Page 3 of 3 FirstFirst 123
Results 41 to 55 of 55
  1. #41
    Senior Member qwkgto's Avatar
    OHIO"S only 9 second GTO
    Phantom Black Metalic
    2005 GTO
    Keep up the good work,glad the SD is working out for you!
  2. #42
    Member GTO1_OHIO's Avatar
    Melbourne Beach, FL
    Phantom Black Metallic
    2004 GTO
    ....so last night after my third run I hear this metallic sound coming from the front end. I think it may just be a pad sticking of maybe cracked. So this morning I start the car up and drive the car around and nothing. I figure the brakes thing was temporary. Today after my trial run the sound comes back an seems worse when I took the car out for the 10 mile run. The sound continued the final 3 runs so my last time last night and todays may have been slowed slightly by whatever is causing this. I'm guessing it could also be the emergency brake or even a wheel bearing.
    So as for today, I started a run with split times that almost identically matched my last run of yesterday. This was a time trial run
    DA: + 1756
    60: 1.69
    1/8: 7.60
    MPH: 93.07
    1/4: 11.93
    MPH: 118.60
    Then came the 10 mile run out of the park followed by 3 hot laps. The rule though is that nothing but tire pressure could be adjusted once we started ... including the hood ... it had to remain closed.
    The first run pretty much matched my time trial run, the OTRCAI easily got the temps down after the drive. I was in the second run down the track so I didn't have to sit very long and have heat build under the hood. I launched with an IAT of 95 degrees
    DA: + 1934
    60: 1.69
    1/8: 7.61
    MPH: 92.95
    1/4: 11.956
    MPH: 118.23
    The second run went off 15 minutes later. During this time the IAT reached 126 degrees while I waited. I had the car off to not build up anymore heat while I waited. The run lost some but not too much.
    DA: + 1934
    60: 1.71
    1/8: 7.66
    MPH: 92.54
    1/4: 12.018
    MPH: 117.88
    The third run went off 13 minutes later. This time the IAT went up to 135. I had to leave the car running to cool the tranny since my tranny cooler's fan had triggered at 180 degrees. This run actually was stronger then the previous and would have been in the 11s if I had not let off.
    DA: + 2046
    60: 1.71
    1/8: 7.65
    MPH: 92.86
    1/4: 12.010
    MPH: 115.74
    ...so I let off because this was a index race and I was damn close to averaging 12 seconds after the first two runs and in the money for the 12 second index. However I didn't quite do it soon enough and ended with a 3 run average of 11.994666666667 arghhhhhhh!!!!!
    ...so my though about the OTRCAI and starting out with a high IAT is that it kicks in well after the 60 ft mark, but just can't drop the sensors reading quick enough to keep it from creeping up as the heat increases on successive runs ....but still we are only talking about a very minor increase in the 60 ft. The different between my best and worst 60 today is only .021 and only .035 over two days. The heat also only dropped my 1/4 MPH only by 1.46 MPH over yesterdays best run (that's throwing out the 115 where I let off the gas).
    Conclusion. I'm very happy with the results as the OTRCAI seems to negate the heat was well as I could expect. ...can't wait for some negative DA.
    I'm skipping tomorrows bracket race since I still don't know where that metallic sound is coming from ... so that's it for now. Hopefully more people can duplicate what I've shown with this OTRCAI.
  3. #43
    2005 GTO
    sounds like the results are what you needed,now time for the alky.
  4. #44
    Melbourne Beach, FL
    2004 GTO
    What I didn't point out yet about my runs yesterday is that comparing them to the runs I posted from August 2008. The August runs were each first runs of the day so they were not at all affected by heat soak yet all my heat soaked runs from yesterday were better then them ... all were run in the low 70's and the DAs were all simular. That's a pretty impressive result from the svede1212 OTRCAI.
    ...so don't think I need the alky. What would it buy me now? I don't plan on keeping the the hood down and letting the IAT temp climb to 120 - 130 again. lol ...so I'm pretty sure I'll run 11s regardless of temperature now.
  5. #45
    2005 GTO
    Quote Originally Posted by GTO1_OHIO View Post
    I saw this setup in person,very clean way better,then any CIA ..so to speak that I have ever seen, and performs very well in the heat!
  6. #46
    Apr 2009
    SAUDI
    BLACK
    GTO 2005
    YOU GENIUSS
  7. #47
    Junior Member davleigh's Avatar
    Mar 2012
    townsville
    2002 vx ss commodore
    why not go a mafless tune? is it available in the states?
    with mafless tunes you are getting anywhere from 30-50 rwkw. from having an otrcai.
    you guys should check out the - justCommodores forum. these guys have a lot of experience in mafless tuning. and plus seeing as though your gto is our holden monaro and for the stock gto, its basically a 2 door version of a vx ss Commodore, you should get more then enough support in regards to your cars and upgrades.
    just an idea. but i recommend the mafless tune any day over a maf tune, you get more hp/kw.
    more torque, better response. in turn giving you a quicker et and higher mph.
  8. #48
    Mar 2012
    townsville
    Mate why not go a mafless tune with your otrcai?
    you will gain more hp and torque.
    You will acheive a 40 - 70 rear wheel hp with a mafless tune.
    highly recommended
  9. #49
    North Jersey
    2004 GTO M6
    Some members go SD/MAFless.
  10. #50
    Mar 2012
    townsville
    what is SD sorry?
  11. #51
    North Jersey
    2004 GTO M6
    SD is speed density. Also known as MAFless.
  12. #52
    Junior Member VY Cruiser's Avatar
    Sep 2012
    Sydney, Australia
    What strut brace is that? Looks beefy
  13. #53
    North Jersey
    2004 GTO M6
    BMR strut brace.
  14. #54
    Sep 2012
    Sydney, Australia
    Thanks, I want one
  15. #55
    Nov 2013
    A, A
    2004 Pontiac GTO
    hey i hate to bring this back from the dead but i was looking to get one of these for my 04 but i cant seem to find svede1212 on here anymore.
  1. Custom Sub Box
    By TopForm11 in forum Stereo and Electronics
    Last Post: 05-31-2007, 11:19 AM
  2. Custom FRC's
    By CWW17 in forum Showcar and Detailing
    Last Post: 05-25-2007, 12:09 PM
  3. Custom Tag for my Car
    By jimbo98z in forum Almost Anything Goes
    Last Post: 05-09-2006, 01:04 PM
  4. 94' Custom S-10
    By Larnek in forum Vehicles For Sale / Trade
    Last Post: 11-03-2005, 10:40 PM
