Results 1 to 20 of 30
Thread: ls6 intake swap
    Member SSMOKEshow's Avatar
    Feb 2008
    in the world
    1999 Camaro SS
    ls6 intake swap
    in getting an ls6 intake for my 99 ss just woundering what i will need to do to install it the right way
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Junior Member Cookie's Avatar
    Mar 2009
    Carbondale, IL
    go very slow! and take your time getting around the oil sending unit which is right behind and towards the right of the intake but in front of the brake booster vacuum hose. lots of guys break em and your gonna have to get a new one as well as the socket to put it in as a regular deep socket isnt deep enough.
    Member qwk93ta's Avatar
    Fairfield, Ohio
    00 WS6
    You will either have to grind the bottom of your LS6 intake or buy LS6 coolant lines.
    Dealing Powder ntimid8r7's Avatar
    Sep 2008
    Saint Cloud,FL
    1994 Z28 MQBM
    2001 SS #1629 LPM
    NAPA has the only socket that will fit it correctly. the others are too tight.
    Fairfield, Ohio
    00 WS6
    What size socket do you need from Napa?
    Sep 2008
    Saint Cloud,FL
    1994 Z28 MQBM
    2001 SS #1629 LPM
    If you break it, when you buy the sending unit just take it down and size it. I think it is a 1 5/16 BUT i could be wrong as my dad has it right now changing the one in his Silverado. I will see if I can find you the link.
    Sep 2008
    Saint Cloud,FL
    1994 Z28 MQBM
    2001 SS #1629 LPM
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    shit if you break the opsu..then no need for a deep socket..a regular will work since its broke..then just hand tighten the new one..however..make sure you unplug the opsu first..that will give you more room to lift the brake booster over the opsu..and you wont break it. its easily a two man job.
    Sep 2008
    Saint Cloud,FL
    1994 Z28 MQBM
    2001 SS #1629 LPM
    hand tighten and then when you can't figure out where the oil leak is at............
    Shepherd, Michigan
    98' trans am
    Quote Originally Posted by ntimid8r7 View Post
    mine isnt leaking.
    Arizona
    mine isnt leaking.
    Not yet..........
    Arizona
    To the original poster, to install them the "right way" as you stated could mean different things to different people.
    To me it means to avoid all the grinding on the intake crap and go through with the purchase of the correct coolant lines, plugs, and the seals for them. Also a new set of intake gaskets is good insurance. Some re-use the old ones, I prefer to not take a chance of doing it over.
    This stuff will set ya back another $150 or so. Just depends on the person I guess.
    Fairfield, Ohio
    00 WS6
    What is this link for?
    Shepherd, Michigan
    98' trans am
    mine isnt leaking.
    Not yet..........
    you mfers..just noticed it started to leak ..now i need to find a place that actually sells the right size..since before i was going to rent a opsu socket..but autozone and advanced auto both didnt have any that fit
    Mar 2009
    Carbondale, IL
    we just snugged mine and i was runnin oil out so fast you would have thought we drilled a hole in the pan. So we took it back apart and put 2 wraps of pipe tape on the threads and cranked it down until it wouldnt move any more... now it doesnt leak
    Sep 2008
    Saint Cloud,FL
    1994 Z28 MQBM
    2001 SS #1629 LPM
    The NAPA link was for the oil pressure switch socket but I didn't realize that it would expire.
    It is part# SER 3458.
    You have to get it tight enough for the crush ring to do its job.
    Shady, I hope it didn't make too much of a mess for you. There is nothing worse than trying to get an oil leak cleaned up.
    www.fquick.com/ntimid8r7
    www.cccfonline.com
    Triple H Coating
    Specializing in Powder and Ceramic Coating
    steve@triplehcoating.com
    www.triplehcoating.com
    Feb 2008
    in the world
    1999 Camaro SS
    thanks guys
    Shepherd, Michigan
    98' trans am
    what's a little bit of oil i am going to go pick up the socket and do it when i get out of work.
    Shepherd, Michigan
    98' trans am
    whats the torque on that bisssh
  1. Question: HOW TO: Swap stock intake with LS6 intake
    By thechad125 in forum General Help
    Last Post: 02-26-2013, 03:17 AM
  2. intake swap ?
    By jeffz0rz in forum External Engine
    Last Post: 10-05-2009, 04:01 PM
  3. ls6 intake swap
    By lonsr13 in forum General Help
    Last Post: 09-11-2008, 07:34 PM
  4. anyone ever get dtc after ls6 intake swap?
    By senicalj4579 in forum External Engine
    Last Post: 04-03-2007, 12:51 PM
  5. LS1 to LS6 intake swap.
    By gnomee in forum External Engine
    Last Post: 02-02-2006, 09:58 AM
