#1 |
99 camaro ss
Clutch won't engage
Does anyone know how to bleed the clutch on a 99 camaro ss? I was having problems getting it into gear so I checked the slave and it was empty. I put fluid in it and it seemed to help. Then it happened again first thing in the morning upon start up....it wouldn't engage. I checked the fluid and it was full. The problem seemed to only happen in the morning when the car was cold and as it warmed up, it would engage. Now it won't engage at all.
ANY IDEAS??? |
#2 |
'98 Camaro Z28
Black/Black
the master in under the hood. The slave is connected to the tranny. Your slave could be leaking. I had a similar problem, ended up replacing the slave. Might as well change out the clutch while you're in there if you're still running the original.
As far as bleeding the clutch, it's a two man job, unless you open a hole in your floorboard to access the bleed nipple. Do a search, there's a write up done somewhere on here. |
#3 |
Jack
1999 TA WS.6
http://www.ls1.com/forums/showthread.php?t=124254
If your master was empty, you have a leak somewhere that needs to be addressed. |
#4 |
00 trans am,SLP,Ws6
silver/black
Mark at Kyspeed sells a extention so you can bleed it yourself with out cutting the floor. If you replacing the slave it's worth the little extra $$. I did it and I'm so glad I did I just ran it up along side the master. And tucked it when I don't need it. But it's long enough that you can sit in the car pump the clutch then bleed it in a bottle without even getting out of the car
#5 |
99 camaro ss
I had just got the car back from the shop and they had put a new clutch and motor etc. In the car. I don't know if they forgot to fill it originally. I put maybe 500 miles on the car as the problem got progressively worse.
Since i filled it with fluid, the fluid level hasn't dropped. Could it just be air in the lines? |
#6 |
99 camaro ss
How do i get a hold of mark at kyspeed???
#7 |
99 camaro ss
OK........I FEEL DUMB.......I JUST SAW THE AD UP TOP FOR KYSPEED.......THANX
#8 |
Jack
1999 TA WS.6
You don't have to cut a hole in the floor when using the MityVac either. Depending on the price of the extension, that MityVac was only ~30 bucks. And its guaranteed to work flawlessly, every time, and much quicker then using the bleeder valve.
#9 |
KYSPEED.COM
1998 trans am
if you want please send me a pm. or make a post on what you are wanting.
I dont get emails from this site for some reason. also my cell is 606-422-8502 call me if you have any questions. I will have the slaves in stock tomorrow and the bleeder line I have now. thanks, Mark
__________________
KYSpeed.com | FREE SHIPPING & HANDLING | PRICE MATCH | EMAIL Kook's | American Racing Headers | Vararam | HallTech | Textralia | SPEC | McLeod | Raptor | Trick Flow | AFR | ECS | FAST | APS | TTi | Procharger | RPM Transmission | Comp | DMH | HP Tuners | PFADT | SLP | STS |
#10 |
Jack
1999 TA WS.6
Are we talking about the Tick remote bleeder? If so, theres no way to install it without dropping the transmission.
#11 |
It lives!
2000 WS6
It took me a good hour of bleeding the clutch to gett it squared away. I did it the old fashion way. My wife was in the car and pummped the pedal 10 times or so, then held it down while I cracked the valve. I slid a socket over the valve, then used a 1/4 inch ratchet to open and close the valve. You will want a drop cloth, and a bucket, but most of the fluid will run down your arm anyway.
I actually tied a rag around my wrist to help soak it up. Not a fun job, but you won't have to drop the tranny to install a new bleeder extension.
#12 |
00 trans am,SLP,Ws6
silver/black
Ya it's was the tick that I was referring to. I didn't take that into consideration that you would have to drop the trans I had it out when I did it because I was doing a bunch of other stuff at the same time slave replacement was one of those things
#13 | |
Jack
1999 TA WS.6
Quote:
#14 |
ASE Master Technician
99 Formula WS6 M6
^^^me too...and so has GM. They recommend the Mity Vac method also
#15 |
Jack
1999 TA WS.6
#16 | |
99 Formula WS6 M6
yep here the service bulletin
Quote:
#17 |
It lives!
2000 WS6
Sooo...let me get this straight. The vac goes to the reservoir, and not the bleed screw? I was always under the impression that the vac was connected to the bleed screw and was bled like a one man brake job.
#18 |
99 Formula WS6 M6
yep. Vacuum to reservoir. I've tried vacuum at the bleeder screw. It doesn't seem to work as well.
#19 |
It lives!
2000 WS6
Damn, I should have looked into a bit more.
#20 |
99 Formula WS6 M6
The J 43485 mentioned in the bulletin is a power steering bleeder adapter. It a big rubber stopper with a tube through it. Very easy to make. A couple guys I know snatch some big rubber stoppers from their science class lab and made them.
| Bookmarks |
| Thread Tools | |
