Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 84
  1. #21
    SATX
    2000 Trans Am
    Quote Originally Posted by breakparts View Post
    No Way Gm Wont Cover The Warranty On Your Rearend There Asses About The Rearends,unless Stock Like F1 Tires And Your Original Size Wheels Are On It.and Not Bald..also They Can Check Your Computer For Your Last Rpm Shifts So They Can Usually Tell You Beat It Up ,and They Will Do Anything To Make You Look At Fault...iv Been There But If Its Bone Stock And Making Noises But Still Driveable Mabey And Thats A Mabey...and Once 1 Dealership Denies You Then The Rest Will Be Notified...and If You Brought It To The Dealership To Get It Checked And They Denie You Be Prepared To Pay For Inspection And Reassembly...assholes They Are..and We Pay Extra For Nothing
    True that man!!!
    Last year my mom's suburban had a humming noise on it, turned out that the diff. had a couplbe of pinion gears broken in it. the total cost to fix it was 5,000, however she still had waranty... so this happened dec 1 2006 that didnt get fixed till dec 22 2006, but the warranty company was trying to blame fault on her, so a couple of guys from the company came and took pictrues and all that nonsence. bottom line its a headache better be safe than sorry.
  2. #22
    brooklyn,ny
    blue
    1998 b4c
    Im upgrading to 3:73 in my 10-bolt will the reluctor gear from the 3:42 work or can I get one for an S-10 ?? if so then which year S-10 any input you have will be greatly apprieciated Ive been reasearching this for a month no answers-Bill
  3. #23
    Fort Worth, TX
    04 Short Bed Chev Trk
    8.5" 10 bolt
    on a second note the 8.5" 10 bolts hold up under a lot of HP, and have seen sub 8 second passes several times over. that is another way to get a great rear for a lot less price if your willing to take the time and have it narrowed.
    Zboner, question? to have the 10 bolt narrowed, what does this mean?
    I have a 8.5" 10 bolt 3.73 gears in my 04 5.3 Chevy short bed P/U. I want to go with 4.10 ring and pinion instead to get better eight of mile performance.
    What do you think. D.Rigsby, N. Texas.
  4. #24
    in my Trans Am
    2000 Trans Am WS6
    guys i think my stock diff went to shit today, horrible grinding and clunking.....what the hell do i do!!?? Do i have to drop 3000 to get whole new rear? or can I upgrade the gears or something and have that installed?? I am seriously F-ed here. Need some good advice quickly thanks for your time
  5. #25
    Member intheclouds1977's Avatar
    QC Illinois
    2000 WS6 M6
    Spending $3k on any rear end is retarded. You can buy 10-bolts from junk yards for under $100 and bolt a 'new' one in.
  6. #26
    Quote Originally Posted by intheclouds1977 View Post
    When the rearend blows, there is a good chance it will take your tranny with it. I have seen it happen many times. My best friend had his stock 10 bolt blow at the track, it took his built 4l60E and 4000 stall with it. Very costly disaster for my friend. I would get tired of swapping 10 bolts after 1 or 2 times myself. I will gladly buy a real rearend instead of sticking junk 10 bolts back under my Camaro.
    Painted manta stripe
  7. #27
    QC Illinois
    2000 WS6 M6
    I'm not advocating bolting in another 10-bolt...but spending $100 for a junk yard one is a lot smarter than spending $3k to rebuild your stock 10-bolt back to stock.
  8. #28
    Junior Member Kevin hayes's Avatar
    Dallas,TX
    99 camaro z28
    today! look for 12 bolt
  9. #29
    Dallas,TX
    99 camaro z28
    450 junk yard , go with 12 bolt or 9
  10. #30
    Junior Member 99CANADAHAWK's Avatar
    GTA Ontario Canada
    1999 Trans Am FIREHAWK
    What if I buy a diff cover for the 10 bolt for now , will that help the rear untill I can afford a 12 bolt ?
  11. #31
    The covers help some, but you can still easily grenade a 10 bolt even with the cover.
  12. #32
    Member jujofields's Avatar
    Lafayette, Indiana
    Pewter Metallic
    2002 Trans Am WS.6
    What cover do you recommend? I'm in the same situation; don't have the extra $$$$ yet to get a 12 or a 9, so I'd like to at least strengthen the stock 10 as much as possible until I can swap it out....
  13. #33
    Quote Originally Posted by jujofields View Post
    http://www.thunderracing.com/catalog...vid=3&pcid=210
    I have been using that one for 2.5 years now and been pleased with it.
  14. #34
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    The cover will help keep the pieces in better too once it blows. I've had a bolt off a ring gear puncture a rear cover already. That was a GM 12 bolt with a chrome cover though. That was also a truck with a 454 BB with about 500HP and big grippy tires.
  15. #35
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Quote Originally Posted by Eagle View Post
    GM CORPORATE 10-BOLT
    This 10-bolt, with a 8 1/2-inch ring gear diameter.
    GM CORPORATE 12-BOLT
    The stronger 12-bolt, with an 8 7/8-inch-diameter ring gear diameter.
    Yes, the bolt count is associated with the cover, not the ring itself.
    -Eagle
    I WISH GM put the 8.5" 10 bolt in these cars. Then the whole rear end would be an issue for 99% of us. We got stuck with the 7.5" 10 bolt
  16. #36
    GTA Ontario Canada
    Is a Stronger 10 Bolt Possible ?
    I have a whining noise comming from my rear when I`m on the gas & doing about 80 - 100 KPH I don`t have enough money now to replace with a 12 bolt or equivalant . Now I know that the 10 bolt is crap but if I replace everything like stronger axles, a diff cover & say an Eaton Posi that should hold up allot better right ? I don`t intended to drag my car and I don`t plan on making anymore than say 450 HP on motor .
    It`s only a weekend car I`am the eleventh owner of the car so I`m guessing it may have been hammerd on a bit in the past . So as far as parts go it`s about $1,200 - 1,500 CND compared to $4,000 for a 12 bolt .
    Any Opinion`s other than the obvious ( the 10 bolt is crap )
    Thanks .
  17. #37
    Madison, WI
    2001 Silverado Z71
    Whining could be shot side bearings, which would be cheap and easy to replace. Otherwise I'm not at all opposed to beefing up a 7.5" 10 bolt a little bit. I'd say a eaton posi and support cover are as far as I would go. Skip the axles.
  18. #38
    GTA Ontario Canada
    Thanks Cutlass I`m not too shure what the noise / vibration is yet but I hope it`s something as simple as that , I forgot to mention that my car is an A4 with a Torsen diff & I have not heard too many good things about the Torsen .
  19. #39
    Junior Member epmedia's Avatar
    May 2008
    Spring Valley, CA
    Grey?
    78 BMW 320i with mods
    A ten bolt may break when you burn rubber in reverse, up hill (post by experience).
    You may be able to get by for a few months by pulling the cover and flushing all the metal bits out of the case and bearings. Bearings are tough. You probably just lost a few tooth-ends. A quiuck-temporary fix is what I mentioned above (hopefully for you).
    Good Luck ).
  20. #40
    Domestics>Everything DOHC Cobra's Avatar
    Florida
    2004 Mustang Cobra
    I was told that Ford rear ends would fit, is that true?
  1. How To Break a 10-Bolt
    By Naaman in forum Drivetrain
    Last Post: 10-24-2015, 05:50 PM
  2. Engine Break-In Guide - Break-In Without Breakin'
    Last Post: 03-17-2011, 09:40 AM
  3. check out this break dancer break
    Last Post: 02-23-2009, 09:20 PM
  4. Center bolt to Perimeter bolt Heads, Coil Mounting help
    By juiced99ws6 in forum Internal Engine
    Last Post: 03-30-2007, 11:38 PM
