Results 1 to 10 of 10
06-24-2011, 01:46 PM #1
How to check if you have a bad starter
Hello everyone. I seen too many issues with starters lately so I decided to make this write up in order to help some members figure out if the starter is the problem.
You will need a voltmeter or 12v test light.
This is very important. Before you begin you need to make sure that the "security light" in the cluster is NOT FLASHING. If the light is flashing this procedure can not be followed until that issue is resolved 1st. The flashing "security light" indicates that you are having an issue with VATS. This will prevent the starter and fuel pump from working. Follow the steps in this link from the tech stickies to resolve the flashing "security light" BEFORE you continue.
http://www.ls1.com/forums/showthread.php?t=61262
If your security light is off then continue reading.
Jack the car up on the passenger side at least. Put some jack stands(safety
1st). Now look underneath the engine for the starter, is on the passenger side of the engine.
Now this might be alittle tricky becuase the solenoid of the starter is on the top. There's a few tests you can do to find out if the starter is bad.
Use this pic as reference:
1. Grab your voltmeter/test light and connect one lead to ground. Grab the other lead and touch the big red starter wire(from the battery) your test light should light up or your voltmeter will show 12v. This tells us that you have a good ground to continue with the test.
Now leave the lead on the ground (that you have found), use the other lead and connect to the smaller wire on top of the solenoid. You will need someone to get in the car and turn the ignition switch to the "start" position like they are trying to crank the car. You should see the test light lit up or 12v on the voltmeter. This tells us the electrical part from the ignition switch all the way to the starter is working fine.
If the small wire has 12v when you turn the key to start position the starter is bad and needs to be replaced.
2. If you are not getting 12v on the small wire then your starter relay could be bad. A quick way to do that is to swap the starter relay with the one of the fan's relays(they are the same). The relays are located in the boxes on the engine bay towards the driver's side.
Pull the covers off:
Here is the location of the relays: (purple is the fan relays)
I don't advise you to drive the car without one of the fan relays. If the auto parts is close then keep an eye on the temp and make the trip. If you can get the relay without driving the car even better.
If you are having issues after swaping the relay it's posible that you have an open wire between the relay and the starter, an open wire from the ignition switch and the starter relay(not to be confused with the ignition cylinder key) or a bad ignition switch.
I hope this help. Thanks for reading.Last edited by JayTA98; 06-25-2011 at 09:14 AM.
06-24-2011, 02:48 PM #2
let me know what you guys think and if i miss anything. Thanks.
06-24-2011, 02:55 PM #3
vote sticky!!!!
06-24-2011, 03:14 PM #4
Updated please check for any other revisions. thanks.
06-24-2011, 03:16 PM #5
06-24-2011, 03:53 PM #6
06-24-2011, 03:57 PM #7
06-25-2011, 07:47 AM #8
- Mar 2010
- St Pete, FL
Bat mobile black- 2000 Trans am WS6 M6
wish you would of did this before my post LOL
06-25-2011, 09:13 AM #9
06-25-2011, 09:22 AM #10
I Sticky myself. Thanks to Smittro for quality control.
Help: starter
By dzikusnj in forum Firebird / WS6Replies: 5Last Post: 06-23-2014, 08:48 AM -
For Sale: ls1 new starter
By 98maro in forum Parts For Sale / TradeReplies: 2Last Post: 03-18-2011, 07:36 AM -
Help: New starter
By Adam_94_T/A in forum Firebird / WS6Replies: 10Last Post: 02-15-2011, 08:16 PM -
is my starter bad?
By Zboner in forum External EngineReplies: 11Last Post: 07-08-2009, 04:07 AM -
Desks - check, phones - check, Cuban Flag with pic of Che - check
By dock in forum Political / Debate ForumReplies: 5Last Post: 02-13-2008, 06:30 AM
