Results 1 to 10 of 10
Thread: Coolant leak
    Member Sas's Avatar
    Loveland/Ft. Collins, CO
    Blue
    2001 Formula Firehawk
    Coolant leak
    I've been trying to track down a slight coolant leak that I have and think I finally found it. Does this mean my front main seal is going?
    Apr 2010
    Cincinnati
    1996 & 2002 T/A
    There shouldn't be any coolant coming from the front main seal. Where that coolant is at, it's more than likely run down from the water pump assembly. You could clean it off and put dye in the coolant system to be positive of the location of the leak.
    Member Sas's Avatar
    Blue
    I didn't think there would be any in the seal, but it looks like it's coming from the gasket right there. I didn't see any coming down from the water pump, it's just in that one area. The cars been sitting in the garage for three days and that's about the only time it leaks. Is there a special kind of dye to put in, or would pretty much any dye work?
    There is a large brass plug behind the alternator that may be leaking. It is the driver side block drain for the cooling system and takes a 17mm allen head. I used a paste thread sealant on ours and would recommend that or teflon tape if it is leaking.
    Member Sas's Avatar
    Blue
    Thanks, I'll have a look there and see if that's it.
    rsg98Z28 rsg98Z28's Avatar
    Atlanta, GA
    1998 Camaro Z28 vert
    I would start with a water pump. Try the simple things first if youre a little unsure, that looks like thats what it is judging by the location of the leak.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Quote Originally Posted by rsg98Z28 View Post
    This. Either the pump or gaskets are leaking.
    Member Sas's Avatar
    Blue
    I need to replace the belt tensioner for the alternator anyway, so once I get the new parts I plan on digging around down there. Decided just to let it have a slight leak, with a drip pan under it, until I get some money in the next week or so.
    North Jersey
    2004 GTO M6
    If you have to drive it, keep a gallon of water or dex-cool with ya to be safe. I did that when my water pump and radiator went out on me.
    Member Sas's Avatar
    Blue
    Luckily right now I don't have to drive it, and the only time it seems to leak is when I don't drive it for a few days. When I do drive it it runs fine with no leaks.
  1. Help: big coolant leak can't see from where?!
    By ls1fan74 in forum GTO
    Last Post: 03-25-2015, 01:54 PM
  2. Help: Coolant Leak
    By maher19403 in forum GTO
    Last Post: 10-22-2010, 01:09 PM
  3. Help: big coolant leak
    By Siciliano15 in forum External Engine
    Last Post: 05-03-2010, 01:31 PM
  4. Coolant Leak
    By Tx98Formula in forum General Help
    Last Post: 04-03-2010, 08:50 AM
  5. Help: Need pic of coolant pump weep hole (Coolant Leak)
    By Sweet Chops in forum General Help
    Last Post: 04-20-2009, 07:14 PM
