Thread: panhand and LCA question
09-09-2010, 07:56 PM #1
i see the track maybe 6times a year......no road racing at all
NOW
what should i get? for panhard bar and LCAs......adj or non-adj ends AND poly or spherical rod ends
09-09-2010, 08:02 PM #2
09-09-2010, 08:43 PM #3
if your car is stock height or only lowered a little get boxed LCA with poly. and for phb get the on car adj. with poly.
polyurethane is better for drag. rod ends are better for road race. roto joints are supposed to be half way.
you should of posted this 3 days ago I just sold my bmr aluminum boxed LCA and poly phb w/ SLP springs to some kid on craigslist for 200
09-09-2010, 08:47 PM #4
09-09-2010, 08:53 PM #5
I never drag raced so I can't tell if the polys are really better then the rod ends. the only thing that I do notice now with the rod ends is I feel every bump in the road much more than I did with the poly pieces. also the poly squeaked alot on turns which isn't really a big deal but it was kinda annoying
09-09-2010, 09:02 PM #6
09-10-2010, 08:06 AM #7
- Dec 2005
- Pa
Hello,
Rod ends can be noisy overtime, even good rod ends will eventually wear and add additional noise. I wouldn't recommend them for a daily driver.
Since you do plan on lowering the car I highly recommend an adjustable panhard bar. This will allow you to center the rear end after lowering it. With out the rear end may sit slightly off center after you lower. For control arms non-adj. will be just fine.
I posted a few links below on my recommendations. If you have any questions I would be happy to assist you.
Panhard Bar- www.umiperformance.com/2029
Lower Control Arms- www.umiperformance.com/2015
Hope that helps!
Ryan
09-10-2010, 08:26 AM #8
09-10-2010, 09:10 AM #9
09-17-2010, 03:32 AM #10
- Dec 2005
- Pa
09-17-2010, 03:57 AM #11
Imho, I'd go with the adjustable panhard Dom.. Our axles are sightly off center from the factory.. An Adjustable will bring things into line.. Just my .02..
09-17-2010, 06:56 PM #12
speedometer question + top speed question
By Krazy351w in forum General HelpReplies: 7Last Post: 06-21-2007, 05:51 PM -
HPIII question (not the same old question)
By slims00ls1z28 in forum Computer & TuningReplies: 5Last Post: 06-01-2007, 04:55 PM -
97 Bird Headlight question also engine noise question
By Zapper2003 in forum General HelpReplies: 2Last Post: 12-13-2006, 03:03 AM -
Speedometer question, RPO question
By acrylicophobia in forum Firebird / WS6Replies: 12Last Post: 11-02-2006, 07:08 AM -
Sex Question spinoff- PORN QUESTION
By egaian in forum Almost Anything GoesReplies: 77Last Post: 07-26-2006, 03:07 PM
