Results 1 to 20 of 23
Thread: 98 ls1 fuel pressure question
07-27-2010, 05:42 PM #1
- Jul 2009
- Meadville PA
Black- 1998 formula trans am
Ive been going nuts my car has been running like a 4 cylinder and I think Ive finally figured it out but want to know what you guys think.
Ive been told that low fuel pressure will bring up oxygen sensor and catalytic failure codes which I have on all 4 sensors and both cats. I thought it was grounds and they have been all cleaned. I thought it was crack sensor because I have no RPM's showing on my scanner when the car is hooked up and running? Changed it and it still does the same thing? Thougt maybe the TPS was bad and changed that still no fix. Now I checked the fuel pressure. My haynes manual says 55-60 with key on and car not running. I tried that and get 44 pounds. I started the car and it runs 55-56 pounds but when I rev the car up the pressure drops to 40 lbs. What do you guys think about my pump? Should the pressure be a definate 55-60 key on car not running and whats with the pressure drop? Is it just because the car is using more fuel when reving so the pressure drops at gauge? Would a faulty pump cause the codes because of a lean fuel condition? Thanks for youe help in advance.
98 formula m6
07-27-2010, 05:48 PM #2
I would start with the fuel filter before jumping into a pump change. Then, if you still have a pressure drop, it has to be the pump or the regulator. Not sure how the '98 is setup though.
07-27-2010, 05:55 PM #3
07-27-2010, 06:02 PM #4
- Jul 2009
- Meadville PA
Changed the filter about a month ago. I went to autozone to get a regulator and after looking it uo and pulling it out of the box the regulator they have is a smaller diameter and has a vacuum port. Mine is bigger with no port. I had them check 97 98 99 vette and f-body and they did not have one that would work? Whats up with that? I get parts all the time there and never had a problem getting the right parts. What the hell do I have ?
07-27-2010, 06:03 PM #5
- Jul 2009
- Meadville PA
The regulator is on the fuel rail in my 98 and it was a one year only deal. Anybody out there have an aftermarket part number for my regulator?
07-27-2010, 06:37 PM #6
07-28-2010, 08:15 AM #7
- Jul 2009
- Meadville PA
I just got off phone with gm parts and that is the fuel pressure regulator in the middle of fuel rail. I just dont know why I cant get one that will fit from the parts stores?
07-28-2010, 08:16 AM #8
- Jul 2009
- Meadville PA
Can I just buy a pump by itself and switch it out into my sending unit? Will it come apart without breaking something like a glue joint?
07-28-2010, 08:55 AM #9
I've read in the past where people have found that regulator ( which is in the tank by the way ) separate of the whole module but I have no idea where they find it at. I'll chime in this last time and then you're gonna have to learn things your way......that piece in the middle of the fuel rails is not a fpr......it's a pulse dampner. It maintains pressure to the passenger rail so there's no huge drop when the passenger side injectors fire. I have a 98 and have had my pump out and stared in the eyes of the fpr.....it's in the tank on the module.
07-28-2010, 03:26 PM #10
- Jul 2009
- Meadville PA
07-28-2010, 03:29 PM #11
- Jul 2009
- Meadville PA
QUOTE=0rion;2400631]I've read in the past where people have found that regulator ( which is in the tank by the way ) separate of the whole module but I have no idea where they find it at. I'll chime in this last time and then you're gonna have to learn things your way......that piece in the middle of the fuel rails is not a fpr......it's a pulse dampner. It maintains pressure to the passenger rail so there's no huge drop when the passenger side injectors fire. I have a 98 and have had my pump out and stared in the eyes of the fpr.....it's in the tank on the module.[/QUOTE]
Could it be that you have a late 98 that has 99-02 fuel pump and mine is early with 98 only pump? Who knows this car is driving me crazy
07-28-2010, 06:19 PM #12
- Apr 2008
- Madison, WI
^^^Dude....NO...its in the tank. There is no return line up to the fuel rail, therefore no possible way there can be a FPR there.
07-28-2010, 09:05 PM #13
- Jul 2009
- Meadville PA
GM part number 89060420
GM Performance 89060420 - GM Performance Fuel Pressure Regulators
This is what summit racing calls it.
07-28-2010, 09:11 PM #14
- Jul 2009
- Meadville PA
Here is a picture and notice that there is two fuel lines in the picture. [IMG][/IMG]
07-28-2010, 09:16 PM #15
- Jul 2009
- Meadville PA
Closer picture
[IMG][/IMG]
07-28-2010, 09:24 PM #16
I don't know what else to tell you really....go ahead and order that one from Summit I guess.
07-28-2010, 09:46 PM #17
- Jul 2009
- Meadville PA
07-28-2010, 10:23 PM #18
once again, they all do. 98-02 f-bodies all have a returnless fuel system with the regulator in the tank.
07-29-2010, 09:55 AM #19
07-29-2010, 01:56 PM #20
- Nov 2006
- Indianapolis
OP, you have a 95% chance that your fuel pump is dieing. The pressure should stay over 55, especially when the engine is under load. A free rev isn't really a load on the engine, so if the psi drops like that, imagine how far it falls when you are driving.
Help: Fuel pressure question
By pimpin78transams in forum General HelpReplies: 21Last Post: 04-21-2011, 04:35 PM -
Need Fuel Pressure specs for an '02 5.3 Flex Fuel
By Fortune50 in forum GM TrucksReplies: 1Last Post: 09-04-2007, 08:18 AM -
What fuel pressure should I set my fuel pressure safety switch at?
By JAvery20 in forum NitrousReplies: 3Last Post: 04-01-2006, 03:59 PM -
Looking for gauges! nitrous pressure, fuel pressure!
By texasss in forum Parts Wanted / TradeReplies: 2Last Post: 10-29-2005, 09:05 AM
