Results 5,301 to 5,320 of 7102
10-17-2016, 09:22 PM #5301
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
Lol yup it's sitting next to me in my office in pieces. Sarah has been bitching at me to get it back together since she hasnt been able to ride with me when i drive it.
Started recovering it and had some issues. Had to send some stuff out to get fixed got it all back. Leather is back on but it sat so long disassembled that I forgot how one of the brackets go back on. Just haven't gotten around to looking it up since I can't find it anywhere in the repair manuals.Mods - Lid, Skip Shift Eliminator, MGW shifter, UMI SFCs, Founders Lower Control Arms, Founders Panhard Bar, Founders Adj. Torque Arm, UMI Torque arm mount, MWC Drive shaft safety loop, KONI Yellows, Strano Springs, Strano Sway bars, UMI Upper and lower A Arms, 160 thermostat, TSP headers and TSP true duals Monster stage 2 clutch, racetronix fuel pump, Strange S60 rear axle and tune by Frost.
10-18-2016, 10:33 AM #5302
That's 1 of the problems of ordering parts AFTER disassembly happens. When it takes several months to get back to said project, some things begin to look very unfamiliar. I took apart my 87 GN door to install new weather strips about 2 months ago, and now getting ready to start the re-installing process. Most of the time its pretty straight forward, but once in awhile I find a part that isn't as easy to figure out. So far so good though.
1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
10-18-2016, 04:10 PM #5303
Hell, some of the cars I take apart stay in pieces for years at a time.
10-18-2016, 06:31 PM #5304
My car has been apart for 4 months now. Don't really even care anymore.
Sent from my SM-G900V using TapatalkBoost gets you laid, unless your name is Jon.
10-19-2016, 05:59 AM #5305
vehicles apart for months.....
Try for 3 yrs. But seriously, as long as you tag, bag and make detailed notes & take pictures, keep all related parts in the same container/location you should be fine. After having my car apart for almost 3 yrs, several engine pulls to my amazement I still had all the parts and bolts.
10-25-2016, 07:04 AM #5306
Jay Leno said all sports cars should have a white-ball Hurst shifter-ball.... so I better unpack the one i ordered and muscle the very nice 30th Ann. factory leather "H" one off my stick.
p.s. that pic is one I saw on Show usyour Birds thread.... not mine as I have white seats and haven't put the ball on yet. :-)Last edited by BobbyGFirebird; 10-25-2016 at 07:41 AM.
10-25-2016, 07:15 AM #5307
Not done yet...but got the front bird license plate insert coming finally. Will need paint, but hated that indented portion
2001 Trans Am Vert
10-28-2016, 06:20 AM #5308
Had mine out today and got her in the air for a long awaited oil change.
After reading up on it there were many differing thoughts on amount but
i opted for 5 1/2 quarts. Seems ok.... No leaks and the motor has not seized
up so all good!
I put two replacement Falkens on the front also and the handling is soooo much better.
The Yokohama which came off were ten years old! Yeah..... i know!!
10-29-2016, 01:54 AM #5309
5-1/2 qts. is what I always go with. I need tires for our car - the Falkens currently on it wore out the centers bad no matter what I did with air pressure. A neighbor runs identical tires on his Corvette and has the same issue.
10-29-2016, 02:03 AM #5310
- Apr 2010
- Alabama
My oil changes are becoming expensive I now need 8 quarts of oil lol
Sent from my HTC6535LVW using Tapatalk1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
10-29-2016, 02:10 AM #5311
That's what you get for installing a diesel in that thing!
10-29-2016, 02:20 AM #5312
- Apr 2010
- Alabama
10-29-2016, 05:38 PM #5313
I'm running 6 quarts in mine (still 346 ci).
Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
10-29-2016, 08:28 PM #5314
- Aug 2007
- Greensboro, NC
Gave it a rinse less wash and went to start it up..... and dead battery. Had to drive the daily. Guess I need to drive it more. Oh well maybe jump it and get it going after the football game tomorrow.
10-31-2016, 04:34 AM #5315
- Aug 2016
- Merrick,NY
- 2001 WS6
Put the bird on
Sent from my iPhone using Tapatalk
11-04-2016, 07:37 AM #5316
Last night got the front plate insert on, deleted the AIR system, new plugs and wires, changed the oil.
Today i paid for my Frost tune
11-04-2016, 10:48 AM #5317
Serious bath, oil change and possible plug change this weekend on the bird. Gotta see how they've held up since the tune in Apr. I've also gotta replace my sons front calibers on his Grand Prix GT.
11-04-2016, 03:49 PM #5318
- Aug 2016
- Merrick,NY
- 2001 WS6
Adjusted my headlight cover
11-07-2016, 04:54 AM #5319
Added a couple washers to the AIR blockoff plates. With stock bolts the driver side was not tight enough for a full seal
11-07-2016, 06:15 AM #5320
Spark plug change was definitely needed. #7 plug was cracked. My mpg came back. Which is kinda funny with a 403ci going thru a 8.8 w/4.10 gears.
Also no debris in the oil, this was a 20k mile oil change after rebuild. It's still clean.....
Next oil change I'll switch over to synthetic.
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
