#1 |
1998 camaro
intake manifolds
i want to put a new intake manifold on mine. what would be the best or what are the best options. thanks
#2 |
Sold: LS1 '85 El Camino
2000 Trans Am WS6 M6
"Nymphadora"
LS6 Intake = Stock to Slightly Modified (Headers, Exhaust and Lid)
Fast 90/92/102 = Cammed to Heads & Cam to Boosted, etc...
__________________
2000 Black Trans Am WS6 M6 "Nymphadora" Performance: FTP 95mm Lid, FAST 90 Intake, Holley 90 TB, CNC Ported 5.3L Heads, Torquer V.2, LPP LTs, 4" Mufflex, Moser 9" w/ 4.10s, Full Aftermarket Suspension, and SD Tuned. Currently Being Installed: 150 Wet Shot of Nitrous. |
#3 | |
Jack
1999 TA WS.6
Agree with above, but for a boosted application I would stay away from a two piece intake. I'm sure that doesn't pertain to the OP, just thought I would throw it out there.
__________________
6.0 - 5.3 Lingenfelter's - 230/236 - FAST 92/92 - Kooks - 4" exhaust - ecutout - 9" 4.11s 416 RWHP 375 RWTQ on a Mustang Dyno - On old MAF Tune|Now SD by Frost Best 1320' ET - 11.91 | Best MPH - 119 | Best 60' - 1.65 Quote:
#4 |
Bangin Gears>Stab n Steer
2000 CAMARO SS M6
TRIPLE BLACK
you can get the BBK SSi manifold that flows 18% better than the LS6 brand new for only $399 at new era performance.
#5 | |
"Nymphadora"
Quote:
The problem with the BBK is that it's metal and is an unnecessary heat sink. |
#6 |
Senior Member
I had an aluminum Wein intake that got hot & stayed hot... Now I'm running a 90mm LS2 intake, but would rather have a FAST...
#7 |
2000 CAMARO SS M6
TRIPLE BLACK
The problem with the BBK is that it's metal and is an unnecessary heat sink.[/QUOTE]
True, but with the nitrous back fire burst plate underneath and the large amount of boring room made it the winner for my application. I just figured that I would throw it out there since most likely every one would only mention FAST or LS6. Just wanted to show that there are other options. |
#8 |
Theres an intake comparison in GMHTP this month. some are going to be alot more than you want or need though.
#9 |
Senior Member
02 Camaro SS-35th Anv. Ed
08 Impala LTZ
#10 |
I B strokin it
2004
hugger orange
Its VERY tall, but for $360 the Edelbrock proflo XT is a great intake.
I'm running one in my 04 GTO and had to cut a hole and run a hood scoop...on an F-body you need to take a big notch out of the cowl. |
#11 |
1999 camaro SS
profesional products 96mm
#12 |
2000 CAMARO SS M6
TRIPLE BLACK
#13 |
99 transam 30th vert
blue and white
ls1 ls6
What issue of GMHTP is the intake comparisons in? Can you get the info on line? I would love to see what it is comparing to what etc as there is so much controversy out there on every intake. LS@, LS^, Typhoon, Fast, Weiand, you name it and everyone has a different opinion.
#14 |
if you have the $ FAST is the way to go...if not x2 on the bbk ssi. I really don't have any problems with heat soak. if you're going with minor mods an ls6 intake would be a good investment.
__________________
01 white ss, t-top, m6, intake, exhaust 363rwhp/372rwtq |
#15 |
1998 camaro
what do you have on your car to make it put that to the wheels? and what intake do you have
Thanks |
#16 |
2000 CAMARO SS M6
TRIPLE BLACK
He probably has a few more things than me. Here are my numbers with the LS1 intake and bolt-ons... 356.67rwhp 370.10rwtq.. Ill let you know what happenes with the BBK
#17 |
1998 camaro
can you tell me the mods you have? so i can kinda now what i put out.
#18 |
00 camaro ss M6 #6695
In my case. I'm also lookin for Avondale manifold
I knw that ls6 is better than bbk But since I have 00 ss and I'm in Cali I need to get the bbk cuz it has the EGR provisions And I also kne that FAST is the best one But I can't afford that. To much
__________________
00 ss blk m6 98 z28 red m6 sold ![]() 07 zx6r ninja flat/black |
#19 |
i've just got bbk ssi intake man./80mm throttle body, volant cai, hooker long tubes and borla catless exh.
#20 |
| Bookmarks |
| Thread Tools | |
