Results 5,421 to 5,440 of 7102
01-17-2017, 03:19 AM #5421
My TA went out for a little cruise yesterday after taking a 3 month nap. The roads are fairly clear here and the weather was absolutely perfect. Poured in a few ounces of "stabil" at the end of the cruise and put her to rest until March-April. Now I just need to get back to work on the GN and get it road worthy.
1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
01-17-2017, 05:58 AM #5422
Went from this 19 yr old "nasty" carpet
too....
(Please ignore the ripples, I took this before I spent 2 hrs smoothing them out. What a bitch to do.)
More pics here http://www.ls1.com/forums/f36/bird-h...1/#post2960558Last edited by SMWS6TA; 01-18-2017 at 05:55 AM.
01-17-2017, 06:02 AM #5423
Ran into some car guys last night who are in a car club. The one guy started asking me about my car then talked about wanting to race. He has an older NOVA and it sounded very quick. Sounds like I'm being set up lol.
Sent from my SM-G900V using TapatalkBoost gets you laid, unless your name is Jon.
01-17-2017, 12:39 PM #5424
uh-oh... painful shock flashback... is that the over-the-hump airhose for power lumbar/lateral balloons?! I came near giving self a heart attack one cold night in my office's garage trying to stretch that thing back onto its coupling after being off for a decade I guess! At least I made the security guys laugh on the closed circuit t.v. !
01-18-2017, 03:57 AM #5425
Hey Jon, they arent from Oaklahoma are they? I hope it isn't an old guy and a younger Asian guy! LOL
01-18-2017, 04:42 AM #5426
Lol. Right! Seriously though, I can beat a higher HP car from a dig if he doesn't hook like I do. He was talking about roll racing. I'm sure he's spraying. He didn't talk much about his car lol. Said just a mere $100 race.
01-21-2017, 10:48 PM #5427
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
01-21-2017, 11:11 PM #5428
- Apr 2010
- Alabama
If it's a mustang easy you can run faster than their car can go before it breaks down...or crashes into a crowd.
Sent from my HTC6535LVW using Tapatalk1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
01-22-2017, 06:47 AM #54292000 Trans Am WS.6 M6
SLP lid & bellow w/ K&N, GMMG catback w/ Corsa Clones, UMI SFC, UMI Adj. Panhard, UMI Adj. TQ arm w/ relocation kit, QTP Longtube headers ORY, LS6 intake, EGR/A.I.R delete.
Eibach prokit, Bilstein HDs, Nitto NT555s, skip shift elim, whiteface overlays, 20% tint, matte black decal/overlays
YouTube.com/DarrenWS6
01-22-2017, 07:59 AM #5430
Car is THAT fast, duh lol
01-28-2017, 06:19 AM #5431
- Mar 2011
- fort myers,fl
black- 1998 trans am convertible
HIT 270,000 miles yesterday. it's amazing what a little love and regular maintenance will do. thanks to all who provided advice on ls1.com. i am grateful.
01-28-2017, 06:22 AM #5432
^^ That is awesome! Congrats!
01-28-2017, 08:29 AM #5433'02 Black RamAir M6--Kooks LTH, Magnaflo, Lowered Eibach springs and Bilstien shocks, Tuned By Frost, K&N & SLP box, Smooth bellows, polished TB, Spohn perf. suspension, shock tower brace. UMI 3point SFC. Front & side splitters w/ canards. American Racing 18" wheels & Mich. Pilot SS titres
'76 LagunaS3 - 355ci , 350 turbo, 3:55's
01-29-2017, 07:30 AM #5434
- Mar 2011
- fort myers,fl
02-02-2017, 12:12 PM #5435
So while I'm laid up I decided to finish up my doors with the heat & sound deadner.
I need to add a couple of more strips to the drivers door but I'll wait till I pull the panels off to change out for new material on the inserts when it comes in. I had to make sure I had enough to finish the passenger side so that is why it has more then the drivers side on the inside.
Music sounds so much better now, even at idle. I gotta wait till I can drive it again to see how much road noise it cut down.
02-02-2017, 01:11 PM #5436
Looks like a puzzle!
02-15-2017, 06:06 AM #5437
Found my coolant temp issue, one of the coolant fans died. Waiting on replacement.
02-17-2017, 03:13 PM #5438
At least that is a semi-easy fix.
02-17-2017, 08:47 PM #5439
Swapped the fan motor and hooked it all up again. Waited till it got hot enough and then...nothing....grrr..
Swapped the relays around and found fan 3 was dead. Looks like when the motor died it took the relay as well. Picked up one but had to bring the relay inside with me. Parts stores no longer can "get" the relays under radiator fan relays. I had to cross-reference it to the ac blower fan relay to get one.
02-20-2017, 05:20 AM #5440
- Aug 2016
- oceanside
Silver- 2002 T/A Ws6 convertible
Installed my new Borla cat back exhaust! Not quite finished and now wondering if I should replace the Y pipe too. That flat looking thing under the car looks like crap but don't know if there would be clearance issues with the SLP pipe and if I install lowering springs. Ah, decisions decisions
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
