Thread: Replacing fuel lines
02-24-2009, 12:35 PM #1
- Pittsburgh, PA
I want to replace the fuel lines with stainless steel braided lines. Only thing I don't understand is what that little green valve does on the existing fuel line and how to go about putting that on the new line. Is it just remove/replace or do i need adapters for the 6AN fittings? What does that do anyway?
Custom Car Emblems from third_shift|studios
jaison tortorea
02-25-2009, 05:03 AM #2
- Danville, PA
Navy Blue Metallic- 1998 Camaro SS
That little green fitting is actually the relief valve for the evap system. You won't remove that, it is not a fuel line. If you get under the car and trace the hard lines what you'll find is that there's only two lines from the fuel system that run to the front of the car. One is the main feed line, the other is the evap system. The main feed line travels back to the fuel filter. Back there, you'll notice that there is a tee where the return line comes off and runs to the tank. If you intend to run an adjustable fuel pressure regulator, you'll need to run a new feed line and use the stock feed line as your return line or you can ditch the hard lines all together and run two braided lines, one for feed and one for return. Leave the hard line there for the evap.
There's a lot more to explain about this and you'll need to do some more research.
02-25-2009, 05:36 AM #3
Why do you want to replace fuel lines?
02-25-2009, 06:42 AM #4
- Pittsburgh, PA
Shit, that was really helpful, but you went the wrong direction! I want to keep all the hardlines, up to the engine bay-where it turns "soft" i want to replace that stuff with some dressy-er braided fuel lines. So question remains i guess, sorry, but that was very thorough!
Dress up the engine.
Question: Fuel lines
By kingls1 in forum General HelpReplies: 0Last Post: 07-21-2012, 05:56 AM -
fuel lines
By Ls_won in forum General HelpReplies: 3Last Post: 09-03-2010, 06:02 PM -
Question: fuel lines
By pewter Z28 in forum General HelpReplies: 0Last Post: 08-16-2010, 05:24 PM -
By 2000dreambird in forum External EngineReplies: 6Last Post: 05-21-2010, 08:20 AM -
Help: air and fuel lines
By third_shift|studios in forum General HelpReplies: 34Last Post: 03-14-2009, 06:54 AM
