LS1 Performance Information Kentucky-Speed TunedbyFrost T-Tops Online
Go Back   LS1 Performance Information > LSx Technical Help Section > General Help
Online Store Sponsors Rules
Notices
Autotrix howellefi Afterthoughts Auto
Reply
Thread Tools
Old 07-24-2010, 08:26 PM   #21
LgndKller20073
LgndKller20073's Avatar
2001 Firebird
I just want to make sure I'm right on this....if I buy this: http://www.autozone.com/autozone/par...1248_109988_0_
I can cut the trap door, pull out the old pump and directly replace it with the new one? I don't have to tinker with anything or solder and put stuff back together? I'm trying to make this as easy as possible.
LgndKller20073 is offline   Reply With Quote
Old 07-25-2010, 12:41 AM   #22
00ls-1
00ls-1's Avatar
2000 z28
if youre worried about the gas smell you could have it welded back or put some kind of epoxy epoxy not recommended but itll work. i know of people doing the trap door with no problems at all
00ls-1 is offline   Reply With Quote
Old 07-25-2010, 05:25 AM   #23
Cutlass
ASE Master Technician
Cutlass's Avatar
99 Formula WS6 M6
Quote:
yes its a direct plug in swap.
Cutlass is offline   Reply With Quote
Old 07-25-2010, 05:28 AM   #24
JayTA98
1998 TA
I did mine because of the metal tank and it work out great. I didn't even used screws, I just used RTV black silicone as a gasket and l haven't smell any fuel.
JayTA98 is offline   Reply With Quote
Old 07-25-2010, 06:23 AM   #25
pajeff02
Junior Moderator
pajeff02's Avatar
You can also get an autobody seam sealer from NAPA and most any auto paint supply store.
pajeff02 is offline   Reply With Quote
Old 07-25-2010, 09:00 AM   #26
silverz28camaro
silverz28camaro's Avatar
2000 z28
sebring silver
Get a racetronix pump, $200
silverz28camaro is offline   Reply With Quote
Old 07-25-2010, 09:06 AM   #27
Too Fast
Senior Member
Too Fast's Avatar
2000 WS6 6spd Hooker LT
I love it when the factory puts in trap doors to replace the fuel pump. A lot more import cars do than domestic. I will do it that way if/when my pump dies. In the meantime I don't let it go much lower than 1/4 tank and I change my fuel filter every 30k.
Too Fast is offline   Reply With Quote
Old 07-25-2010, 09:52 AM   #28
pajeff02
Junior Moderator
pajeff02's Avatar
While we are on the topic... what is the recommended replacement fuel pump for a stock engine? Off the shelf GM or something aftermarket? Same question for a modified engine? Racetronix?
Old 07-25-2010, 11:44 AM   #29
LgndKller20073
2001 Firebird
I think I will go ahead and try the trap door then. Hopefully I can get my car started from Midas and drive it the mile to my parent's house without it dying on me.
Old 07-25-2010, 08:00 PM   #30
LgndKller20073
2001 Firebird
What do I need to remove the carpet from the hatch area? I remember I couldn't dynomat that area because I couldn't figure out how to remove those little triangular things?
Old 07-25-2010, 09:31 PM   #31
00ls-1
00ls-1's Avatar
2000 z28
the hooks? mine was a torx socket
Old 07-26-2010, 03:21 AM   #32
Too Fast
Senior Member
Too Fast's Avatar
Quote:
If it died on me, I'd probably get one from Car Quest, or maybe an AC Delco store.
I've seen a lot of people recommend the Racetronix for modded engines.
Old 07-26-2010, 12:03 PM   #33
LgndKller20073
2001 Firebird
I had to have my car towed home from Midas but I went ahead and installed it. Plus, Midas didn't even charge me for the diagnostic test! So I basically got it stored there for 2 days and the problem diagnosed for free. Everything works perfect again. No smell of gas yet even after filling up, but I'm going to wait a few days to continue to check for leaks or anything before I seal it up completely. Took about 4 hours total to dremmel, remove, replace, then Dynamat the rest of that area. Not too bad. Here's some pics:
Old fuel pump:
Old fuel pump taken out:
New fuel pump in:
Close up of the new pump:
Hatch area with Dynamat:
Old 07-26-2010, 12:16 PM   #34
95camaroZNC
95camaroZNC's Avatar
1999 Trans Am
Well done, that looks pretty pro!
95camaroZNC is offline   Reply With Quote
Old 07-26-2010, 02:08 PM   #35
pajeff02
Junior Moderator
pajeff02's Avatar
Nice work. Now you can say, "I just saved a bunch of money..." doing it yourself.
Old 07-27-2010, 07:37 PM   #36
LgndKller20073
2001 Firebird
Yeah, I can say that....now my brakes are grinding like crazy so I need to replace those and the rotors and I need new tires. $1500 for all that though isn't bad. It's better than $1500 for just the fuel pump!
Old 07-28-2010, 04:22 AM   #37
Too Fast
Senior Member
Too Fast's Avatar
Old fuel pump:
New fuel pump in:
So how did you secure the piece you took off? How is the hole covered?
Old 07-28-2010, 09:45 PM   #38
LgndKller20073
2001 Firebird
Quote:
It's actually not yet. I've been checking for leaks from the O-ring for the last few days and making sure there weren't any before I cover it. But I'm thinking I'll use some sheet metal and caulk to put it on there.
Old 07-29-2010, 04:45 AM   #39
Smittro
The V6 Doc. is in........
Smittro's Avatar
92/01 Chevrolet
one black/ one NBM
Took me about 3 hours start to finish dropping my tank no cutting.. Just sayin'
Smittro is offline   Reply With Quote
Old 07-29-2010, 05:35 AM   #40
pajeff02
Junior Moderator
pajeff02's Avatar
Quote:
Other than the exhaust and heat shielding, what else has to come out to remove the tank? Is the panhard brace in the way?
Reply
TunedbyFrost Holley EmblemPros
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
GM Parts Direct
One of the largest message boards on the web !
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
