Results 1 to 20 of 31
    Seattle
    '05 Ninja ZX-10R
    700hp vette vs 10r vs R1 vs Nos Busa.
    http://www.nickslick.com/nico/movies/4thsmall.wmv
    This is why I want an ls1 for my dd.
    Part time Goofball 0to60n4.5's Avatar
    Michigan
    Mystic Teal
    98' Formula
    Thanks for the cool movie . I should have popped some corn for this one ( lots of runs to enjoy) .
    If it doesn't require Premium fuel ,You got the wrong Model.
    89' TTA
    96' LT4 VETTE
    94' LT1 VETTE
    98' LS1 FORMULA
    97' TSI AWD TALON
    84' 357cid CAMARO
    79' 403cid Fuel Inj. SEVILLE
    ABOUT 6 OTHER DAILY DRIVERS
    http://webpages.charter.net/pmcmolson/HOMESPAGE3.htm
    Impounded MikeSomething's Avatar
    Old Bridge, NJ
    Pewter Metallic
    '00 Z/28
    Good watchin...
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    it was alright i was hoping to see the 900 hp viper they talked about at the beginning
    98' SS Convertible Camaro-76k-Build # 1471, Cragar SS rims, RK SFC's, MAC Panhard, LSX Tune, Shaner S3,
    SLP:short thro,Strut tower brace,fan switch
    MTI Power induction kit,40 Series muffler,Pacesetter LT's + ORY,12 CD changer,3800lbs
    http://www.cardomain.com/ride/787506/1
    member toneloc60's Avatar
    currently, a tent in Iraq
    '00 Z28
    It was worth the time kill.
    That speedo was reading kph, right?
    Seattle
    '05 Ninja ZX-10R
    Clearly. If you read those other threads, then you know that if it goes faster than a camaro with lid and free mods, it's always in kph. Because nothing can be faster than their lightly modded fbodys. Good thing that stripped, 700rwhp vette was there. I think if it hadn't been for that, a couple of those guys would be claiming that bone stock bikes can't go that fast.
    purdue
    that was a big vid. took me 20 seconds to dl. sweet vid too.
    Member 04goatinmass's Avatar
    salem ma
    04 pontiac gto
    awesome video got anymore
    Fort Benning, GA
    '91 turbo fox, '97 vette
    Was the vette making 690 hp or rwhp?
    Chris
    Senior Member NeeD4SpeeD's Avatar
    New York, NY
    Collectors Edition Yellow
    2002 Pontiac Trans AM WS6
    Probably RW if it was all modded the dynos will only read RWHP the flywheel HP is only givin by manufacturers so im assuming that is RW..
    SICK VID tho!!
    Fort Benning, GA
    A lot of aftermarket companies make crate motors that they dyno at the crank before they put them into the vehicle... You're probably right, but the difference at this level is probably more than 100 crank hp, which would make the difference in a couple of races. I'm building a motor for the stang that should put down in the neighborhood of 700 rwhp on pump gas. So, I'm asking because I'd like to know how I'd fair against those bikes.
    Chris
    edit: motor, not "more"
    salem ma
    04 pontiac gto
    Quote Originally Posted by Chris Arnold
    A lot of aftermarket companies make crate motors that they dyno at the crank before they put them into the vehicle... You're probably right, but the difference at this level is probably more than 100 crank hp, which would make the difference in a couple of races. I'm building a more for the stang that should put down in the neighborhood of 700 rwhp on pump gas. So, I'm asking because I'd like to know how I'd fair against those bikes.
    Chris
    how u fair against a nos busa....im sorry but did u see the vette against it..there was no match the busa is just way to powerfull...but id like to hear about your build
    Fort Benning, GA
    Firebird, you don't read very well. Find the following in my post and then observe the context:
    "those bikes."
    "on pump gas." It might be closer than you think if the race is planned in advance, firebird.
    salem ma
    04 pontiac gto
    correct me if im wrong but your saying that your build at 700 will compete with that nos busa or what are you talking about when you say those bikes?all im stating is the vette in the video had no chance against that nos busa.so how would you have anymore of a chance?im a bit confussed here please explain on what you mean
    Fort Benning, GA
    Why so you can flame me? It sounds as though you're under the impression that no car can keep up with a modified bike.
    "Those bikes" refers to all of the bikes, the nos busa was only one. There's the R1, the 10R, and the turbo busa, as well. If the vette is making 690 at the crank, then I believe 700rwhp at the crank of a similarly weighted car would be enough to outrun the 10R.
    pump gas is as opposed to race gas: I can put down a lot more power on race gas... a hell of a lot more. So, no at 700rwhp, no way I could run with either Hayabusa, but if the corvette was making 690 at the crank, then I'll most likely be able to outrun both of the other bikes.
    I don't want to talk too much shit because I'm just putting the motor together right now and it's a long way off from being a tuned running combination, but there's enough potential in the parts I'll be running to make a higher power/weight on race fuel than that nos busa is making.
    Chris
    salem ma
    04 pontiac gto
    i hope u can and will beat the bikes with your car in fact the vette did beat one of the bikes.all im saying is its a challenge to beat the busa...wait did u say u can beat the 10r as well.i dont think so thats a tough one to swallow
    Fort Benning, GA
    He beat the vette by less than 10 lengths in the vid. So yeah, I don't see anything too tough about beating him with 100+ hp over the vette.
    Now here's some sobering math for you to think through:
    240hp:650 lbs (that's a busa + a 150 lb rider) ==> 1 hp per 2.71 lbs
    My turbos together are rated to put out 1360 hp:
    1360hp:3300 lbs (the weight of my car with me) ==> 1hp per 2.43 lbs
    More realistically, I'll run 27psi and right around 1200 hp on race gas.
    1200hp: 3300 lbs ==> 1hp per 2.75 lbs
    Of course, that's at the crank and it's assuming the busa is making 240 at the crank. If the busa is making it at the rear wheels it'd be harder to catch. In that case, it'd be pretty much even rwhp:weight at the max output of my engine and turbo combination.
    Chris
    Fort Benning, GA
    New York, NY
    Thats a nice car you got there chris!! Thoes TT's are by HP Performance???
  1. New Busa motor I had built..
    By MYSCZ06 in forum Almost Anything Goes
    Last Post: 10-11-2009, 01:02 PM
  2. Is this 700hp vette worth it
    By screaminbird in forum Corvette
    Last Post: 11-13-2008, 10:08 PM
  3. 700hp Na 396 Lt1
    By Frans96ss in forum Parts For Sale / Trade
    Last Post: 06-27-2007, 11:47 AM
  4. Turbo busa vs. vette
    By bandit95 in forum Almost Anything Goes
    Last Post: 10-07-2006, 12:01 PM
  5. LS1 rx7 vs.yzr600 and busa
    By zx3focus in forum Kill Stories
    Last Post: 04-28-2006, 01:27 PM
