Page 1 of 4 1234 LastLast
Results 1 to 20 of 69
    doylestown, Pa
    SILVER
    2004 CTS-V
    98 CAMARO SS (From clean to totaled to better than new!)
    June 13th through the 14th I buffed my entire car for 2 days. The car was so smooth and perfect. The following week (June 18th through the 19th I installed vinyl MANTA STRIPES. A month before this, I rebuilt my T56 to LEVEL II Specs, (should hold 700 ft.lbs.), installed a 12 Centerforece DFX clutch and Qiuck Time scatter shield (to hold the 486rwhp), andpainted the whole undercarriage and dynomatted the entire interior while I waited for tranny parts to show up.
    doylestown, Pa
    SILVER
    2004 CTS-V
    July 17 I was headed home from a friends house at 11AM. It hadn’t rained in many many weeks. So when I left it just started raining (you know, when all that oil starts to come out of the blacktop). I hydro planed at 50 m.p.h., did 2 360's in the air and took out 5 sections of split rail fence. I was F**KIN PISSED! Every panel on the car was dented, broken or scratched.
    The following pics show some of the damage. What isn't shown is the cracked front right fender, the ripped bumpers front and back, damage to the intercoolers, front inner fenders, 2 wheels, right and left rocker panel and the exhaust and some other stuff.
    The insurance guy showed up and immediately said it was totaled. I had a long talk with him, showed him some of my other cars (69 Chevelle) and I guess he got to like me. He went back to his car and figured the car at 79% and saved the car. I got enough money to paint the whole car (IF) I did all of the body work myself.
    The following pics are of the work that my dad and I did all by ourselves. This was my first time doing a 1/4 panel! I got the quarter panel and rocker from my totaled 97 SS. The last good parts left on the stripped car!
    Here is the 1/4 panel and rocker I cut off of my 97SS.
    Here is a creative way to remove the rook panel without replacing it. Use a thin piece of steel and sharpen the end of it and hammer it through to cut the glue.
    Here is the 1/4 panel and rocker installation
    doylestown, Pa
    SILVER
    2004 CTS-V
    Here she is! All painted! The car is 90% complete. I still have a bunch of small parts to put back on. Notice the body colored mirrors!!
    doylestown, Pa
    SILVER
    2004 CTS-V
    Sorry, the dead grass really doesn't help!
    Looks great again
    doylestown, Pa
    SILVER
    2004 CTS-V
    Here is a list of the MODS
    1998 LS1 Camaro
    3,600 lb. race weight
    486 rwhp / 450 rwtq
    BEST ¼ MILE 11.9 @119mph 9/18/2010
    Engine Modifications
    - Stock bottom end
    - LS6 intake
    - 42# Green Top injectors (Racetronix pump w/ Hot Wire kit)
    - Trick Flow 215 cylinder heads
    - Harland Sharp 1.7 ratio rockers
    - LS7 lifters
    - Hardened pushrods
    - NGK TR6 plugs gapped @ .035
    - P1SC Procharger @ 7-8# (6-rib) ((upgrading to 8 rib))
    - Pro-Flo bypass valve
    - 16” and 9” Spal fans
    - LT1 radiator
    - Jones Racing power steering and tensioner pulley
    Exhaust
    - QTP Longtube headers
    - 2.5” 304 stainless true duals w/ X-pipe (over the axle) 3” dual E-cutouts
    Suspension
    - Koni shocks (DA front / SA rear
    - SLP/Eibach springs (97SS optional springs)
    - SLP front sway bar
    - Boxed Stock LCA
    - HPM short tunnel mounted T/A w/ driveshaft safety loop
    - Strange 12 bolt w/ 31 spline C-clip eliminator axles/POSI / w/ 4:10’s
    - Strange driveshaft with Spicer ends
    - LCA relocation brackets
    - 3 point UMI subframe connectors
    - Edelbrock adjustable panhard bar
    - JEGS panhard bar relocation bracket
    - Poly engine and trans mounts
    Transmission
    - $$Level II rebuild & MANY, MANY EXTRA$$
    - Pro 5.0 shifter
    - Centerforce dual friction 12” clutch
    - Quick Time scatter shield
    - McLeod adjustable master cylinder
    - Skip shift eliminator
    Other mods
    - ABS/Traction Control delete
    - 17 x 11 ZR1’s (rears)
    - Mickey Thompson 315/35/17 drag radials
    INTERIOR MODS
    - led turn signals in mirrors
    - Trans Am seats w/ lumbar supports
    - Trans Am door panels
    - Dual Seat heaters
    - New headlinder
    - New sun visors
    - 9 speaker / 1800 watt stereo
    - 99 + steering wheel w/ radio controls to power aftermarket radio (Kenwood)
    - Sirius Satellite Radio
    - Dyno matted complete interior
    - All electronic gauges (wideband A/F, fuel pressure, boost)
    EXTERIOR MODS
    - clear front markers
    - halo headlights
    - EXPORT taillights
    - BILLIT rear CAMARO letters
    - New custom Camaro emblem on nose (front bumper)
    - Entire undercarriage painted gloss black
    Many, many mods are not listed. To much to remember! Will update later. But as you can see, I have put a lot of time and money in this car. I wasn’t going to let it get totaled NO MATTER WHAT.
    The car has ran a best of 11.9 @ 119 mph in the ¼ mile as of last week. Yesterday I just found (2) supercharger hoses with holes in them! This could have contributed to a loss of probably over a # of boost. I am going to go back to the drag strip again and I think I should be able to run a mid 11 second pass under 120 mph.
    Dynamic duo naperws6's Avatar
    naperville
    02 HAWK aka the beast
    Nice work and don't put on the stripes maybe it as bad luck.
    doylestown, Pa
    SILVER
    2004 CTS-V
    Quote Originally Posted by naperws6 View Post
    Haha, maybe !
    Senior Member 98maro's Avatar
    Feb 2010
    north bay california
    00 camaro ss M6 #6695
    To bad bout the accident. But looks great now. Headlights and tail lights look good.
    02 tahoe Z71 blacked out
    98 z28 red m6 sold
    07 zx6r ninja flat/black sold
    08 zx6r ninja sold
    Keep it together for the next Spazpalooza!
    Feb 2010
    Greenwood, IN
    Light Pewter Metallic
    looks great man. glad you brought her back to life. sweet set up in the motor.
    2012 Regal GS
    2004 Cadillac CTS-V (Sold)
    2001 Camaro SS (Sold)
    1999 Camaro Z28 (Sold)
    Coral Springs, Fl
    Sunset Orange Metalic
    Too much time rebuilding and not enough time watering your grass i see
    Car looks great, personally i like it without the stripe
    Good to see you had the care to rebuild it
    Keep up the good work
    Feb 2010
    Greenwood, IN
    agreed
    Looks damn good! Glad to see you resurrected her. I would have probably done the same had it been our car.
    Member camaross1's Avatar
    Aug 2009
    chesapeake,VA.
    2002 camaro ss
    Thumbs up
    damn man, you and your dad get a BIG THUMBS UP, alot of work, most people would excepted it as a total loss, or had a bodyshop fix it, now thats a REAL camaro lover, great job before and after, please stay out of the rain ha!
    good to see it's back on the road again!!!
    What I think is coolest is how quickly it all came BACK together considering where it came from post-accident.
    doylestown, Pa
    SILVER
    2004 CTS-V
    What do you mean?
    It usually takes a bit of time to source the parts and whatnot to repair a car, esp. when they're out of production. You just seemed to have everything fall into place for the rebuild, probably not the case, but that's how it seemed on my end.
    Philly+Glenmoore, Pa
    Pewter Metallic
    2002 Trans Am WS6 M6 D1SC
    Speechless man! You sure did tons of work and it definitely looks like it payed off. Cant wait to see your car again. Hopefully mine will be up to standards by then!
  1. CLEAN headlights 98-02 camaro
    By pewterzron in forum Parts Wanted / Trade
    Last Post: 08-05-2011, 08:50 AM
  2. For Sale: CLEAN 01 Camaro RS 3.8L SS Package
    By Fotis in forum Vehicles For Sale / Trade
    Last Post: 11-30-2009, 08:55 AM
  3. Parting out 95' camaro(totaled)
    By 99transamC/FIA in forum Parts For Sale / Trade
    Last Post: 06-14-2008, 04:21 PM
  4. R.I.P. 1999 Camaro SS... Totaled.
    By Tyler_LS1 in forum Camaro / SS
    Last Post: 02-18-2007, 04:43 PM
