Results 61 to 80 of 622
09-21-2009, 05:34 PM #61
- Sep 2009
- moundville, AL
Silver- 2000 Trans Am WS6
here is some one a NBM camaro http://www.ls1tech.com/forums/wheels...l#post11778018
09-22-2009, 05:31 PM #62
09-26-2009, 09:05 PM #63
09-28-2009, 05:44 PM #64
09-28-2009, 05:49 PM #65
09-28-2009, 05:54 PM #66
09-28-2009, 05:59 PM #67
09-28-2009, 06:43 PM #68
No issues whatsoever, everything went together well once I got the proper caliper clearance with the front wheel spacers.
Braking is excellent, huge improvement over the stock brakes. You won't notice it around town, but the first time you get on them from higher speeds you won't believe the stopping power of this setup.
09-28-2009, 06:49 PM #69
09-28-2009, 07:05 PM #70
Got the calipers off of ebay as a pair (loaded with pads and hardware), got the rotors from GM Parts Direct, and got the lines from Flynbye performance. Wheels spacers I got from Advance Auto, had to special order them from Eibach. However, you won't need the wheel spacers if you get 40mm offset wheels.
09-28-2009, 07:14 PM #71
09-28-2009, 09:41 PM #72
Oh, two more things. In your write up you say that you can go with either 4 piston Caddy or 6 piston Z06, why would the caddy be better for the track with 2 less pistons? And will the Z06 fit with that spacer that you know of? Are you lowered or stock height with all of this. Thanks again, I appreciate it.
09-29-2009, 05:56 PM #73
From what I've read, its not the number of pistons thats the issue. The 4 piston CTS-V calipers are Brembos, while the 6 piston Z06 calipers are made by PBR, which is the same company that makes the stock F-body and standard (non-Z06) calipers. While PBR makes great products, the Z06 calipers just aren't as good for the track due to their design. One issue is the pads design - instead of using 2 pads, the Z06 calipers have 6 pads (3 on each side), which isn't as good for track use (uneven wear apparently?) and there are much less aftermarket pads options. The pads are also very expensive, at around $300 a set.
Both are excellent calipers, its more a matter of personal perference and budget than anything else. Also note that the CTS-V caliper is a direct bolt on, while the Z06 caliper needs an adaptor bracket to work.
The Z06 calipers should fit the same as the CTS-V calipers in terms of wheel spacers, I don't think the calipers are any wider, but you would have to check the measurements to be sure.
As far as ride height, my car is stock.
09-30-2009, 08:53 AM #74
- Sep 2009
- Ceres,CA
Black- 2000 Pontiac WS6 Trans Am
09-30-2009, 12:58 PM #75
09-30-2009, 01:59 PM #76
10-01-2009, 05:26 AM #77
10-02-2009, 05:59 AM #78
I agree. Always seems to me that the non t/a bumper comes out farther and looks aggressive as hell with a ra hood.
00 blackbird, Is that a formula firebird?
10-10-2009, 11:47 AM #79
10-11-2009, 10:27 AM #80
- May 2009
- Toronto
SOM- 2002 SS
Here's my Z
For Trade: Corvette wheels
By kenro23 in forum Parts For Sale / TradeReplies: 0Last Post: 02-07-2012, 07:21 PM -
Family of F-bodies for those with 2+ post ur rides
By bowtieguy02SS in forum Almost Anything GoesReplies: 66Last Post: 01-29-2009, 10:35 PM -
Corvette wheels same as F-Body wheels?
By StuntmanMike in forum Wheels and TiresReplies: 1Last Post: 08-14-2007, 02:43 AM -
Post Pics of the Ugliest F-bodies youve seen....
By Tyler_LS1 in forum Multimedia SectionReplies: 3Last Post: 12-26-2006, 11:21 PM -
BMW wheels that fit F-bodies
By SSwt00SS in forum Wheels and TiresReplies: 2Last Post: 08-24-2006, 02:13 PM
