Results 1 to 18 of 18
Thread: My SLP AIR hole plug
03-12-2009, 11:58 AM #1
Reading around i found different ways to plug the hole in the side of the lid for the AIR hose. Here was my fix that only cost me $1.39 at lowes for a 2 pack of 7/8 nylon hole plugs. It was cheap and looks somewhat decent.
03-12-2009, 12:07 PM #2
- Jul 2005
- Jacksonville, FL
Looks good, I'll have to tell my friend about yours - he has one of those gold expansion plugs in his.
03-12-2009, 01:17 PM #3
since you put the size needed and place you found them then you get a sticky.
03-12-2009, 01:28 PM #4
- Aug 2006
- Baton Rouge, La.
QuickSilverMetallic- 2005 GTO M6
Now what do you do with the hose you took off of that? Im thinking about doing this, but I dont want to rip the emissions junk out.
03-12-2009, 02:28 PM #5
- Feb 2006
- U. S And A Greatest country in all of world
Stock- 2002 Camaro
thanks for posting! i was just gunna ask
where did you get that bellows?
03-12-2009, 04:35 PM #6
- Apr 2008
- Madison, WI
It kinda looks like the SLP smooth bellows, doesn't it? I think thats what it is.
03-12-2009, 04:49 PM #7
- May 2007
- Bartlesville, Oklahoma, United
Bright Rally Red- 2000 Camaro SS #5075 M6
I used a cap off a battery post...it fit perfectly and I used some black tape to cover the small slit in the end of it..cost=$0
03-12-2009, 04:59 PM #8
The hole plug is in the hardware section at lowes in all the pullout drawers.
As for the coupler it is a fernco sewer coupler. Also found at at either home depot or lowes. I had to trim a little on bit of both edges to make it work though.
03-28-2009, 03:56 PM #9
- Sep 2007
- Philly+Glenmoore, Pa
That hose connects directly to the air pump. If you do race style (air delete) Long tubes theres no reason for the air pump anymore. You can go in and take it out. If you want to keep it you can cut down the hose and get a breather for it.
I did this exact same thing. Got a plug from Lowe's because I have the same SLP lid and removed my air pump.
I'll have to grab some pics.
03-28-2009, 07:10 PM #10
03-29-2009, 12:08 AM #11
- Oct 2007
- Beaver Dam KY
Well you got the plug but I dont have a rubber grommet for it...
03-29-2009, 01:28 PM #12
- Sep 2007
03-29-2009, 01:50 PM #13
- Oct 2007
- Beaver Dam KY
03-29-2009, 02:35 PM #14
I'm the same way, although my emission stuff including the AIR pump is deleted in the tune, I left everything hooked up as if it were working.
So I never needed the plug, I left the entire hose intact with pump and all.
I just couldn't see taking it off and having another box full of 4th gen parts laying in the garage
03-29-2009, 02:36 PM #15
05-04-2022, 10:56 AM #16
09-08-2022, 06:13 AM #17
- Oct 2021
- usa
white- 1999 firebird
so then you do not have to state smog the vehicle? no visual inspection?
11-27-2022, 09:02 AM #18
- Nov 2022
- amesterdam
what do you do with the hose you took off of that? Im thinking about 192.168.100.1 192.168.1.1 doing this, but I dont want to rip the emissions junk out.
Samsung still needs to plug hole in Android devices
By Ed Blown Vert in forum Computers / GamingReplies: 0Last Post: 12-30-2012, 08:50 AM -
spark plug threads stuck in hole
By ls1wallen in forum General HelpReplies: 5Last Post: 05-23-2011, 10:36 AM -
Stripped Spark Plug hole
By Lunatikgixxer in forum General HelpReplies: 7Last Post: 12-19-2010, 06:59 AM -
Do I need to plug this hole?
By Hawk23 in forum General HelpReplies: 22Last Post: 05-23-2008, 05:01 AM -
Spark plug wire and plug!
By RYDER661 in forum General HelpReplies: 2Last Post: 03-13-2006, 09:01 PM
