Results 4,341 to 4,360 of 7102
08-18-2015, 05:53 PM #43412000 Trans Am WS.6 M6
SLP lid & bellow w/ K&N, GMMG catback w/ Corsa Clones, UMI SFC, UMI Adj. Panhard, UMI Adj. TQ arm w/ relocation kit, QTP Longtube headers ORY, LS6 intake, EGR/A.I.R delete.
Eibach prokit, Bilstein HDs, Nitto NT555s, skip shift elim, whiteface overlays, 20% tint, matte black decal/overlays
YouTube.com/DarrenWS6
08-19-2015, 07:17 AM #4342
I got my fog lights from a place called "http://www.certifit.com/". They are local to me in the same parking lot where I work, so it was a no brainer. The turn signal housings were purchased from gmpartsdirect.com
08-19-2015, 07:21 AM #4343
I haven't upgraded to the leds yet on the TA, so sorry guys, no info on what it takes to install. I know with my 09 Cobalt, I installed led tails lights, and they hyper blink. I'm either gonna get a resistor for the bulbs, or just change out the stock flasher relay for 1 that works with the led's.
08-19-2015, 06:04 PM #4344
08-20-2015, 04:49 PM #4345
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
I would probably have to check with the company, I have sequential tail lights and I remember them not being compatible with LED's so I don't know if a led flasher would affect them!
99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
Wish list.
Coil overs, Heads & Cam
08-22-2015, 05:48 PM #4346
Aside of work this morning I've had the day to myself. Cleaned at home and got some stuff done. Ordered a pizza as a lazy dinner and drove the WS6 around until it was ready for pick up .
I also have been meaning to get a clip of my signal flasher. Video pretty much describes the issue. I just forgot to mention the signal will still kick back when the wheel is turned and straightened. It just hyper flashes and does not 'tick tick' on individual signaling. Bad flasher relay? As you can see from the video I have whiteface gauges. I hope it wasn't the original installer's fault. In that case it is livable.
08-23-2015, 05:49 PM #4347
I took it for a quick ride this evening, and returned home by dark. I let it run with the parking lamps on and did a admirable walk around of it in the garage. I noticed the license plate light and the glow of the filament bulb. I then went to the back of my F150 and pulled one of the #194 high powered V-LED bulbs I have in it ( 6000k color ) and put it in the WS6. I ended up liking it and am quite blown away with how bright it is. Almost wish it wasn't so bright but damn is it clean looking!
Before:
After:
The bulb is a tight fit but it did fit. Here is a link.
6K WHITE 4 LED HIGH POWER FLANK BULBS 194 168 158 160LM | 1 PAIR. Currently costs $18 per pair.. Jeeze, when I bought them for my F150 I was bitching that they were $14.50! If anyone orders one, use quantity 0.5 for just a single bulb. They also offer a 5000k white compared to my 6000k slight blue hue white.
08-23-2015, 06:37 PM #4348
As your attorney, I would recommend against lighting up your plate real well. Kind of blows the "some other dude defense" if they can get a good read on it!
08-24-2015, 06:09 AM #4349
08-24-2015, 09:59 AM #4350
There are 2 bulbs in the back of each tail light for the brake and turn signals. There are 3 bulbs total in each side, but only 2 of them light up for the brake and tail lights. Turn your left or right signal on, then go to the back of the car to check for both bulbs flashing. You can also check for corrosion inside the contacts where the bulb and socket meet.
08-24-2015, 11:49 AM #4351
- Jul 2015
- camp hill pa.
black- 99 trans am
Last night I picked up fenders, both headlight assemblies, front and rear bumper covers, lower sid moldings, both inside door panels, new air intake and a few other goodies. All used and adding a rear soon as well.
Trying to get a new hood today.
08-24-2015, 12:14 PM #4352
08-25-2015, 05:43 AM #4353
Damn!! Are you building a car from scratch? LOL. I also have a stock, black TA hood. Not a ram air. Although i am a little further away I guess then kingls1.
1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
08-25-2015, 06:10 PM #4354
- Apr 2011
- Johnstown,PA
No such luck Ron he PM'd me he is looking for a aftermarket Super Hawk hood like I have. Might have to use our Hoods for sled riding down a steep hill this winter about all their good for!
08-25-2015, 06:55 PM #4355
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
Just noticed my dash pad developed a crack on the thin side of the vent hole
08-27-2015, 09:49 AM #4356
Got this today...
Also ordered my new Magnaflow Muffler for my 3" exhaust.
08-27-2015, 12:46 PM #4357
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
Finally not traveling for work or pleasure so got to take it for a ride for the first time since replacing wires and plugs. Seems that was my problem. Sounds good and feels more responsive.
08-28-2015, 02:25 PM #4358
Also order my new tips
08-28-2015, 02:39 PM #4359
Nothing major, replaced the long 31" metal antenna with a 13" one I found on ebay they have 8" ones too.
Regards,
Todd
#cajunhotrodder on instagram
08-28-2015, 06:32 PM #4360
At the local cruise-in, I took these photos. PaJeff's Buick Regal T-type and their recently acquired '70 Camaro to the left of my car. To the right, Zack ( zapper2003 )'s Firebird, and a built and serious Dart owned by a fellow named Ron.
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
