Results 21 to 40 of 55
  1. #21
    Junior Member BYOFICR's Avatar
    BATON ROUGE
    QSM
    04 gto
    here is mine
  2. #22
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    You kept your MAF? I like!!
  3. #23
    Member GTO1_OHIO's Avatar
    Melbourne Beach, FL
    2004 GTO
    Yeah this is made so that a MAF will fit.
  4. #24
    North Jersey
    2004 GTO M6
    GUHREAT SUCCESSE!! *Borat*
  5. #25
    BATON ROUGE
    QSM
    04 gto
    you kept your maf? I like!!
    yep and sucks anything in its path! Lol!
  6. #26
    North Jersey
    2004 GTO M6
    I'm getting ideas now. *scratchin goatee*
  7. #27
    Member pmolina0436's Avatar
    2004 GTO
    I am taking donations so i can get one of these intakes..anyone??
  8. #28
    Melbourne Beach, FL
    2004 GTO
    Some initial results from my new speed density tune with the svede1212 intake.
    452.51 rwhp 403.79 rwtq
    + 12.43 rwhp + 1.07 rwtq over a year ago ... nothing has been done to the car other then replacing the LPE intake with the svede1212 intake
  9. #29
    North Jersey
    2004 GTO M6
    Nice job!!
  10. #30
    Member 6.0LiterImportEater's Avatar
    Frederick, MD
    2006 Pontiac GTO
    I saw that someone built a custom one out of fiberglass by forming/fitting foam and then applying the fiberglass over it. Came out quite nice once painted. I'm thinking of going that route since the only one out for the '05-'06 is the Varaam and not diggin it.
    I'm also a fan of fuckin around and building things while saving money hahaha!
  11. #31
    Senior Member qwkgto's Avatar
    OHIO"S only 9 second GTO
    Phantom Black Metalic
    2005 GTO
    Quote Originally Posted by GTO1_OHIO View Post
    Nice ,this means car is home again!note to self get my goat done so we can go racing!
  12. #32
    Melbourne Beach, FL
    2004 GTO
    Quote Originally Posted by qwkgto View Post
    Nope it wasn't but now its is.
    Finished the tune, for now, and picked up another 2 rwhp to finish at 454.48 rwhp 403.08 rwtq. I'll take a 14.4 rwhp gain anytime.
    Just went down to Summit and picked up a NGK wideband so I can monitor the tune at the track.
  13. #33
    congrats on the numbers.....how you liking the speed density tune? Should be a lot less headaches idling and cruising.
  14. #34
    Melbourne Beach, FL
    2004 GTO
    The tune seems pretty good. I'm going to go to the super chevy show next weekend so I'll see how the car runs.
  15. #35
    2005 GTO
    I bet the car runs better in the heat,now maybe he can run those 11s in the hotter weather
    Now if I can get all my parts back and everything in car for Norwalk..ll be able to check this all out in person.
  16. #36
    Melbourne Beach, FL
    2004 GTO
    I found some use for parts from my LPE CAI. I reused the rubber edging that sealed the top and sides of the LPE air box to the hood and fender to seal between the radiator cover and intake.
    ... but more importantly I also put it on the frame to seal off the bottom of the intake from hot air rising from my tranny cooler.
    Then I reused the IAT fitting from the K&N filter to secure the IAT to the back of the intake..then use a Thermo-Tec Adhesive Backed Heat Barrier* product to protect it and the intake from heat soak.
    * These aluminized Heat Barriers are made up of woven silica with a flexible aluminized finish. The highly reflective surface of the material is capable of withstanding radiant temperatures in excess of 2000 degrees F.
  17. #37
    link to the heat barrier stuff?
  18. #38
    Melbourne Beach, FL
    2004 GTO
    Summit Racing carries a line of their products, Heres the two products I used:
    Sheet:
    http://store.summitracing.com/partde...5&autoview=sku
    Tape:
  19. #39
    thank you sir
  20. #40
    Melbourne Beach, FL
    2004 GTO
    Today was the first of three days of racing at the Super Chevy Show. …My job is to determine what gains were made by using the svede1212 OTRCAI and a speed density tune.
    First the base line: April 11 - Summit Motorsports Park, Norwalk Ohio
    DA: -87
    60: 1.65
    1/8: 7.47
    MPH: 92.9
    1/4: 11.74
    MPH: 119.98
    Todays runs: June 12 - Summit Motorsports Park, Norwalk Ohio (with the svede1212 OTRCAI)
    DA: + 1929
    60: 1.67
    1/8: 7.55
    MPH: 93.71
    1/4: 11.85
    MPH: 119.28
    So what does this tell us other then I’m running about the same time with a difference in DA of 2000? First of all the 93.71 is a new PM 1/8 MPH, the 92.9 above in April had been my best.
    My other 2 runs today were:
    DA: + 2031
    60: 1.67
    1/8: 7.56
    MPH: 93.60
    1/4: 11.87
    MPH: 119.34
    DA: + 2013
    60: 1.68
    1/8: 7.59
    MPH: 93.12
    1/4: 11.91
    MPH: 118.76
    So as always my car ran extremely consistent today. Correcting the times above for DA ... show corrected I actually ran faster today then on a day when it was in the mid 40s.
    April:
    11.717 @ 120.333
    Today:
    11.700 @ 121.048
    11.699 @ 121.242
    11.748 @ 120.63
    This comparison shows about a 1 MPH gain from the OTRCAI …. But lets look at previous runs at about the same DA. The following runs are from Pontiac Nationals weekend at Norwalk last August.
    August 8 2008
    DA: 2103
    60: 1.69
    1/8: 7.704
    MPH: 91.58
    1/4: 12.12
    MPH: 112.47
    August 9 2008
    DA: 2288
    60: 1.70
    1/8: 7.68
    MPH: 92.41
    1/4: 12.05
    MPH: 114.01
    August 10 2008
    DA: 1746
    60: 1.70
    1/8: 7.66
    MPH: 91.15
    1/4: 12.03
    MPH: 114.89
    …so at similar temperatures ( simular DA) in the low 70’s last year I was running 5 MPH less and couldn’t break into the 11s. Damn heat soak!!! But again my car ran consistent over those three days.
    So my biggest impression so far is I’m running late fall/early spring times today with the temperature 30 degrees warmer. …the only change is the OTRCAI and SD tune. So from last year at Pontiac Nationals the gain is 5 MPH … not that the car couldn’t do it before but the svede1212 OTRCAI is keeping the IAT down. I observed that after my first and second runs today that the difference between ambient and IAT was 6 and 7 degrees respectively. The A/F mix was also right on at around 12.65 – 12.75 crossing the line ( I have a permanent wideband)
    Tomorrow is the True Street Challenge where racers drive out of the park on the streets for 10 miles then come back and hot lap 3 runs for an index race. Guess I’ll see if the heat soak problem is still a non issue.
    Sunday is bracket racing so still a different setting to do some testing.
  1. Custom Sub Box
    By TopForm11 in forum Stereo and Electronics
    Last Post: 05-31-2007, 11:19 AM
  2. Custom FRC's
    By CWW17 in forum Showcar and Detailing
    Last Post: 05-25-2007, 12:09 PM
  3. Custom Tag for my Car
    By jimbo98z in forum Almost Anything Goes
    Last Post: 05-09-2006, 01:04 PM
  4. 94' Custom S-10
    By Larnek in forum Vehicles For Sale / Trade
    Last Post: 11-03-2005, 10:40 PM
