Results 1 to 20 of 32
    Senior Member
    texas
    2000 formula
    LT1 rad install in pics
    I am a member of the pimp boys rewards program......so my recent purchase of new tires really added to my rewards account.......decided to upgrade my rad to a LT1 style.....its really thicker than the LS1 rad.......and a drop in after you fix the LT1 stuff......pimp boys had it in stock.......so I did it that day......the LS1 rad is about 7/8 thick......LT1 is about 1 1/4
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    had a freakin birds nest in there
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    you can see the 1/2 heater hose I used to help plug the lower left hand outlet on the rad......the hose and a brass petcock on the end of it did the trick
    Senior Member
    texas
    2000 formula
    used a 1/2 to 7/8 plug to fill in the upper right hand hole where the LT1 coolant level sensor goes
    Senior Member
    texas
    2000 formula
    look ma....no rad.....i also reverse blew out the A/C condenser to get rid of all the crap stuck in the fins......then flushed it with water......it was DIRTY
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    and it all cost less than 100$
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Now all you need is the LT1 lol sry, couldn't resist.
    Senior Member
    texas
    2000 formula
    i could make it a .........V16
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Quote Originally Posted by sjsingle1 View Post
    An Ls/Lt combo 16 cylinder engine I would pay to see that. lol Not to mentoin you would have to blend the LT1 front end of the car onto the LS car to make it all fit lol
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    so do you notice any difference in temp? i know the Ls runs just under 210f...
    Senior Member
    texas
    2000 formula
    i run a 160 stat.....so no diff in temp...my stock idiot gauge is always around 190......but it has never run hot on me.....not even with all that crap in the rad fins and a/c fins......but i dare it to even think about running hot now
    Senior Member
    texas
    2000 formula
    U p d a t e
    Senior Member
    texas
    2000 formula
    driving home today and that rubber plug in the coolant level sensor hole........CAME OUT....lost at least half the coolant......went to auto zone and got the sensor and plugged it in the hole.......at least i know that wont COME out.......so..........i dont recommend you use a rubber plug in that hole......i dont know if i screwed up the engine .....i looked down and the water temp was pegged......dont know how long it was pegged in a 1/2 hr drive on the highway.......got a tow home to fix it.......seems to be running all right now
  1. CTS-V Install w/ pics
    By Wesman in forum Suspension and Handling
    Last Post: 06-13-2011, 11:43 AM
  2. Header Install in Pics (Pt 2)
    By sjsingle1 in forum External Engine
    Last Post: 05-09-2010, 02:14 AM
  3. JL install pics
    By midnightnavyz28 in forum Stereo and Electronics
    Last Post: 08-23-2009, 04:29 PM
  4. INSTALL progress pics -- rear well box for 12" -- PICS
    By fredmr85 in forum Stereo and Electronics
    Last Post: 05-28-2007, 12:37 PM
  5. SLP Lid install pics
    By bellboa1 in forum Camaro / SS
    Last Post: 04-24-2007, 02:28 PM
