Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21
    I agree on the headliner....call some places. I just can't see that being a very expensive fix to just take it to a pro and have it done. I've never had any dealings with CPAP either.....I just know they're the go to guys for late model GTO parts. Like cammed said too.....keep your eyes out at ebay or the gto boards for someone parting one out. Honestly....I would sweat a fender liner too much so you have time to just keep an eye out at places. Hell....I purposely cut mine on the truck so the tires would clear
  2. #22
    DFW
    '18 CTS-V
    '13 ZL1
    Ok guys, reporting back on a couple of things with the GTO.
    First, picked up stock 17" wheels w/tires, lug nuts and caps for $475 shipped off ebay a little while back. I went in for a 4-wheel alignment and found the front caster was off well over 1°. The tech said I needed to look into some new front bushings (ill grab a pic of what he pointed too).
    Steering, every now and then I get a clunking sound and feel it through the steering column. its this the strut rub or do I have some greater force at work?
    So anyone have any thoughts? Thanks!
    Aside from an exhaust leak, and having to put a new radiator in the car, I'm happy to report no issues after 6000 miles from driving. Makes the daily commute fun again.
  3. #23
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Radius rod bushings could be split. If you want good polyurethane bushings on the cheap, go for whiteline adjustable radius rod bushings. They are poly with, I think, nickel plated steel plates. I run them and they are great. As for the clunking of the steering, check your inner/outer tie rods for looseness. Could also be a loose steering shaft coupler or worn swaybar bushings.
    The aftermarket for the modern goat seems to keep growing.
  4. #24
    DFW
    '18 CTS-V
    '13 ZL1
    Goat, here is a picture (sourced not of my car) but yes, I believe you are correct. As for tie rods I will look into those. I have been looking at Pedders, however I will do research on the "whiteline" you have mentioned above. I don't need anything to crazy since it's just a DD, but it would be great to resolve some of these 'noises'.
    As for a loosened steering shaft, or swaybars, I will look into those as well. I honestly have no clue if the 19" wheels that were on the car when I purchased it might have done anything to mess with all that or not.
    Thanks for the advice!
  5. #25
    North Jersey
    2004 GTO M6
    Yup. Those be the radius rod bushings. Glad to help.
  6. #26
    DFW
    '18 CTS-V
    '13 ZL1
    Replaced the Radius Rod Bushings in about 30 minutes around a month back with Whiteline Adjustable ones. I set them at +1/2° caster. Also mounted new tires and a full alignment done. It's made a huge difference and nice ride improvement as well.
    The TSW wheels are for sale. I will be posting a thread soon once I get pics with my handle and date taken.
  7. #27
    North Jersey
    2004 GTO M6
    Picked up an '04 GTO
    Whitelines kick ass!!
  8. #28
    DFW
    '18 CTS-V
    '13 ZL1
    GTO is sold...should be welcoming a 1,800 mile logged, 2012 Camaro SS 1SS (Silver/ Blk int/ 6spd) home no later than the end of this week.
    The GTO served me as a great car from 66,000-109,000 miles. Only needing a battery, a set of tires (BF Goodrich Comp 2 A/S (fantastic tires by the way), Radius Rod Bushings, and a couple headlight bulbs. It will be missed, but the move up from a 12 year old car to only a 4 year old car with less than 1,800 miles was simply to good to pass up.
    I received numerous compliments and comments towards the GTO. Solid car all around.
    2013 ZL1: °°590rwhp/576rwtq°°
  9. #29
    North Jersey
    2004 GTO M6
    Congrats. I'm still loving my GTO almost nine years later and I'm still getting compliments.
  1. Picked up my 00 ls1 ws6.
    By luvmy00ls1pwrd in forum Member's Rides
    Last Post: 02-13-2012, 02:05 PM
  2. just picked one up :)
    By oldschoolmx in forum GTO
    Last Post: 08-13-2011, 03:08 PM
  3. just picked up....
    By tigersport14 in forum Almost Anything Goes
    Last Post: 07-15-2008, 07:14 AM
  4. picked up my 02 ss but
    By 2000 ss in forum General Help
    Last Post: 01-14-2007, 12:00 PM
  5. Picked up a Z06
    By Z06-Goose in forum Rocky Mountain Members
    Last Post: 12-30-2005, 10:32 AM
