Results 21 to 28 of 28
Thread: cheap power
05-13-2010, 07:30 PM #21
- May 2010
- chicago area
green- 1997 camaro base
just little bit. but it would be a good point to shoot for eventually
05-13-2010, 11:48 PM #22
The second video is what appears to be a relatively stock l36 Camaro.
The first vid is mostly well tuned l67 with stock eaton blowers.. I'm not sore bro, I'm the v6 Doc. (A nickname given to me by a couple senior members)
One could buy a used cam and a set of used headers, add custom pipes (which is the only kind of exhaust I use) get a tune and easily be in lt1 territory as far as power with a 3800 N/A. Then there's the weight difference too and don't forget torque, we have that too..Last edited by Smittro; 05-14-2010 at 12:04 AM.
05-14-2010, 11:41 AM #23
- May 2010
- chicago area
what cold air intake would you recomend using?
05-14-2010, 12:16 PM #24
K&N believe it or not, but NOT the filter. Or better yet custom. You can open up the air box base for those of you whom have a lid type air box like mine.. I usually build custom CAI's so I can't go farther than that as far as off the shelf goes. I just don't look for them to buy because I can fab them in my own fab shop. My 01 has a stock lid and base. But my z34 was a custom. My Camaro will get a custom set up because of the future blower I plan to use..
05-14-2010, 05:03 PM #25
- May 2010
- chicago area
there are "custom" ones on ebay ... but i dont really know im looking for the ones that look like they would have the most airflow.
05-15-2010, 12:43 AM #26
Imho, for the best coldest air flow you've got to get the CAI/filter out of the engine compartment or @ least below it or above it with like an SS hood. A few pieces of say 3 or 3.5" (Anyone with the factory 85mm or roughly 3-3/8in. fly by wire you'll need @ least that dia.) intercooler pipe and some rubber couplings and elbows should do the trick. Then some kind of filter. Conicle filters will work, a mushroom shaped filter would prolly be better tho imho..
05-15-2010, 04:30 AM #27
- Apr 2008
- Yorkville, Illinois
Silver / black- 95 Z28
I put an SLP cold air induction kit on the womans 02 v6 firebird. was easy to install, noticed immediate difference and it was relatively affordable if I remember correctly. She's got a 5-spd, with the SLP induction, pacesetter midlength headers and a dynomax super turbo muffler (will be getting flowmaster catback for her b-day) sounds throaty for a v6 and definately gets out of its own way. Just shop around the different parts places so you don't get hosed. Good luck with the car dude! Keep us posted
05-15-2010, 08:45 AM #28
- May 2010
- chicago area
will do just got my first paycheck once i get a little cushion in my bank acount ill start adding performance
Help: More Power Cheap
By Coydawg6 in forum Internal EngineReplies: 32Last Post: 07-02-2010, 01:17 AM -
JET Performance Chip for sale!! 99 Camaro/Firebird LS1 automatic CHEAP CHEAP CHEAP!!
By J4moflo in forum Camaro / SSReplies: 0Last Post: 02-17-2008, 08:39 PM -
Big screen 51 inch HD Rear projection TV F/S local only in Philadelphia Cheap Cheap
By Hurley711 in forum General ClassifiedsReplies: 14Last Post: 08-30-2005, 07:02 PM
