Results 1 to 13 of 13
    Warminster, PA
    Spark Plug Reference Chart
    Hey guys, been working on this for a little while and finally have it ready to post. Maybe someone can sticky it to the top so that people can easily reference it? It's fairly hard to compare each manufacturers heat range since there are so many factors involved but this is, in my opinion, the closest match for NGK's heat range system, which was used in the chart. If you guys would like to see certain plug manufacturers added, let me know.
    Spark Plug Info
    **Note: Heat ranges are determined by NGK standards. Not all plug manufacturers follow the same guidelines.
    ***Note: List is intended for reference only. Please consult with head mfg. and ignition mfg. for proper gap.
    ****Note: NGK IX and Denso plugs are Iridium.
    LT1
    Thread – 14mm
    Reach - .708”
    Socket – 5/8 hex
    Seat - Taper
    Stock Heat Range: 5
    Gap: .050
    Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Autolite 764; Champion RS14YC6 (stock number 13); Denso IT-16 (stock number 5325)
    Nitrous (one step colder)
    Heat range: 6
    Gap: .035 - .038
    Plug: NGK TR6 (stock number 4177); NGK TR6IX (stock number 3689); Autolite 103; Denso IT-20 (stock number 5326)
    Nitrous (two steps colder)
    Heat Range: 7
    Gap: Consult
    Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Autolite AR94; Denso IT22 (stock number 5327)
    LT1 w/ AFR heads
    Thread – 14mm
    Reach – 3/4”
    Socket – 5/8 hex
    Seat – Gasket
    Stock – MFG Recommendations
    Heat Range: 9
    Gap: Consult ignition mfg.
    Plug: NGK 5672A-9 (stock number 7405); Autolite AR3910; Champion C59YC (stock number 792); Denso IQ27 (stock number 5315); Denso IQ01-27 (stock number 5708)(diagonal platinum ground); Denso IQ02-27 (stock number 5711)(horizontal platinum ground)
    Heat Range: 10
    Plug: NGK 5672A-10 (stock number 7942); Autolite AR50; Denso IQ31 (stock number 5323)
    Heat Range: 11
    Plug: Denso IQ34 (stock number 5324)
    LT1 w/ Trick Flow & Edelbrock Heads
    Thread – 14mm
    Reach – 3/4”
    Socket – 5/8 hex
    Seat – Gasket
    Stock – MFG Recommendations: approx under 9:1 compression
    Heat Range: 4
    Plug: NGK FR4 (stock number 5155); NGK BKR5EIX (stock number 6341); Autolite 3926; Champion RC12YC (stock number 71); Denso IK16 (stock number 5303)
    MFG Recommendations: approx 10.5:1 compression
    Heat Range: 5
    Plug: NGK FR5 (stock number 7373); Autolite AR3924 (Racing Plug); Autolite 3924; Champion RC9YC (stock number 2075); Denso K20PR-U (stock number 3145); Denso IK20 (stock number 5304)
    MFG Recommendations: approx 11:1 compression
    Heat Range: 8
    Plug: NGK R5672A-8 (stock number 7173); Autolite AR3911; Champion C63YC (stock number 796); Denso IQ24 (stock number 5314)
    MFG Recommendations: approx 12:1 compression
    Heat Range: 9
    Plug: NGK R5672A-9 (stock number 7405); Autolite AR3910; Champion C61YC (stock number 785); Denso IQ27 (stock number 5315)
    MFG Recommendations: approx 13:1 compression
    Heat Range: 9 - 10
    Plug: NGK R5671A-9 (stock number 5238); Autolite AR3933; Champion C59CX (stock number 296); Denso IK27 (stock number 5312)
    MFG Recommendations: approx 14:1 compression
    Heat Range: 10
    Plug: NGK R5671A-10 (stock number 5820); Autolite AR3932; Champion C57CX (stock number 295); Denso IK-31 (stock number 5321)
    **NOTE: Use chart for static compression and adjust heat range for nitrous use accordingly.
    LS1 Stock and AFR
    Thread – 14mm
    Reach - .708”
    Socket – 5/8 hex
    Seat - Taper
    Stock Heat Range: 5
    Gap: .060
    Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Autolite 764; Denso IT-16 (stock number 5325)
    Heat Range: 6
    Gap: .035 - .038
    Heat Range: 7
    Gap: Consult
    Nitrous (two and a half steps colder)
    Heat Range: 8
    Gap: Consult
    Plug: NGK R5724-8 (stock number 7317); NGK TR8IX (part number 3691); Denso IT-24 (stock number 5328)
    Nitrous (three steps colder)
    Heat Range: 9
    Gap: Consult
    Plug: NGK R5724-9 (stock number 7891); Autolite AR93; Denso IT-27
    Nitrous (four steps colder)
    Heat Range: 10
    Gap: Consult
    Plug: NGK R5724-10 (stock number 7993); Autolite AR92
    LS1 w/ Edelbrock and Dart Heads
    Thread – 14mm
    Reach – 3/4”
    Socket – 5/8 hex
    Seat – Gasket
    Heat Range: 4
    Heat Range: 5
    Heat Range: 8
    Heat Range: 9
    Heat Range: 9 - 10
    Heat Range: 10
    4.6 Mustang GT
    Thread – 14mm
    Reach - .708”
    Socket – 5/8 hex
    Seat - Taper
    Stock Heat Range: 5
    Gap: .054
    Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Motorcraft AWSF-32C (copper); Autolite 764; Denso IT-16 (stock number 5325)
    Heat Range: 6
    Gap: .035 - .038
    Plug: NGK TR6 (stock number 4177); NGK TR6IX (stock number 3689); Motorcraft AWSF-22C (copper); Autolite 103; Denso IT-20 (stock number 5326)
    Heat Range: 7
    Gap: Consult
    Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Motorcraft AWSFA-12C (copper); Autolite AR94; Denso IT-22 (stock number 5327)
    Heat Range: 8
    Gap: Consult
    Heat Range: 9
    Gap: Consult
    Heat Range: 10
    Gap: Consult
    4.6 Mustang Cobra (96-01)
    Thread – 14mm
    Reach - .708”
    Socket – 5/8 hex
    Seat - Taper
    Stock Heat Range: 5
    Gap: .054
    Heat Range: 6
    Gap: .035 - .038
    Heat Range: 7
    Gap: Consult
    Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Motorcraft AWSFA-12C (copper); Autolite AR94; Denso IT22 (stock number 5327)
    Heat Range: 8
    Gap: Consult
    Heat Range: 9
    Gap: Consult
    Heat Range: 10
    Gap: Consult
    4.6 Mustang Cobra (03-04)
    Thread – 14mm
    Reach - .708”
    Socket – 5/8 hex
    Seat - Taper
    Stock Heat Range: 6
    Gap: .049 - .052 (have had better results with tighter gap)
    Heat Range: 7
    Gap: .035 - .038
    Heat Range: 8
    Gap: Consult
    Plug: NGK R5724-8 (stock number 7317); NGK TR8IX (stock number 3691); Denso IT-24 (stock number 5328)
    Warminster, PA
    5.0 Mustang 87-95
    Thread – 14mm
    Reach - .460”
    Socket – 5/8 hex
    Seat – Taper
    Stock Heat Range: 4
    Gap: .054
    Plug: NGK UR45 (stock number 6945); NGK UR45IX (stock number 3207)
    Heat Range: 5
    Gap: .035 - .038
    Plug: NGK UR5 (stock number 2771); NGK UR5IX (stock number 7177)
    Heat Range: 6
    Gap: Consult
    Plug: NGK UR6 (stock number 7773); NGK UR6IX (stock number 7348)
    5.0 Mustang Cobra 93-95 w/ GT-40 Heads
    Thread – 14mm
    Reach - .708”
    Socket – 5/8 hex
    Seat - Taper
    Stock Heat Range: 5
    Gap: .054
    Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Autolite 764 or 104; Denso IT-16 (stock number 5325)
    Heat Range: 6
    Gap: .035 - .038
    Heat Range: 7
    Gap: Consult
    Heat Range: 8
    Gap: Consult
    Ford F-150 Lightning (99-04)
    Thread – 14mm
    Reach - .708”
    Socket – 5/8 hex
    Seat - Taper
    Stock Heat Range: 6
    Gap: .049 - .052
    Heat Range: 7
    Gap: .035 - .038
    Heat Range: 8
    Gap: .033 - .036
    Heat Range: 9
    Gap: Consult
    Plug: NGK R5724-9 (stock number 7891); Autolite AR93; Denso IT-27 (stock number 5329)
    Member camaronx's Avatar
    nashville tn.
    torrid red/red interior
    2005 GTO 6spd
    Great info!
    What about stock ls-2 m05 gto with cat back and 125 shot of nitrous. What plug do you reccomend? Prefferably american and not autolite they remind me of ford or maybe it's just me ot is autolite a ford plug? But a list of all that would work is fine--i had the ngk-tr6 in my 94 camaro
    Virginia, USA
    1995 Trans Am
    I'm new to the chevy small block game - been under the buick 3.8 v6 and lately under the Gloriful Pontiac 389 from the 60s game - but only a few months into the chevy 350 in my 95 T/A (LT1)
    Reading this post as I'm trying to see what plugs to buy to replace the ones in my TA I'm thinking - why is ACDelco a no show on the great post you got up there?? I've always been a fan of AC plugs although when pricing some at my auto parts store they tell me the TA takes platinum AC plugs -
    I've never been a fan of platinum plugs as I feel they're a tad geared towards extended life (and higher prices) and a tad less geared towards quality of performance from the plug.
    Anyone have any good stories for an AC plug in the LT1? If so lend me the part #.
    Mike
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    great work there. i know it took some time to make this chart. so, sticky it is.
    Orlando FL
    Red+White Top and Stripes
    2000TransAmConvertible A4
    I like how you included the info for Fords.
    FAST 90/90, SLP Lid, Kooks JetHot Coated LT's, American Racing Y-Pipe+Magnaflow Cats, DHM Electric Cutout, Flowmaster American Thunder Catback, HP Tuners Software, 343 rwhp.
    BMR Convertible Subframe Connectors, Hotchkis Strut Tower Brace, BMR Driveshaft Safety Loop.
    Feb 2008
    york pa
    96 ws6
    I had a ? I have ngk55 plugs I'm about to put on my afr headed 383 lt1 and plan on spraying a 80shot at the track every once in awhile. So ur saying I should space them a little less than .50? I fast reply would be nice because the plugs r going in tomarrow. Thanks
    NYSpeed.com WhatUpWhatUp's Avatar
    Oct 2009
    NeW YorK
    2002 z28 A4
    ha nice info!
    Dec 2010
    florida
    It is too good for those users who are not well knowledge. you can easy trace at this forum every question which is in your mind. I'll see what I can get out of it. Thank you
    Junior Member artie634u's Avatar
    Western Oregon
    Indigo Blue
    2001 Trans Am WS6
    Which spark plug is better, E3 or Bosch Fusion?
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Quote Originally Posted by artie634u View Post
    NGK tr55.
    Member Frozen WS6's Avatar
    EagleRiver, Alaska
    RED, BLACK
    2001 WS6, 1998 TA
    After alot of looking to find what plug to use with what shot of Nitrous this is the best tip I've found and makes things really simple.
    http://www.ngksparkplugs.com/docs/te...de_Affects.pdf
    Go One heat range for for every 75hp shot. So
    BR6 good up to 75 shot
    BR7EF good to 150 shot
    B8EFS good to 225 shot
    I've tested this first hand and it works. I was told over and over tr6 was ok for a 150 shot. My 150 shot on that plug did a best of 9.88. After finding this info I put the br7ef in (my only change) went 9.89 on a 100 shot and 9.75 on a fat 150 shot.
    🤔 11s. blackbirdbrain89's Avatar
    hagerstown, mercersburg
    black trans am
    2000
    in the ls1 drat heads... they take a stock style... not gasket type .. and
    list from hot to cold for autolite
    AR3910
    AR3911
    AR3932
    AR3933
    i have ran all on my gfs 77 400sbc @11.5-1CR with biug cam and 34* of timming (pump gas)
    the 3910,3911 are to cold for it, i talked to a auto lite rep told me they are for race only eng's they will not work under 3500 rpm. they are too cold
    we use the Ar 3933...in and works good
  1. Spark Plug Gap
    By jamesg1750 in forum External Engine
    Last Post: 07-16-2010, 05:26 PM
  2. Help: spark plug gap
    By dav-02ws6-m6 in forum General Help
    Last Post: 03-26-2010, 04:59 PM
  3. What kind of oil 5w30& spark plugs&spark plug wire
    By ROMERO98Z28 in forum General Help
    Last Post: 09-01-2009, 01:50 PM
  4. Spark plug wire and plug!
    By RYDER661 in forum General Help
    Last Post: 03-13-2006, 09:01 PM
