Page 1 of 3 123 LastLast
Results 1 to 20 of 55
    Member GTO1_OHIO's Avatar
    Melbourne Beach, FL
    Phantom Black Metallic
    2004 GTO
    Custom OTRCAI is on
    For those that aren't familure with this OTRCAI, It is a custom hand laid fiberglass unit being made by svede1212. ...oh and it only fits the 04 because of a difference in radiator height and distance to the TB.
    The short version ... installed it, started the car, and man the sucking sound inside the car is insane it's so loud. I though the LPE was loud.
    ... so the story begins. Just wanted to get this started tonight so that I can report on as I get some progress.
    The version I ordered is for the 4 inch hose/ 100mm MAF. For the summer I decided to go with a speed density tune. Maybe in the fall I'll go to a 100mm MAF to see what difference there is with it. Anyways, my setup is 90mm Fast Intake and 90mm Nick Williams TB. I used a 3 inch long straight hose and 3 inch long hump hose, each 4 inches in diameter. The hoses are attached using a 4 inch joiner made by Vibrant Performance. As you can see I had 6 inches to work with. ...well almost. Because of the angle from the TB to the intake, the bottom distance is 5 3/4 inches....meaning I had to trim the straight hose a little. ...this should give me plenty of space to get a 100mm MAF in there if I want.
    The other unique variable to my setup is my Gravana Type-W (Woodward) hood. There is plenty of space for the intake with this hood.
    As for my tune, I disconnected the sensor to the stock MAF and the car would not hold an idle at all. Reconnected it, the car started, found idle and ran very well considering the MAF and IAT are not in the air flow. This should be good enough though to get the car loaded on my trailer and off for the SD tune.
    I have a track rental to go to next month so I should be able to get some good info on what performance benefits I get out of this intake. I haven't done any changes to the car since last year and have 98 runs that I compare against from last year and 12 more from the last month. I'm also interested in seeing how it performs verses the Vararam design.
    Retired Outlaw Sum Bitch
    Cool. Does the radiator shroud go back on? The shroud forces air flow through the radiator and without it you lose major air flow through the radiator you know. Not being a wet blanket just curious.
    Melbourne Beach, FL
    2004 GTO
    Yes, I just have to cut it.
    Member pmolina0436's Avatar
    2004 GTO
    price?
    Melbourne Beach, FL
    2004 GTO
    Quote Originally Posted by pmolina0436 View Post
    price?
    Shouldn't really say since he's doing these custom for people and I don't know if he's charging people the same price. I will say it was for about the same as pre-order price for Vararam's new one.
    North Jersey
    2004 GTO M6
    Looks very good. I have been toying with the OTRCAI idea since I read the threads on LS1GTStalk.
    Quote Originally Posted by GTO1_OHIO View Post
    Good. Without it the air flow is all fucked up.
    Senior Member qwkgto's Avatar
    OHIO"S only 9 second GTO
    Phantom Black Metalic
    2005 GTO
    looks good buddie,hope it works as well as you expect,SD for the win!
    Junior Member BYOFICR's Avatar
    BATON ROUGE
    QSM
    04 gto
    hey man looks great i have one as well
    Melbourne Beach, FL
    2004 GTO
    Quote Originally Posted by BYOFICR View Post
    Know that. We are a small club at this point. lol
    BATON ROUGE
    QSM
    04 gto
    hey sarge yea i have my rad cover back on with some minor cutting
    Good man. You guys running a MAF or SD?
    Melbourne Beach, FL
    2004 GTO
    I'm going to try SD. Don't know how much experience my tuner has with it. I guess I should get HP tuner and learn it so that I can adjust as needed since I understand that SD needs a lot of road time to get really dialed in properly.
    mistermike, however, told me that EFI live would be better for SD.
    ...if the SD doesn't work out I'll go with a 100mm MAF. I'm having trouble getting details on these from vendors though.
    ...cut the radiator shroud last night just need to file down a few places, then I'll post up a picture. My plan is have my friends bodyshop paint the CAI and shroud PBM to match the car.
    BATON ROUGE
    QSM
    04 gto
    yea im still running my maf
    the rad shroud you can use sandpaper to make the edges smooth vs a file much easier and the paint well its a great idea but hate to say it eventually will break up know from expereince im guessing because of the amount of heat ( worth a try ) good luck
    you get a sticky for this....nice job and looks good.
    Melbourne Beach, FL
    2004 GTO
    So here's a pic with the radiator shroud cut to fit. ...like I said all will be painted PBM
    looks good russ....looks like a decent set up.
    North Jersey
    2004 GTO M6
    THAT LOOKS AWESOME!!!!!
    2004 GTO
    do the front grilles get air in the intake...
    Melbourne Beach, FL
    2004 GTO
    The filter doesnt extend down that far and behind the grills is my Derale tranny cooler. The cooler does have a fan that blows upward at a angle towards the bottom of the filter.
  1. Custom Sub Box
    By TopForm11 in forum Stereo and Electronics
    Last Post: 05-31-2007, 11:19 AM
  2. Custom FRC's
    By CWW17 in forum Showcar and Detailing
    Last Post: 05-25-2007, 12:09 PM
  3. Custom Tag for my Car
    By jimbo98z in forum Almost Anything Goes
    Last Post: 05-09-2006, 01:04 PM
  4. 94' Custom S-10
    By Larnek in forum Vehicles For Sale / Trade
    Last Post: 11-03-2005, 10:40 PM
