Thread: Best Cam?
    Member transamgirl89's Avatar
    Dec 2009
    Dacula, Georgia, United States
    2001 RS Camaro
    Best Cam?
    I'm looking to put a cam in my 01 and need help deciding on the best one to get. I live pretty close to Summit Racing so I'll more than likely get it there. Anything else relatively cheap I can do while mose of the other stuff is out of the way?
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by transamgirl89 View Post
    The cam you deside on should be relative to your goals. "Best" is not a word I use for cams.. Are you just dropping a cam in or are you doing the whole top end? Stock cam and valves see an intake lift of 0.298 exhaust is 0.306.. I would'nt exceed over a max lift of 0.500 on stock l36 springs. imho
    As far as other things to do. open up those l36 exhaust ports to @ least factory manifold opening size. Can't do much to the intake side cuz of the damn water jackets being so close. But polishing the "eggs" on the upper and lower intake can help..
    Pittsburgh
    2008 Hummer H3
    As you can see the eggs could use some help..
    Dec 2009
    2001 RS Camaro
    Wow that looks good. Thanks Smitty! I'll look into doing that over the summer.
