Results 1 to 18 of 18
Thread: Mightyvac vs HF
    Member 2000dreambird's Avatar
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    Mightyvac vs HF
    does anyone know if the Harbor freight pump is better or worst than the Mightyvac?
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    seriously? no one has input on this?
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Worse I would assume.
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    after reading lots of reviews on the two of them it seems like the biggest problem with the mighty vac is that its made of plastic. however it doesn't seem to break often. the harbor freight one, even though its mostly metal it seems to be poor construction, fails often, and the pump stroke seems to be less then it should be to achieve a usable vacuum.
    Needless to say i went with the mighty vac.
    Junior Member Rfyler's Avatar
    Oct 2011
    Chico, CA
    2002 Camaro 35th LE
    All Harbour Frt tools are Junk! Buy good quality tools and you will be better served! You get what you pay for......
    phoenix
    04 2500 4x4 crew cab
    Quote Originally Posted by Rfyler View Post
    I agree. Look over any tools you get from there VERY carefully, and if it's over $50, get the warranty. The only tools I buy from there are ones I plan on using a few times.
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    I went with the mightyvac. Glad I did too because my buddy bought the HF one and then called me to come over with mine after he broke his.
    phoenix
    Looks like some one brought this back from the dead. Thanks for the return input. Mity Vac FTW!
    Nov 2012
    Roanoke, VA
    Sebring Silver
    2000 Trans Am
    I got a HF one for Christmas one year, IT NEVER WORKED! Big bulky cast stuff might be ok, other stuff from there is likely crap!
    Harbor Freight= Chinese Store
    Nov 2012
    Roanoke, VA
    Sebring Silver
    2000 Trans Am
    Opps, just saw how old this thread was.
    Coral Springs, Fl
    Sunset Orange Metalic
    Old or not there is a metal mity vac
    Coral Springs, Fl
    figured if throw that out there
    Indianapolis
    2000 WS6 6spd Hooker LT
    Shit I'm old. My Mity Vac is made from cast aluminum. Worked ok back in the day, I quit using it about 10 years ago.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Stay away from Harror Freight unless you need a "one time" tool. Go with Mightyvac all day long.
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    I did end up going with the Mighty Vac, and honestly its a waste of time. none of the attachments seal well, and there is always a leak somewhere. It honestly seemed like a waste of time and i ended up just going old school with it and pumping the pedal....
    My Mity-Vac (plastic version) works just fine -- have used on a regular basis for years now.
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    it has potential, i just need to get the fittings to seal right. At the time i was trying to use it it was like 101 out and i just wanted to get shit done.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    My MityVac was something like bucks shipped. Your trying to go cheaper then that? At some point the money saved equals a Wednesday cheeseburger or something and you're left with uncertainty about the tools lifespan.
