Results 1 to 17 of 17
Thread: Frost...tranny settings
04-28-2009, 06:26 PM #1
I've wondered about this for a long time and have never stumbled across the reason it's like this.
Why does the car shift differently if you move the selector manually? If I move the selector down to L1 and take off and immediately put it in L2 it will bang the limiter everytime. I'm pretty sure it'll do it if I just drop it to L3 also. If I leave it in drive it shifts pretty much right where my shift points are.
I logged my mph to make sure my mph was being met and it is. Could it be because my mph is actually shifting quite a bit higher than I have it set? I know in the old days they always said you wanted those pretty close together but I've also seen tunes where people have zero'd out the mph and used rpm only. What puzzles me is why moving the selector is changing the shift points. If I leave it in drive it shifts pretty much where I have it set at. The 1-2 shift is a little sooner than commanded but I can adjust for that.
04-29-2009, 02:00 AM #2
- Oct 2007
- Beaver Dam KY
Subscribed. On another note, when mine is in second it wont downshift to first "Most" of the time, and when in 3rd it does the same.
04-29-2009, 02:27 AM #3
I "think" the elecrontic shift control only operates with the thifter in OD and D, and only OD in cars with a 3 inplace of the D. It's Posible that the electronic shift control gets disabled durring manual gear selection. Which means the trany MAY use pump pressure or rpm or both to "automaticly" shift between gears.
04-29-2009, 02:34 AM #4
04-29-2009, 02:52 AM #5
- Oct 2007
- Beaver Dam KY
04-29-2009, 03:11 AM #6
04-29-2009, 08:23 AM #7
Subscribed. Similar thing going on with our A4... the 1-2 manual shift will engage upon shifting, but the 2-3 shift will delay until it tachs out.
04-29-2009, 08:27 AM #8
04-29-2009, 10:27 AM #9
I have seen it but I don't know why it is. I tell people if they want to shift, get a MVB or a six speed. Even if you HAD control, you cannot shift repeatably like the PCM, so why give that up?
It's not the answer that you want, I know
04-29-2009, 10:32 AM #10
04-29-2009, 11:01 AM #11
I agree with you 100%..... I never shift manually at the track. The only time I've ever really shifted manually was if I wanted to hold first gear such as making a turn and then hammer it when I got straight. If I do that then it bangs the limiter. I would like to solve the question as to why it shifts differently when I do. I'm going to log delivered torque and start looking at where it's at on those tables and raising specific pressures and see what happens.
04-29-2009, 11:05 AM #12
04-29-2009, 11:05 AM #13
04-29-2009, 11:48 AM #14
Usually, if you are holding a gear, as soon as you hit it, immediately moving back to drive makes it hold the way you want and it will still go back to normal WOT shifting (ie it wont shift when you move the selector but rather when it gets to the top of the gear as it should).
04-29-2009, 12:21 PM #15
04-29-2009, 01:42 PM #16
I have seen inconsistency between years with that method and never bothered to take notes as to which OS's did what. Sorry, not a lot of help here
04-29-2009, 04:00 PM #17
well, I'll get to work on it in the next week or two and see if I can make any progress at least with the 98's. I just hate having to slap the limiter to test and see if my adjustments are working. I may back everything down to a more tolerable level until I get it figured out as to what I need to do. Right now my limiter is only 6700 but on a 98 I feel that's pushing it to keep bouncing it off there.
Cooling fan(s) settings
By cruzincamaro in forum External EngineReplies: 0Last Post: 05-04-2012, 05:42 PM -
Transmission Settings
By pajeff02 in forum Computer & TuningReplies: 27Last Post: 11-08-2010, 06:04 AM -
Rpm settings
By ledesma54 in forum Computer & TuningReplies: 4Last Post: 07-24-2008, 01:24 PM -
Alignment Settings???
By dougcw in forum Suspension and HandlingReplies: 12Last Post: 10-05-2006, 11:16 PM -
Shock settings
By The Rookie in forum Suspension and HandlingReplies: 1Last Post: 11-25-2005, 10:26 AM
