Results 1 to 20 of 28
Thread: 98 PCM to 99+ PCM
01-02-2009, 06:05 AM #1
- Nov 2008
- Cheswick, PA
Silver- 1998 Camaro Z28
98 PCM to 99+ PCM
Anyone ever swap from a 98 LS1 PCM to a 99+
Theres very little support for the 98 due to the off year but a whole lot for the 99+
I assume its more than a simple buy a 99 PCM and have it flashed with my 98 programming...
Thanks!
01-02-2009, 06:44 AM #2
- Oct 2007
- Beaver Dam KY
You have to repin the wiring harness and do a lot of other crap. I know it requires you to use parts off of a van to get the fuel guage working as well. Its not fun from what ive heard.
01-02-2009, 10:27 AM #3
I have heard of many companies doing 98 pcm tunes, some even have them for sale. I would also look on ebay, I have been researching a pcm tune for my '98 and have not had many problems. If you want a hypertech/diablo tuner you won't find much. Those tuners don't do a whole lot though from what I have heard for the money.
01-02-2009, 11:08 AM #4
- Jan 2006
- Shepherd, Michigan
you need to repin your 99 pcm into the 98 harness etc..then you need to get the eco van's fuel section into the 99...then you get real time tunning and more bars etc...you can use any pcm from a 99+
01-02-2009, 01:36 PM #5
01-02-2009, 01:38 PM #6
- Nov 2008
- Cheswick, PA
01-03-2009, 05:10 PM #7
true the 99+ pcm's are the desired pcm's to have but your 98 can be tuned just fine. Get with www.lsxtune.com (frost on the board) about a mail order tune.
01-04-2009, 01:45 AM #8
01-04-2009, 03:41 AM #9
there are things you can do with the 99+ pcm's such as real time tuning that you can't do with the 98's. There are a few other differences too but the 98 can be tuned just fine. I know Frost says if he owned a 98 he would swap to a 99 pcm but I wouldn't. I don't feel the work involved repinning everything and getting the gas gauge to work and things like that is justified by the gains but that's just my personal opinion. There are positives to having that 99+ pcm for sure, I'm just used to my 98 I guess.
01-04-2009, 04:31 AM #10
- Jan 2007
- Hamburg, Germany
Silver- 1998 Camaro Z28 A4
thanks for the backup, i guessed as much. since i don't have plans for major modding/tuning i'll stick to my 98 pcm. and the car runs great at the moment.
01-04-2009, 03:20 PM #11
98's UNITE!, Frost was able to tune my 98 PCM, haven't tried it out yet because its winter!
01-06-2009, 07:27 AM #12
- Jan 2006
if your going for a heavily modded 98..a repin is really necessary..last thing you want at wot is the pcm guessing mixture and etc
01-21-2009, 12:00 PM #13
- Jan 2009
- new orleans
dark red- 98 Z28, 6spd
By chance do anyone make an adapted harness for the swap, just an idea but would be great.
01-23-2009, 05:47 AM #14
01-23-2009, 05:50 AM #15
- Oct 2007
- Beaver Dam KY
01-23-2009, 07:10 AM #16
It's a very old idea... Find connector that matches the PCM-side (a pcm-equivalent connector) and it can be done. They are not made though, so something new would have to be manufactured and the market for such an item is too small.
It's hard to accept that even if it was made that it's several-hundred dollar cost would be OK when you can accomplish the same thing without that much work as it is...
01-28-2009, 11:44 AM #17
- Dec 2008
- Anderson, SC
Metallic Red/Charcoal- 2000 Z28
It's hard to accept that even if it was made that it's several-hundred dollar cost would be OK when you can accomplish the same thing without that much work as it is...[/QUOTE]
I have absolutley no idea what's involved with swapping a "98" PCM for a "99" or later but would like to make the change. I have access to any 4th gen F body PCM or wiring harness that would be needed. Where could I find the instructions necessary to make this change or where to send to have it done?
Thanks,
01-28-2009, 02:15 PM #18
01-29-2009, 03:31 AM #19
- Dec 2008
- Anderson, SC
02-02-2009, 06:17 PM #20
I have done the swap a few times... PM me if you are interested.
Non Sponsors
