Results 1 to 13 of 13
Thread: Dart 205 Heads
    RI
    Mag Red
    2002 Vette
    Dart 205 Heads
    Dart 205 heads with 10K miles on them. Never raced or tracked. Heads were disassembled when new and the ports were sanded to remove the casting lines and the chambers were smoothed.
    Since I removed them in November 2008, they have had the following work done to them.
    1. Full disassembly and the ports were cleaned by hand (no large power tools or chemical tanking).
    2. The valves have been ultrasonically cleaned to new condition.
    3. Once all parts received their initial cleaning, the guides were hand washed, lubed and all valves were lapped using fine lapping compound.
    4. Once lapped, the heads were checked for flatness and cleaned a final time.
    5. The valves were ultrasonically cleaned a 2nd time to prior to assembly.
    6. The heads were re-assembled measuring installed height of each valve spring (installed heights are below)
    These heads should be ready to install straight out of the box when you receive them.
    I am also including a set of Denso Iridium IK-20 gasket spark plugs. If you check the price on these they are $11.99 apiece new.
    Price: $995 plus shipping if paying by postal money order for the heads including the plugs. Paypal add 3%.
    Here is a listing of parts that comprise these heads:
    62 cc Combustion Chamber
    Valves – The valves are REV part no. CL-1170 (intake) and CL-1168 (exhaust).
    “REV CL Series valves are one piece forged, swirl polished and have hard chromed stems. A special solution style heat treat process is used for this line of valves to maintain a consistent grain flow in the material for unsurpassed ductility, longevity and reliability.”
    Valve Springs – PSI1511 beehive valve springs
    Valve spring locks – Machined/hardened
    Retainers – Titanium manufactured by Trick Titanium (they make the retainers for Comp as well)
    Shims - Comp Cams
    Valve Seals – U.S. Seal (same manufacturer as GM OEM)
    Valve Spring Installed Heights
    Photos of bare heads cleaned through final assembly.
    Fresno Ca
    LPM
    2002 Z28 Camaro
    DAM! I wish I had the money! Heres a free bumb for you.
    Member devildogws6's Avatar
    Monticello MN
    1 (100%)
    2000 trans am ws6
    how much better are these than stock 243's??
    RI
    Mag Red
    2002 Vette
    Quote Originally Posted by devildogws6 View Post
    I honestly don't know and wouldn't want to make an inaccurate estimate.
    Monticello MN
    1 (100%)
    2000 trans am ws6
    gotcha lol,
    RI
    Mag Red
    2002 Vette
    TTT for a new day
    Member side2000's Avatar
    md
    2000 camaro ss
    factory ls6 castings flow 275 cfm @ .550, these flow 290. also have same comp ratio as ls6 castings. fair upgrade for a 346, especially w/ bigger valves. (dunno what's done to these didn't take time to read completely)
    RI
    Mag Red
    2002 Vette
    Quote Originally Posted by side2000 View Post
    Higher compression. LS6 are 64cc chamber, these are 62cc. These also don't go turbulent, unlike LS6.
    md
    2000 camaro ss
    i thoguht they were 64.5? my mistake.
    RI
    Mag Red
    2002 Vette
    The Darts are delivered as 62 cc which is a nice advantage because you don't need to mill to get the chamber size down, unless of course you want it smaller than the 62 cc.
    md
    2000 camaro ss
    well the fact they come w/ 62's is really nice, i'm not much a fan of altering precisely designed combustion chambers if i dont have to.
    RI
    Mag Red
    2002 Vette
    Up to the top
    RI
    Mag Red
    2002 Vette
    SOLD
  1. Dart 225 heads
    By Dewman in forum Internal Engine
    Last Post: 01-19-2011, 03:57 PM
  2. Dart Heads
    By Brownboy2020 in forum Internal Engine
    Last Post: 08-20-2007, 04:53 PM
  3. Dart pro 1 heads?
    By corvettefrance in forum Internal Engine
    Last Post: 01-11-2007, 06:19 PM
  4. Dart heads??
    By stangslayer98 in forum Internal Engine
    Last Post: 01-19-2006, 12:57 PM
  5. Dart heads
    By kraymond in forum Internal Engine
    Last Post: 11-10-2005, 10:01 PM
