Thread: p1415
12-28-2008, 06:16 AM #1
- Jan 2007
- STL
RED- 2001 CAMARO Z
p1415
can anyone tell me what they mean? thanks josh
12-28-2008, 07:16 AM #2
- Jul 2005
- Jacksonville, FL
It's a secondary air code. Usually a clogged drivers side air check valve.
12-28-2008, 04:27 PM #3
- Jan 2007
- STL
RED- 2001 CAMARO Z
thanks man
12-28-2008, 05:14 PM #4
01-07-2009, 09:57 AM #5
I got the same code today: p1415 "Manufacturer Contrl Auxillary Emission Controls"
I'm not sure what/where the check valve is, can you give me hint?
Also, I have a hole in my PCV hose that I've "fixed" about a year ago with duct tape. That hole also caused the check engine light to come on (Codes P0171 and P0174 twice (left and right bank). Those codes haven't come back so I'm not sure if this is related or not. You can read about that little episode here: http://www.camaroz28.com/forums/showthread.php?t=590984
Thanks
01-07-2009, 10:14 AM #6
- Jul 2005
- Jacksonville, FL
It's the black disc shaped valve right above cyl #5 coil. It screws into the metal air pipe coming off the exhaust manifold, then attaches to the air hose with a clamp. Same part number for either side.
01-07-2009, 10:29 AM #7
- Oct 2007
- Beaver Dam KY
Codes: p0420 and p1415
By Thorinman in forum Computer & TuningReplies: 3Last Post: 04-14-2008, 06:00 AM -
P1415 Code, Tuning it Out
By ViperJ in forum General HelpReplies: 1Last Post: 11-22-2007, 07:48 PM -
SES code P1415
By dkroshko in forum General HelpReplies: 3Last Post: 04-03-2006, 07:09 PM -
P1415 SES code HELP!
By y2kformula in forum Computer & TuningReplies: 15Last Post: 02-17-2006, 05:24 AM
