Results 4,661 to 4,680 of 7102
02-20-2016, 09:53 PM #4661
02-21-2016, 12:08 AM #4662
Interesting..... I know this may be a bit of a blanket statement but isn't it "what most people do"
when they do a tune after some mods?? Just delete them from the tune?
That is to say, "all" that the rear O2's do is tell the car that the cats are working?! and that the front ones
are the essential ones for the correct running of the car?
02-21-2016, 01:15 AM #4663
02-21-2016, 11:29 AM #4664
Speaking of no cats.... when I my headers and duals installed, I eliminated my cats and had them tuned out ( along with the AIR system too). I love the sound and what feels like a few HP's too BUT the smell of the exhaust is very pungent w/o them. And not even the 'good' smell that you get with the older cars. Has anyone else noticed that with their cats eliminated?? ....not bad enough the reinstall them ,, just sayin' !
'02 Black RamAir M6--Kooks LTH, Magnaflo, Lowered Eibach springs and Bilstien shocks, Tuned By Frost, K&N & SLP box, Smooth bellows, polished TB, Spohn perf. suspension, shock tower brace. UMI 3point SFC. Front & side splitters w/ canards. American Racing 18" wheels & Mich. Pilot SS titres
'76 LagunaS3 - 355ci , 350 turbo, 3:55's
02-21-2016, 02:57 PM #4665
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
If I sit at a light too long with windows down it can get rough but otherwise I don't notice the smell too often. But that could be me just being used to it.
02-22-2016, 04:22 AM #4666
Yes, I smell the smell of cats being deleted. I believe it's the carbon burning. It isn't pleasant, but I love the fact that it's 2 less sensors I no longer worry about going bad and setting an SES light. Also the added sound and power of less restriction is a plus.
1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
02-22-2016, 04:23 PM #4667
I'm now a CONTRIBUTOR, and I bought some LS! bling too ! Very appreciative to you guys and gals for the last 6 months advice.
02-23-2016, 02:24 PM #4668
You should take a ride out to Carlisle in June and join us at the GM Nationals. Always a good time!
02-23-2016, 05:11 PM #4669
02-24-2016, 12:06 PM #4670
so, my almost last "UNKNOWN" thing on the "new used '99 TransAm. Does anybody know if there is SUPPOSED to be a little black wire with a connector or fuse (???) coming off the back-right side of driver seat and going into the floor right near the seat support? It has sort of an after-market look, and I can't believe GM would have placed it so vulnerable to rear passenger's feet? Is it simply the wire for seat-pressure-sensor?
p.s. do any of you guys carry a spare GM PassKey2 key if one fails? Other words, do these keys lose their resistance, or they only go bad if the chip loosens, or falls out? Can I get a new key made at AutoZone ? I just don't want to get stranded outside Sturgis at 2a.m. ! :-)
02-24-2016, 12:36 PM #4671
The only key you could get form parts stores are the door keys, for the ignition you'll have to get them clone at the dealership. Cost me $25 when I needed a spare. Just make sure you take your registration in with the VIN #.
Option 2 - VATS delete.
I know there are some wires that work the seat controls. Without a pic it's hard to say.
02-24-2016, 05:18 PM #4672
I look forward to driving mine this spring when the good weather returns. Otherwise, this talk of catless Y pipes has me anxious to get my LTs and OR/Y in.
2000 Trans Am WS.6 M6
SLP lid & bellow w/ K&N, GMMG catback w/ Corsa Clones, UMI SFC, UMI Adj. Panhard, UMI Adj. TQ arm w/ relocation kit, QTP Longtube headers ORY, LS6 intake, EGR/A.I.R delete.
Eibach prokit, Bilstein HDs, Nitto NT555s, skip shift elim, whiteface overlays, 20% tint, matte black decal/overlays
YouTube.com/DarrenWS6
02-24-2016, 05:25 PM #4673
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
Most people do but I invested in a catted y-pipe, I would like to know when they aren't working, especially when they may be clogged up. I look at it as an added bit of insurance.
My '89 T/A engine went down when that cat' clogged and overheated the engine and the head gasket went.
02-24-2016, 05:37 PM #4674
- Sep 2010
- Bel Air, Maryland
SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
02-24-2016, 06:00 PM #4675
02-24-2016, 08:11 PM #4676
00 FB Vert - Stock
02-25-2016, 02:47 AM #4677
- Apr 2008
- Madison, WI
-------------------------------------Kooks 1 7/8" race headers, Kooks ORY, Borla catback, Nitto 555R, LS6 intake manifold, Shaner S3 ported stock throttle body, SLP lid, smooth bellows, JAAM Ram Air kit, Elite Engineering catch can, LS6 valley cover, EGR and AIR deleted, Frost tune, and Simpson Racing child car seat in the back. 13.2 @ 108MPH
02-25-2016, 03:06 AM #4678
Here is the link to the show: Carlisle GM Nationals - Collector Car Show and Swap Meet, Everything GM, Chevrolet, Pontiac, Buick, Cadillac, Oldsmobile
We also have a thread up on here somewhere that covers all the chatter about our plans and past glory.
I made up a resistor pack for our car and simply keep it in the car ready to go if our system ever craps out:
02-25-2016, 05:24 AM #4679
I think the tiny black wire goes to the seat belt. Its suppose to turn the light off when the seat belt is engaged. Just my guess, but I really cant think what else a tiny thin gauged wire could go to.
02-25-2016, 10:04 AM #4680
^^ Good a guess as any. I can check the books for our '02 if it isn't this.
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
