    Master Tech SSDEUCE's Avatar
    Jul 2009
    crownsville MD
    navy blue metalic
    2001 camaro ss
    Best factory heads
    hey yall lookin for the best factory heads out of theses numbers 806, 853, 241, 339 don't know much about ls1 heads so specs or what there off of will help thanks
    COTM July '09
    Annapolis, MD
    BLK/BLK w/CGM Stripes
    2010 Camaro 2SS/M6
    http://www.smokemup.com/tech/ls1.php
    People mostly like the LS6 head (243's)
    Make real real sure Johns00Z28's Avatar
    Germantown, MD
    2000 Z-28
    Yes 243 heads for the 3.9 bore. The L92s and LS7 heads for bigger bores flow huge numbers.
    Jul 2009
    crownsville MD
    navy blue metalic
    2001 camaro ss
    in nhra stock eliminator those are the only ones your allowed like to use 243 but not legal if i want to try that class
    NC
    SOM
    1998 T.A.
    If you can't use 243's and you cannot port them the 241's make maybe 3-5 more than 806's or 853's. This is due to a smoother casting finish due to a different casting method. All three have the exact same port design so once ported they all have the same potential.
    I would spend money on a GOOD valve job as that will give you more than the difference between these heads....
    Quote Originally Posted by SSDEUCE View Post
    Of the ones you listed, the 241s are the best.
    Jul 2009
    crownsville MD
    navy blue metalic
    2001 camaro ss
    good deal cause thats what i got
  1. Replies: 0
    Last Post: 02-04-2011, 02:00 PM
  2. Casting Number for factory heads on '98 TA Ws6
    By SSwt00SS in forum Internal Engine
    Last Post: 08-01-2010, 06:39 PM
  3. Factory Specs: Cams, Heads, Intakes
    By hoss 2000 z-28 in forum Internal Engine
    Last Post: 02-02-2009, 05:33 AM
  4. 2001 SS factory zo6 block/heads
    By samuelsamuel in forum Camaro / SS
    Last Post: 09-26-2007, 09:20 PM
  5. LQ4 with factory ls6 heads and intake=
    By old ta 1 in forum Internal Engine
    Last Post: 04-13-2006, 05:46 AM
