TunedbyFrost
Go Back   LS1 Performance Information > LSx Technical Help Section > Drivetrain > Automatic Transmission
Online Store Sponsors Rules
Notices
Kentucky-Speed Autotrix Fast Toys Performance
Reply
Thread Tools
Old 01-14-2006, 10:57 PM   #1
99WS6TA
1999 Pontiac Trans Am/WS6
Does the car need tuning after TC install?
The engine is stock with 120k and the TC is 3400. The transmission feels like it shifts 5 times instead of 4. Is this normal without tuning? Will tuning fix this? Or is this a tranny problem? Thanks for for any help!!!
99WS6TA is offline   Reply With Quote
Old 01-14-2006, 11:25 PM   #2
MysticZ28
01 Z28
Mystic Teal
Quote:
It can only shift 3 time ... 1-2;2-3;3-4 ... If you are wot into 4th the TC won't lock up until you back out of it.
Sometimes with a AM TC even with normal acceleration the TC may not lock up right away and may even lock, unlock and then lock again.
MysticZ28 is offline   Reply With Quote
Old 01-15-2006, 08:01 AM   #3
nhraformula
member since may 2000
Veteran Member
nhraformula's Avatar
2000 nhra edition formula
i had a converter tune done when i added the tc.
__________________
a few bolt ons, 379 rwhp
11.96 @113.25
nhraformula is offline   Reply With Quote
Old 01-15-2006, 09:24 AM   #4
Ed Blown Vert
Blown, Stroked, & Sprayed
Ed Blown Vert's Avatar
383 Procharged & N20 Vert
What you are feeling is the TC locking up. Normal.
__________________
Forged 383, ATI D-1SC
NX MAF Kit, 222/226 .585 115
AS Stage II 6.0L FI Heads
548.0 RWHP - 536.8 RWTQ - 10# - D1
Black 2008 GMC Yukon Hybrid 4WD
DDM 55w 5000k HID Hi/Lo
GMX-322 LockPick
WeatherTech Cargo Liner
Gunner 6 20" Wheels
Ed Blown Vert is offline   Reply With Quote
Old 01-15-2006, 10:07 AM   #5
99WS6TA
Yes, all is well!!!!! That's right it should only shift 3 times but I feel 4 shifts. The last being the TC locking up. I appreciate it!!!
Old 01-15-2006, 08:53 PM   #6
MysticZ28
01 Z28
Mystic Teal
Quote:
What did they do on your converter tune?
Old 01-15-2006, 10:15 PM   #7
nhraformula
Veteran Member
Quote:
upped shift points,changed line pressure, deleted torque management and some other stuff i cant think of now.
the tune cost 150.
Old 01-15-2006, 10:35 PM   #8
99WS6TA
I plan on getting the mail order basic tune from TSP or ThunderRacing.
Old 01-15-2006, 10:56 PM   #9
MysticZ28
01 Z28
Mystic Teal
Save it and get a dyno tune when you do H/C ... unless you spend a lot of time at the track and want to squeze ever last hundreth out.
Setting your shift points is an exercise in futility unless you know exactly where you power curve is ... Torque management is good for a couple of hundreths ... Line pressure, just makes your shifts feel more impressive and some TC manufacturers recommend against with high stall converters.
Old 01-16-2006, 06:39 AM   #10
MNR-0
MNR-0's Avatar
2004 Monaro
BLACK
Feeling your converter lockup nice and firm is a sure sign all is well. Mine locks up smoothly like a 5th gear.
MNR-0 is offline   Reply With Quote
Old 01-16-2006, 08:54 AM   #11
99WS6TA
I'm only about 3 hours from TSP and it is my understanding that you can get the dyno tune at a discounted rate if you by the basic tune from them first.
Old 01-16-2006, 01:04 PM   #12
nhraformula
Veteran Member
any ls1 tuner will know where to set shift points. i did the converter before the cam and speedinc did the basic converter tune. they only upped the shift points by maybe 300rpm in every gear, but it made a difference for the better.
Old 01-16-2006, 01:24 PM   #13
MysticZ28
01 Z28
Mystic Teal
Unless you have a dyno run to back it up or doing a series of runs while adjusting shift points, you are just guessing.
That said, what every LS1 tuner knows is the stock shift points are set so conservatively that upping them by 300 rpm over stock is a no brainer, for the most part.
Though 300 rpm will show an improvement over stock, what you don't know is whether 200 rpm over or 400 rpm over would have actually been optimal.
Old 01-16-2006, 02:02 PM   #14
nhraformula
Veteran Member
i have a feeling busy tuners as speedinc know where improvements are to be had.
Old 01-16-2006, 05:30 PM   #15
mighty username
you're gay
mighty username's Avatar
RED
they only happen to have Jim Moran as a tuner, who is quite possibly one of the most experienced LSx tuners in the country.
mighty username is offline   Reply With Quote
Old 01-17-2006, 04:15 PM   #16
hammertime
Tech Junkie
hammertime's Avatar
Pewter Metallic
It was already stated above, but yes, you are feeling the lockup of the converter. Probably never noticed it before because the stock converter is already much closer to a fluid coupling when the electric clutch is engaging. Your looser converter probably lugs the engine just a bit as the clutch engages, feeling like another shift.
__________________
Hammer - hammertime.us
2001 Light Pewter Metallic Camaro SS, 6 speed
K&N, SLP Lid, SLP y-pipe, GMMG cat-back, Lou's Short Stick - more to come!
hammertime is offline   Reply With Quote
Reply
EmblemPros Zaino PerformaBuilt
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
GM Parts Direct
One of the largest message boards on the web !
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
