#1 |
98 Trans Am
Tranny servo's?
I keep seeing the Jet servos for the auto tranny supposed to give you firmer shifts. What exactly does the servo do and is it worth buying one or should I go for a shift kit.
Sorry for questions been out of the RWD world for a while been tuning FWD sorry about that! |
#2 |
Tech Junkie
Pewter Metallic
Usually the servo contains a piston that applies the band to perform the shift. Most aftermarket servos have a larger surface area to apply more force when the shift occurs. Short of replacing the band with one having more friction area or a better grabbing compounds, is the best way to keep a trans from slipping when more power is applied.
__________________
Hammer - hammertime.us 2001 Light Pewter Metallic Camaro SS, 6 speed K&N, SLP Lid, SLP y-pipe, GMMG cat-back, Lou's Short Stick - more to come!
#3 |
1997 Formula
Arrest Me Red
You are probably better served with a shift kit at this time.
If you rebuild the trans, the answer would be different. Just remember RWD,RWD, RWD. |
#4 |
98 Trans Am
So this causes less slipping and slipping is bad for a auto. Yes RWD RWD RWD lol! The FWD is fast though its a S/C CRX but takes alot of drama to go fast and the T/A just does it like its nothing!
| Bookmarks |
| Thread Tools | |
