Page 1 of 23 1234521 ... LastLast
Results 1 to 20 of 445
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    My Procharger Build - Kinda
    Well pulling the trigger this week. For my current goals I ended up getting the below. I think I'll be satisfied as this is mainly a street car that sees little track time.
    Sometime down the road I might forge the bottom end and up the boost. We will see. At that time I'll deal with what I need to change (extra fuel pump/bigger injectors/FMIC/etc).
    A guy that Frost recommended will be doing the install. I couldn't pass up his prices and I just don't have the time/space right now so I rather have someone who is confident and that has experience do this.
    I will be posting up pictures and such as the car is in progress. Build starts in 3 weeks. Car gets tuned by Frost in May.
    D-1SC Head Unit - Satin finish
    - ATI brackets/hardware
    - ATI Drain Upgrade
    - ATI truck inlet hat/filter
    - ATI damper
    - ATI pinning kit
    - 8 Rib Drive System
    - Polished plenum
    - upgraded ATI bypass valve
    - ATI HO twin intercoolers
    - Aster Tensioner Bracket
    - LS2 Water Pump - Part #89018052
    - Auto Meter Triple Pillar Pod, 2-1/16" - Part #43-12213
    - Auto Meter 4904 - Auto Meter Ultra-Lite II Analog Gauges - Boost Gauge
    - Auto Meter 6563 - Auto Meter Ultra-Lite Digital Series Gauges - Fuel Pressure Gauge
    - Auto Meter 4378 - Auto Meter Ultra-Lite Digital Gauges - Wideband A/F Gauge
    - Racetronix Fuel Pump - # F99-FPA
    - Wiring Harness for fuel pump - # 99-FPWH
    - Siemens Deka Mototron 60lb Injector: Set of 8
    - AlkyControl Methanol Injection Kit - Complete kit #AC109 Kit
    - Comp 918 valve springs and Manley 7.4" hardened push rods
    For those of you who have never seen my car, pictures are in my profile.
    Current mods are in signature. Hoping it all holds up after the install because I will be BROKE after this one for awhile
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Subscribed.
    Pittsburgh
    2008 Hummer H3
    Member pewterz55's Avatar
    Jul 2009
    chicago
    light pewter metallic
    1999 z28
    awesome 35th. i envy your patience (and wallet) for doing your build the right way. never seen your car in person but after this i sure wouldnt mind checkin it out.
    Looking forward to seeing this all come together.
    Tucson
    Psycho Therapist
    I take "the" out of
    Good luck with the build. Have you ever thought of putting 317's heads on your engine. It lowers compression for more boost safely, or it makes it even safer for the boost level you will be running. Also if you have e85 in your area, I would recomend that more then a meth kit. Mostly because it is a great fuel that doesn't cause detonation. And that will help save your block for a while.
    have fun with this, and I am sure you will enjoy it once it is completed. Also nice to see you built you platform before spending all the money on the power. Most people buy the power then can't figure out why they can't get their car to hook.
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    in.......
    Lemont, IL
    2002 Trans Am WS6
    Nice! It's gonna be a long couple of weeks waiting up to that first drive, but it will be awesome!
    Congrats and enjoy!
    Nick
    2002 Trans Am WS6 - 520rwhp
    D1SC @ 10lbs | FLT Level V - SS3600 - ARH 1 3/4" LTs w/ Catted Y-pipe - Corsa - Koni 4/3's - UMI Adj. LCAs and Brackets - UMI 3 Pt. SFC's - UMI PHB - UMI STB - TTM's (17X9, 17X10.5) - M/T ET Streets
    college station, tx
    sold: 1999 firebird
    subbed..
    Jun 2009
    mass
    whered you order the alkycontrol kit from. been looking to order one but trying to find a good price. i just finished installing my procharger kit if you need any help on the install let me know. havent driven mine yet due to snow still ont the ground.
    i hate to tell you this but every one i talked to said the truck inlet hat will not fir with the twin intercoolers. i also didnt do the drain kit because i didnt see any need for it. procharger drain looks fairly accesable(sp)
    Quote Originally Posted by siluna123black View Post
    I ordered the AlkyControl kit from KYSPEED. Mark is a sponsor in this site.
    Agreed on the inlet truck filter. I have that squared away already. Forgot to update the list I already had after I found out the same thing.
    Thanks for the heads up!!
    Feb 2010
    Greenwood, IN
    Light Pewter Metallic
    subscribed
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    You are going to build what i wish to build someday
    ;) Packy's Avatar
    Apr 2001
    Surf City, NC
    Black/Screaming Yellow
    99 S/C TA WS6 & 04 Cobra
    Good luck! That car is going be hell on wheels with those 4.11's. I hope you have some good rubber ready for her.
    1999 Trans Am WS6 Black - Forged 346, P1SC (8psi), TH-400, and 12 bolt(3.73's)
    10.29@129 w/1.60 sixty foot
    2004 Screaming Yellow Mustang Cobra - Whipple 2.3, Exhaust, & CCW's...My DD
    Thought about that Packy. I'll have funds reserved for some M/T's. I don't think the Nitto DR's are going to cut it on the street any more. I also plan on eventually going with a 3.73 gear most likely, but that isn't going to happen this year.
    Junior Member blackmagicturbo's Avatar
    Jan 2011
    Ventura, ca
    bleen
    2000 SS
    Nice set-up made 642 whp (forged) with same blower set-up minus fuel system (dual aero 1000s) in same car,same color on 91 octane pump ,, get some good tires !!
    Boosted Fredneck Mark98SS's Avatar
    Frederick, MD
    9.62/140
    Any parts arrive yet?
    Minnesota
    '10 ZR1
    Quote Originally Posted by blackmagicturbo View Post
    What compression? 8 psi? Meth injection also?
    Apr 2010
    IN
    subscribed
    we've been waiting...cant wait to see it at the meet and ill have to make a trip up to the strip and give you a few runs late summer
    ;) Packy's Avatar
    Apr 2001
    Surf City, NC
    Yeah Nitto's will be useless until about 60mph. If you do 3.73's seriously look at your future plans. You might even want to go to around 3.55 or 3.50 ish gear if possible. You will be fine and I think really enjoy it with those 4.11's!
  1. Help: ProCharger Build 385 sbc
    By SmallBCS10 in forum Forced Induction
    Last Post: 05-16-2011, 11:53 AM
  2. Kinda no life, but still kinda sweet!
    By blackSS01 in forum Almost Anything Goes
    Last Post: 07-12-2010, 08:54 PM
  3. 500CI Chevy LS1 Engine Build - How To Build A 500C
    Last Post: 02-17-2009, 07:10 PM
  4. what kinda gun is this..... ?
    By bad boy 99 in forum Almost Anything Goes
    Last Post: 10-31-2007, 02:30 PM
  5. Kinda of a new guy
    By ScottZlt1 in forum Corvette
    Last Post: 10-03-2007, 12:33 PM
