Results 1 to 15 of 15
    Junior Member Johny Bee O's Avatar
    Switzerland
    Navy Blue
    2001 Camaro Z28
    Oil on the floor, headgasket?
    Today was a small oil paddle under my car the most oil was already evaporated?. So than i jack my car high to see, from where the oil comes. It looks the oil comes from the cylinderheadgasket but im not sure.
    [IMG][/IMG]
    here the passangerside head...
    [IMG][/IMG]
    What do you guess ? My car has 91kmiles. Whats the best Solution? only new Gaskets or should i replace also the heads? with LS6? hmm...
    The next problem is, i life in switzerland....
    So thanks for the help
    Robert
    NeW YoRk
    2001 ws6
    if its only the gasket why replace the whole head? Unless you wana upgrade
    CA
    +1.. head gaskets are fairly cheap and you could do all the work in a day...
    if your planning on going with a cam or something later.. then yes i would go ahead and upgrade to a better head.... if nothing else buy some stock ls6 heads or something.. if you have the money go for some ported ls6s or 5.3s... and if you are looking to get some nice heads, go for some AFRs or TFPs
    Switzerland
    Navy Blue
    2001 Camaro Z28
    Damn i hate it ... the last 8tkm i drove with the Mobil1 0W-40, i hope the oil wasnt to runny. Is somewhere in the world wide web a guide "how to remove the cylinderhead" ?
    I restore my old buick.... and when i see the LS1 engine in the camaro.. damn is this tight
    NeW YoRk
    2001 ws6
    im sure theres one out there somewhere, if not im sure some of the guys on the site might be able to take you through the steps
    TJEA Retirement Home Dr.Crash's Avatar
    Feb 2006
    U. S And A Greatest country in all of world
    Stock
    2002 Camaro
    Here is how to do a Head/cam swap. should help a little. Good luck!
    http://www.ls1howto.com/index.php?article=2
    Billings,MT
    Sunset Orange Metalic
    2002 Firehawk
    Are you sure about the head gasket leaking?My experiance is the valve covers.Just thought you might want another opinion.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Quote Originally Posted by mghawk57 View Post
    I agree. Clean the area really good and drive for a few miles. Could also be a rear main gasket. When it is running do you smell burning oil? Can you see smoke coming of the exhaust manifolds?
    Marylandistan
    2001 Trans Am (sold)
    I'd make damn sure of where it's coming from before I pull the head.
    Switzerland
    Navy Blue
    2001 Camaro Z28
    Hey thanks to everbody who helps me! really friendly this Board. Today i try to clean the head. Than i will watch with a mirror behind the corners from the head to see where the oil comes.
    Can anyway the Mobil 1 0w-40 the cause to be?
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    I have a problem with my dipstick tube leaking on an LT1 on that same side as your leak. Is the LS1's dip stick on the same side? I bought a new TB and decided to not run the pcv hose to the TB and just put a small breather on the valve cover. Now because I am not sucking the crank case air out of the motor, pressure builds and the dip stick tube is one of the spots mine tries to vent from and it gets all over the block and starter. I need to put a bigger breather on it but some food for thought anyway.
    CA
    Quote Originally Posted by Johny Bee O View Post
    i have heard of people actually running too thin oil..
    try some pennzoil plat. 0-30 or 5-30..
    San Diego ca
    "Arrest Me Red"
    2001 trans am
    just put 10-30 i have sean seal start leaking with thin oil also. i would bet the cover.
    jacksonville
    2001 Chevrolet Camaro SS
    The rule of thumb is start from the top of the motor and work your way down. Valvecover gasket are extremely easy to do and cheap at that. Also take a look around the cam sensor and the oil pressure sending unit, chances are its not coming from there, but it is possible. Clean everything up and go drive and I would run a little thicker oil, 5-30 should do the trick.
    Switzerland
    Navy Blue
    2001 Camaro Z28
    So today i tried make better fotos...
    here they are:
    and here the vavlecover
    In the next step i will clean the oil.... than i hop i will see where the oil is comming...
  1. Help: Wet Floor Pan
    By fan4LS1 in forum General Help
    Last Post: 01-28-2012, 08:49 PM
  2. Headgasket? Pleas help!
    By 01NavyBlueSLPSS in forum Internal Engine
    Last Post: 04-10-2011, 02:54 PM
  3. Question: Blown headgasket?
    By clg82 in forum Firebird / WS6
    Last Post: 07-21-2010, 05:14 AM
  4. WS6 Floor mats
    By kwade in forum Appearance Section
    Last Post: 02-20-2008, 09:48 AM
  5. WTB 97-99 TA Floor Mats
    By 9c1ny in forum Parts Wanted / Trade
    Last Post: 02-14-2008, 04:56 PM
