to do? :
06-15-2013, 10:51 AM #79
Check Caspers Electronics - they have all sorts of connectors and such.
06-15-2013, 02:18 PM #80
- Oct 2008
- Coral Springs, Fl
Check local junkyards in your area if you can't find one, its a standard GM plug you can find on most smaller cars. I picked up a spare just in case i ever break mine.
which gaskets to get for my 6 liter build?
By SMWS6TA in forum General HelpReplies: 2Last Post: 06-28-2013, 11:37 AM -
87 442, NJ, 403ci, built trans, $8k in receipts
By ShadowHawk in forum Vehicles For Sale / TradeReplies: 2Last Post: 09-19-2010, 02:34 PM -
87 442, 403ci, built 200R4, with receipts, $4500,
By ShadowHawk in forum Vehicles For Sale / TradeReplies: 0Last Post: 08-18-2009, 12:18 PM -
V-6 3.8 Liter Ram Air?
By Maro99 in forum External EngineReplies: 1Last Post: 06-23-2006, 05:28 AM -
GM 8.0 liter's Who has them?
By Blown25thT/A in forum GM TrucksReplies: 18Last Post: 03-30-2006, 07:49 PM
